Hello, I apologize for the delay in responding. I ended up changing the code, and a few things happened that made me modify it (I added the MQTT AWS Amazon IoT to the firmware and created two classes: one for WiFi and one for MQTT). If you can help me, I’d appreciate it.
Here’s the situation: I have two ESP8266 boards (NodeMCU 1.0 - ESP-12E Module; LOLIN (Wemos) D1 R1), and I’m testing the same code on both. The NodeMCU ESP8266 works fine, but the Wemos D1 R1 keeps giving me errors (which I’ll list below). Unfortunately, I’m using a version of the Arduino IDE that doesn’t allow me to use the decoding plugin (I believe that’s what you were asking about). Anyway, I’m having trouble identifying the errors that the Wemos ESP is showing. I have a few suspicions, but I’m not entirely sure what’s really causing the issue.
Whether the ESP8266 boards are different in terms of hardware/firmware since they come from different manufacturers (besides the pinout).
Whether it could be issues with delay() and yield() in the code due to the libraries I’m using (I saw in a forum that some libraries might already have delay and yield programmed, and adding them to the code could cause errors).
Whether the Wemos ESP8266 I’m using has a physical defect (but to confirm that, I’d need to rule out all possible hardware-related causes).
Firmware used on both ESP8266 boards:
#include <ESP8266WiFi.h>
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>
#include <WiFiClientSecure.h>
#include <PubSubClient.h>
#include <ArduinoJson.h>
#include <time.h>
#include "env.h" // Arquivo com certificados
// wifimanager
#define RECONNECT_TIMEOUT 300000 // 5 minutos
// Configurações AWS
const char THINGNAME[] = "basicPubSub";
const char MQTT_HOST[] = "a3ew2u22nso37k-ats.iot.sa-east-1.amazonaws.com";
const char AWS_IOT_PUBLISH_TOPIC[] = "esp8266/pub";
const char AWS_IOT_SUBSCRIBE_TOPIC[] = "esp8266/sub";
const long PUBLISH_INTERVAL = 5000; // Intervalo de publicação
// Estrutura segura para mensagens
struct SafeMessage {
char topic[64];
uint8_t payload[128];
uint16_t length;
volatile bool received;
// classe AWS
class AWSHandler
private:
WiFiClientSecure net;
PubSubClient client;
SafeMessage incomingMsg;
unsigned long lastPublish = 0;
BearSSL::X509List cert;
BearSSL::X509List client_crt;
BearSSL::PrivateKey key;
void NTPConnect() {
configTime(-3 * 3600, 0, "pool.ntp.org", "time.nist.gov"); // Fuso -3h
time_t now = time(nullptr);
while (now < 1510592825) {
void connectAWS() {
if (WiFi.status() != WL_CONNECTED) return;
net.setTrustAnchors(&cert);
net.setClientRSACert(&client_crt, &key);
client.setServer(MQTT_HOST, 8883);
client.setCallback([this](char* topic, byte* payload, unsigned int length) {
if (incomingMsg.received) return;
strncpy(incomingMsg.topic, topic, sizeof(incomingMsg.topic)-1);
length = min(length, sizeof(incomingMsg.payload));
memcpy(incomingMsg.payload, payload, length);
incomingMsg.length = length;
incomingMsg.received = true;
while (!client.connect(THINGNAME)) {
Serial.print(".");
client.subscribe(AWS_IOT_SUBSCRIBE_TOPIC);
Serial.println("\nAWS IoT Connected!");
public:
AWSHandler() :
cert(cacert),
client_crt(client_cert),
key(privkey),
client(net)
incomingMsg.received = false;
void begin() {
