Hi.
I am working on a project where I periodically send data to a google app engine using an Arduino Uno and a mounted WiFi shield.
Here is my loop code:
  now = rtc.now();
  Serial.println("Loop: "+getFormatedDateTime());
  if(then.unixtime() < now.unixtime())
    Serial.println("Measurement: "+getFormatedDateTime()+ "  Number of measurements done: "+numberOfMeasurementsDone);
    //Irms0 = 0.0;  // Irms for phase 1
    //Irms1 = 0.0;  // Irms for phase 2
    //Irms2 = 0.0;  // Irms for phase 3
    Irms0 += emon0.calcIrms(1480)*230.0;  // Calculate Irms for phase 1
    Irms1 += emon1.calcIrms(1480)*230.0;  // Calculate Irms for phase 2
    //Irms2 = emon2.calcIrms(1480)*230.0;  // Calculate Irms for phase 3
    lcd.setCursor(0,0);
    lcd.print("                ");
    lcd.setCursor(0,0);
    lcd.print("Total: ");
    lcd.print(Irms0+Irms1);
    lcd.setCursor(10,1);
    lcd.print(numberOfMeasurementsDone);
    numberOfMeasurementsDone++;
    //time = millis();  //Replaced by the RTC
    then = rtc.now();
  delay(450);
  // Modulus of 10 means we send every ten seconds when the second shows 10, 20, 30 etc.
  // The second argument is to ensure that it does not send two times in a row.
  // Since the delay is 450 it can happen that "now.unixtime()" shows the same for two
  // runs of the loop. numberOfMeasurement can only increment one time per second.
  if(now.unixtime() % 10 == 0 && numberOfMeasurementsDone > 3)
    Serial.println("Send: "+getFormatedDateTime());
    long totalEnergyUsed = Irms0 + Irms1; // +Irms2
    // watt-hour = watts * hours
    // KILO watt-hour = (watts * hours) / 1000
    // MOVE TO THE SERVER SIDE? Much easier to do it there.
    // I need to convert double to String to be able to send the info to the server.
    //double kilowatts = (totalEnergyUsed * 0.016666666666) / 1000;
    String data = String("houseId="+houseId+"&timeStamp="+now.unixtime()+"&electricityUsed="+totalEnergyUsed+"&electricityUsedBlib=-1");
    Serial.println("Data: "+data);
    unsigned long t = millis();
    if(client.connect(server,port))
     Serial.println("connected to server");
     client.println("POST /XXXXXXXXXXXXX HTTP/1.1");
     //client.println("Host: www.XXXXXXX.com");
     client.println("Host: XXXXXXXXXXXXXX");
     client.println("Connection: keep-alive");
     client.print("Content-Length: ");
     client.println(data.length());
     client.println("Cache-Control: max-age=0");
     client.println("Content-Type: application/x-www-form-urlencoded");
     client.println("Accept-Language: en-US,en;q=0.8");
     client.println();
     client.print(data);
     client.println();
     Serial.print("Client method time: ");
     Serial.println(millis()-t);
    /* Only for debugging
    while (client.available()) {
     char c = client.read();
     Serial.write(c);
    Irms0 = 0;
    Irms1 = 0;
    Irms2 = 0;
    totalEnergyUsed = 0;
    numberOfMeasurementsDone = 0;
    then = rtc.now();
    Serial.println("Finished send: "+getFormatedDateTime());
In the loop() I take measurement every second using the real time clock to do it accurately. Then every tenth second I send the data to my server.
The WiFi shield takes on average 3 seconds to send the data! I am not sure why it takes so long time. I really thought that in worst case scenario it would take something like 500ms.
When I ping the server it takes on average 28ms.
Is there something I am doing wrong? Have other people also had this experience when sending data to a server?
