Hello html gurus,
I am trying to drive RGB LEDs based on NOAA space weather data from this website:
http://www.swpc.noaa.gov/
The little squares depict current radio black out, solar and geomagnetic storm conditions.
using the inspect element function of my web browser, would this be the specific line to be parsed to retrieve the current radio black out conditions?
none
Thank you,
Greg
That does look like the line(s) you need except that when I look at the html, it says "no data" instead of "none".
Pete
Riva
November 28, 2015, 5:37pm
3
el_supremo:
That's what I also see if you look at the page without Javascript enabled or if I save the page as HTML is also says "no data"
zoomkat
November 28, 2015, 10:46pm
4
The below TextFinder application might be of use. I've got some complex weather code from others that extracts data from a NOAA web page I can post if you want.
http://playground.arduino.cc/Code/TextFinder