net.setBufferSizes(1024, 512);
NTPConnect();
if (!client.connected()) {
connectAWS();
client.loop();
// Publicação periódica
if (millis() - lastPublish >= PUBLISH_INTERVAL) {
publishMessage();
lastPublish = millis();
// Processamento seguro de mensagens
if (incomingMsg.received) {
Serial.print("[AWS] Received: ");
Serial.write(incomingMsg.payload, incomingMsg.length);
void publishMessage() {
StaticJsonDocument<200> doc;
doc["heap"] = ESP.getFreeHeap(); // Inclui memória livre
doc["rssi"] = WiFi.RSSI();
doc["ssid"] = WiFi.SSID();
char jsonBuffer[200];
serializeJson(doc, jsonBuffer);
client.publish(AWS_IOT_PUBLISH_TOPIC, jsonBuffer);
Serial.printf("[AWS] Published: %s\n", jsonBuffer);
AWSHandler awsHandler; // Instância global
// Classe WiFiManager
class WiFiHandler
private:
WiFiManager wifiManager;
unsigned long lastReconnectAttempt = 0;
bool portalActive = false;
void connectToWiFi() {
Serial.println("\nConectando à WiFi...");
if (wifiManager.autoConnect("ESP-Config")) {
connectionSuccessful();
handleConnectionFailure();
void connectionSuccessful() {
Serial.println("\nConectado com sucesso!");
Serial.print("SSID: "); Serial.println(WiFi.SSID());
Serial.print("IP: "); Serial.println(WiFi.localIP());
Serial.print("RSSI: "); Serial.print(WiFi.RSSI()); Serial.println(" dBm");
void handleConnectionFailure() {
Serial.println("\nFalha na conexão WiFi");
if (portalActive) Serial.println("Timeout do portal de configuração");
lastReconnectAttempt = millis();
public:
void begin() {
while (!Serial) delay(10);
wifiManager.setDebugOutput(true);
wifiManager.setConnectTimeout(30);
wifiManager.setConfigPortalTimeout(180);
wifiManager.setAPCallback([this](WiFiManager *wm) {
Serial.println("\n--- MODO CONFIGURAÇÃO ATIVO ---");
Serial.print("SSID: "); Serial.println(wm->getConfigPortalSSID());
Serial.print("IP: "); Serial.println(WiFi.softAPIP());
portalActive = true;
Serial.println("\nComandos: 'r' (Reset), 'c' (Configuração)");
connectToWiFi();
awsHandler.begin(); // Inicia AWS apos conexao WiFi
if (Serial.available()) handleSerialCommand(Serial.read());
if (WiFi.status() != WL_CONNECTED && !portalActive &&
(millis() - lastReconnectAttempt > RECONNECT_TIMEOUT)) {
Serial.println("\nTentando reconexão automática...");
connectToWiFi();
awsHandler.loop(); // Mantém conexão AWS
yield(); // Previne WDT reset
void handleSerialCommand(char cmd) {
switch(cmd) {
case 'r':
Serial.println("\nResetando configurações WiFi...");
wifiManager.resetSettings();
Serial.println("Reiniciando...");
ESP.restart();
case 'c':
Serial.println("\nForçando modo configuração...");
startPortal();
default:
void startPortal() {
Serial.println("\nIniciando portal de configuração");
if (!wifiManager.startConfigPortal("ESP-Config")) {
Serial.println("Portal falhou! Reiniciando...");
ESP.restart();
WiFiHandler wifiHandler; // Instância global única
wifiHandler.begin();
static unsigned long lastCheck = 0;
if (millis() - lastCheck >= 5000)
{ // Verifica a cada 5 segundos
lastCheck = millis();
Serial.printf("Memória livre: %d bytes\n", ESP.getFreeHeap());
wifiHandler.loop();
Error messages on the ESP8266 (Wemos D1 R1):
*wm:Connect to new AP [SUCCESS]
*wm:Got IP Address:
*wm:10.156.4.211
*wm:config portal exiting
Successfully connected!
