I am trying to figure out how to use the pre-loaded example WiFi UDP Send and Receive String
This sketch wait an UDP packet on localPort using a WiFi shield.
When a packet is received an Acknowledge packet is sent to the client on port remotePort
Circuit:
* WiFi shield attached
created 30 December 2012
by dlf (Metodo2 srl)
#include <SPI.h>
#include <WiFi.h>
#include <WiFiUdp.h>
int status = WL_IDLE_STATUS;
char ssid[] = "yourNetwork"; // your network SSID (name)
char pass[] = "secretPassword"; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0; // your network key Index number (needed only for WEP)
unsigned int localPort = 2390; // local port to listen on
char packetBuffer[255]; //buffer to hold incoming packet
char ReplyBuffer[] = "acknowledged"; // a string to send back
WiFiUDP Udp;
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while (true);
String fv = WiFi.firmwareVersion();
if ( fv != "1.1.0" )
Serial.println("Please upgrade the firmware");
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid);
// wait 10 seconds for connection:
delay(10000);
Serial.println("Connected to wifi");
printWifiStatus();
Serial.println("\nStarting connection to server...");
// if you get a connection, report back via serial:
Udp.begin(localPort);
// if there's data available, read a packet
int packetSize = Udp.parsePacket();
if (packetSize)
Serial.print("Received packet of size ");
Serial.println(packetSize);
Serial.print("From ");
IPAddress remoteIp = Udp.remoteIP();
Serial.print(remoteIp);
Serial.print(", port ");
Serial.println(Udp.remotePort());
// read the packet into packetBufffer
int len = Udp.read(packetBuffer, 255);
if (len > 0) packetBuffer[len] = 0;
Serial.println("Contents:");
Serial.println(packetBuffer);
// send a reply, to the IP address and port that sent us the packet we received
Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
Udp.write(ReplyBuffer);
Udp.endPacket();
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
I am new to programming, but have identified one mistake in the preloaded code.
To my understanding this should be
status = WiFi.begin(ssid, pass);
I don't really understand what Receive String is supposed to do, but it gets hung up on
I noticed in the begging of the code that WiFi wasn't highlighted
WiFiUDP Udp;
Where as in all of the coding I have tinkered with to this point list it as
WiFiServer server(80);
Where the WiFi is orange. Can someone lead me in the direction so the library example will work, so I can start to tinker with Send and Receive String commands?
I think the WiFi Chat Server library example may need corrections as well. It will connect and will Serial.print the ip address, but when I type in the ip address to a webbrower it says "unable to connect" where as in the other examples (web client, web server, and simple web server) it connects.