SSID: GalaxyA21sHS
IP: 10.156.4.211
RSSI: -47 dBm
Free memory: 34688 bytes
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Exception (3):
epc1=0x4022dadb epc2=0x00000000 epc3=0x00000000 excvaddr=0x4022daa0 depc=0x00000000
>>>stack>>>
ctx: bearssl
sp: 3fff1610 end: 3fff1ae0 offset: 0150
3fff1760: 63617465 20417574 686f7269 7479202d
3fff1770: 20473230 1e170d31 35303532 35313230
3fff1780: 3030305a 170d3337 31323331 30313030
3fff1790: 30305a30 39310b30 09060355 04061302
3fff17a0: ed46b013 209b565e 433e089b 0f5acd1b
3fff17b0: c178cc13 d5cb2cfb e3325842 d4c0af41
3fff17c0: d7dfe1e4 85518af1 77f24fa2 569c0aa1
3fff17d0: 99cc5dfb cc5c183e 0373cea5 01883dbc
3fff17e0: 7ee50c69 6ebef6c7 46336d18 5b71388f
3fff17f0: 8f3f9209 a4302dac d302b120 921dfc47
3fff1800: e63c7f17 e70de4d2 ce8af5dd 281b7e3f
3fff1810: c4800ff0 29f31fc4 13263d6d 7210ddff
3fff1820: 7dce4c4d 95b2db16 b9fa61e0 3d3a2c02
3fff1830: 7cba3409 0272ea50 8424af5d 651cf4f4
3fff1840: fe6ef47a a54178b4 552f7063 3320795f
3fff1850: 67b815e9 ecb8d6b9 49276996 47ee2827
3fff1860: e0aad526 3fff1760 2db879e6 40268218
3fff1870: 3fff1960 14895026 8cc70208 90befffa
3fff1880: a4506ceb bef9a3f7 c67178f2 3fff1860
3fff1890: d519670d dcbff8f2 aad78aa7 088c937b
3fff18a0: 534d6c16 bee91d4d 690cdb72 189737cb
3fff18b0: 18163071 c73bb62a 3fff1960 65014886
3fff18c0: 02020403 48866009 04036501 00000000
3fff18d0: 00000040 3fff4e2c 00000040 4022df90
3fff18e0: 3fff1914 3fff1960 00000000 3fff1910
3fff18f0: 00000c80 00000000 13e1a68d 3fff4dec
3fff1900: 3fff4f68 3fff4eb8 00000004 4023c448
3fff1910: 00000000 65746163 74754120 69726f68
3fff1920: 2d207974 30324720 310d171e 32353035
3fff1930: 30323135 5a303030 37330d17 31333231
3fff1940: 30303130 305a3030 300b3139 55030609
3fff1950: 02130604 20646c65 00000d00 00000000
3fff1960: df77890d 8c9cd7e1 6003dd94 907350dc
3fff1970: 2d6f5113 87818dd0 528e85a9 558684ce
3fff1980: 69767265 20736563 746f6f52 72654320
3fff1990: 69666974 deadbeef 00000c80 00000000
3fff19a0: caacff90 ca77e2ab 035c8b0b 4a346b71
3fff19b0: 369ef18c 98b77fe4 bd5370c8 f0b96139
3fff19c0: 00769d3a bf2b11e8 5e0b44bf 82a9db92
3fff19d0: 8d8de1a1 b8523372 9b29e5c7 4989b400
3fff19e0: 3fff2d8e 000000c7 402680e0 deadbeef
3fff19f0: deadbeef 3fff4885 3fff594c 3fff4ae4
3fff1a00: 000008f0 3fff4dc0 3fff4ac0 40231184
3fff1a10: deadbeef deadbeef deadbeef deadbeef
3fff1a20: 402683e1 deadbeef deadbeef deadbeef
3fff1a30: deadbeef deadbeef deadbeef deadbeef
3fff1a40: deadbeef deadbeef deadbeef deadbeef
3fff1a50: deadbeef deadbeef 40268a5c deadbeef
3fff1a60: 3fff42dc 3fff4b70 3fff4ae0 3fff4adc
3fff1a70: deadbeef deadbeef 3fff42c0 00000100
3fff1a80: 00000100 deadbeef deadbeef deadbeef
3fff1a90: deadbeef deadbeef deadbeef 3fff4ddc
3fff1aa0: 00000430 3fff4cdc 3fff42dc 4022f78c
3fff1ab0: 3fff4ac0 deadbeef 3fff42dc 4022fb79
3fff1ac0: 000000fa deadbeef deadbeef 3ffef480
3fff1ad0: 00003a98 00000000 3fff01d4 402026c8
ctx: cont
sp: 3ffffe20 end: 3fffffd0 offset: 0000
3ffffe20: 00003a98 00000000 00000000 40205c92
3ffffe30: 00000540 3fff4cdc 3fff42dc 4022f78c
3ffffe40: 00000008 00000001 0000b3ba 00000000
3ffffe50: 3fff47dc 402308e4 3fff42dc 00000000
3ffffe60: 3fff47dc 3ffe8b20 3fff42dc 3ffe8b20
3ffffe70: 00000000 00000001 3fff01d4 40205ce7
3ffffe80: 00000000 00000001 3fff01d4 40205ed3
3ffffe90: 00000000 0000b2ee 40c49ba5 00cee37a
3ffffea0: 00000000 00000000 00000034 0000b2ee
3ffffeb0: 00003a98 3fff3ffc 3fff1e08 40204fe7
3ffffec0: 3fff42dc 3ffffefd 3ffef408 40214830
3ffffed0: 1cc2e184 00000008 3ffef028 3ffef290
3ffffee0: 000022b3 3ffe8b20 3fff01d4 40205f75
3ffffef0: 40217cc4 2ced8c03 40217cc4 2ced8c03
3fffff00: 00000000 00000000 00000000 4020f398
3fffff10: c36d654d 616972b3 76696c20 203a6572
3fffff20: 00000000 3ffe8b4e 00000000 00000000
3fffff30: 00000001 3ffef290 3ffef2b4 4020f640
3fffff40: 00000000 00000000 00000000 3ffef5e4
3fffff50: 3fffdad0 3ffef290 3ffef408 4020f584
3fffff60: 00000000 00000000 00000001 4020f682
3fffff70: 402612fb 3ffef290 3ffef268 4020152e
3fffff80: 3ffef268 40204220 40216a70 4020109c
3fffff90: 3fff54dc 3ffef290 3ffef268 4020245c
3fffffa0: 3fffdad0 3ffef408 3ffef02c 4020259f
3fffffb0: feefeffe 00000000 3ffef5b8 402137fc
3fffffc0: feefeffe feefeffe 3fffdab0 40100e89
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 3424, room 16
tail 0
chksum 0x2e
load 0x3fff20b8, len 40, room 8
tail 0
chksum 0x2b
csum 0x2b
v000759e0
~ld
����g��s��g|�l�d`c��|s�d�'��n�$`��s�l�le��*wm:v2.0.17 D:2
Commands: ‘r’ (Reset), ‘c’ (Configuration)
Connecting to WiFi...
*wm:AutoConnect
*wm:Connecting to SAVED AP: GalaxyA21sHS
*wm:AutoConnect: SUCCESS
*wm:STA IP Address: 10.156.4.211
SSID: GalaxyA21sHS
IP: 10.156.4.211
RSSI: -46 dBm
AWS IoT Connected!
[AWS] Published: {"heap":31496,"rssi":-49,"ssid":"GalaxyA21sHS"}
Memória livre: 31384 bytes
[AWS] Published: {"heap":30992,"rssi":-49,"ssid":"GalaxyA21sHS"}
Memória livre: 30992 bytes
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
tail 0
chksum 0x2e
tail 0
chksum 0x2b
csum 0x2b
v000759e0
~ld
���e�g�s��n|�$�l`c��|s�d�g��'�d`��r�l�d��*wm:v2.0.17 D:2
*wm:AutoConnect
SSID: GalaxyA21sHS
IP: 10.156.4.211
RSSI: -48 dBm
AWS IoT Connected!
[AWS] Published: {"heap":30824,"rssi":-48,"ssid":"GalaxyA21sHS"}
Memória livre: 30320 bytes
[AWS] Published: {"heap":30320,"rssi":-49,"ssid":"GalaxyA21sHS"}
Memória livre: 30768 bytes
[AWS] Published: {"heap":30992,"rssi":-50,"ssid":"GalaxyA21sHS"}
[AWS] Published: {"heap":30992,"rssi":-48,"ssid":"GalaxyA21sHS"}
Exception (0):
epc1=0x40204b06 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3ffffd90 end: 3fffffd0 offset: 0150
3ffffee0: 00000411 0000012c 3fff307c 3fff1b04
3ffffef0: 00000000 00000000 3fff01d4 3fff1b04
3fffff00: 00000000 00000002 3fff01d4 40206238
3fffff10: 00000200 00000000 3fff01d4 40205fe7
3fffff20: 00000000 00000002 16872b02 01034a1a
3fffff30: 00000010 3ffef290 3ffef290 3ffef5e4
3fffff40: 00000001 0000e040 3ffef290 4020f190
3fffff50: 00000000 3fffff60 00000008 3ffef5e4
3fffff60: 00000000 00000000 3fff01d4 40205fe7
3fffff70: 402612fb 3ffef290 00000000 40205470
3fffff80: 3ffefedc 3ffef290 3ffef268 3ffef5e4
3fffff90: 3fffdad0 3ffef290 3ffef268 40202461
3fffffb0: 00000000 00000000 3ffef5b8 402137fc
<<<stack<<<
wdt reset
tail 0
chksum 0x2e
RSSI: -45 dBm
Exception (0):
epc1=0x4022c9b6 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
>>>stack>>>
ctx: bearssl
sp: 3fff17c0 end: 3fff1ae0 offset: 0150
3fff1910: 00000000 ce1ef0cc 3ba41873 66ce78f0
3fff1920: 694dd5a3 5036a2ce b79d0127 c39aefab
3fff1930: b8f792f2 b6a4058d 3232bc70 e9126012
3fff1940: ad003a89 27fd4b58 7e984076 81cf2574
3fff1950: e61c99ed 978215d3 00000700 00000000
3fff1960: ac788939 32ed7d75 c1257f21 6548a489
3fff1970: 67793332 c7791003 dd016393 9245af2a
3fff1980: dff0d42a 5f0bcd2b 211d62ac 150be6ad
3fff1990: ed6e014a deadbeef 00000680 00000000
3fff19a0: e7a42dc7 ba172931 cdaa8514 f5e3af58
3fff19b0: 843ee104 72fccdaf cad28874 b6b03291
3fff19c0: e332d235 4c0b529f 9991945c 16716b1e
3fff19d0: 2c347511 f719e5ae 474c43ed ab16799a
3fff19e0: 3fff3e49 0000005a 40267dc0 deadbeef
3fff19f0: deadbeef 3fff3625 3fff45ac 3fff3884
3fff1a00: 00000926 3fff3b60 3fff3860 40231184
3fff1a20: 402684b2 deadbeef deadbeef deadbeef
3fff1a60: 3fff307c 3fff3910 3fff3880 3fff387c
3fff1a70: deadbeef deadbeef 3fff3060 000000ca
3fff1a80: 000000ca deadbeef deadbeef deadbeef
3fff1a90: deadbeef deadbeef deadbeef 3fff3b7c
3fff1aa0: 00000103 3fff3a7c 3fff307c 4022f78c
3fff1ab0: 3fff3860 deadbeef 3fff307c 4022fb79
ctx: cont
3ffffe30: 00000540 3fff3a7c 3fff307c 4022f78c
3ffffe40: 00000008 00000001 00000bce 00000000
3ffffe50: 3fff357c 402308e4 3fff307c 00000000
3ffffe60: 3fff357c 3ffe8b20 3fff307c 3ffe8b20
3ffffe90: 00000000 00000af1 eb020c49 000ca7b7
3ffffea0: 00000000 00000000 00000034 00000af1
3ffffeb0: 00003a98 3fff2e7c 3fff1e08 40204fe7
3ffffec0: 3fff307c 3ffffefd 3ffef408 40214830
3ffffed0: 2265bddd 00063c15 000f4240 3ffef290
3ffffef0: 40217cc4 7a4d7612 40217cc4 7a4d7612
3fffff10: 00005bdd 000c27f1 3ffef5bc 0000f424
3fffff90: 3ffefedc 3ffef290 3ffef268 4020245c
<<<stack<<<
wdt reset
tail 0
chksum 0x2e
tail 0
chksum 0x2b
csum 0x2b
v000759e0
~ld
���e�n�{��o<�$�l`c��|;�l�n��o�l`��s�l�le��*wm:v2.0.17 D:2
*wm:AutoConnect
SSID: GalaxyA21sHS
IP: 10.156.4.211
RSSI: -46 dBm
AWS IoT Connected!
[AWS] Published: {"heap":31496,"rssi":-48,"ssid":"GalaxyA21sHS"}
