Wifinina udp.read ließt nur 64 Bytes anstatt 255
Hallo zusammen,
ich habe einen Arduino Uno Wifi Rev 2 und benutze das Wifinina Example "WifiUdpSendReceiveString".
  WiFi UDP Send and Receive String
 This sketch wait an UDP packet on localPort using the WiFi module.
 When a packet is received an Acknowledge packet is sent to the client on port remotePort
 created 30 December 2012
 by dlf (Metodo2 srl)
#include <SPI.h>
#include <WiFiNINA.h>
#include <WiFiUdp.h>
int status = WL_IDLE_STATUS;
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID;        // your network SSID (name)
char pass[] = SECRET_PASS;    // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0;            // your network key Index number (needed only for WEP)
unsigned int localPort = 2390;      // local port to listen on
char packetBuffer[256]; //buffer to hold incoming packet
char  ReplyBuffer[] = "acknowledged";       // a string to send back
WiFiUDP Udp;
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
    Serial.println("Please upgrade the firmware");
  // attempt to connect to Wifi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  Serial.println("Connected to wifi");
  printWifiStatus();
  Serial.println("\nStarting connection to server...");
  // if you get a connection, report back via serial:
  Udp.begin(localPort);
  // if there's data available, read a packet
  int packetSize = Udp.parsePacket();
  if (packetSize) {
    Serial.print("Received packet of size ");
    Serial.println(packetSize);
    Serial.print("From ");
    IPAddress remoteIp = Udp.remoteIP();
    Serial.print(remoteIp);
    Serial.print(", port ");
    Serial.println(Udp.remotePort());
    // read the packet into packetBufffer
    int len = Udp.read(packetBuffer, 255);
    if (len > 0) {
      packetBuffer[len] = 0;
    Serial.println("Contents:");
    Serial.println(packetBuffer);
    // send a reply, to the IP address and port that sent us the packet we received
    Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
    Udp.write(ReplyBuffer);
    Udp.endPacket();
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
Im Packetbuffer werden egal wie groß er ist, nur 64 Byte vom empfangenen String gespeichert.
Wobei im Beispiel von Anfang an 256 Byte verwendet werden.
Liegt das an meinem Netzwerk, dass nicht mehr ankommt, oder ist da ein Fehler drin?
Viele Grüße
Hat sich das Ding am Router angemeldet zeigt zugewiesene IP?
wird Fehlerfrei kompiliert keine Warnungen?
Das kommt im Seriellen Monitor an:
16:04:05.999 -> Attempting to connect to SSID: FRITZ!Box 7590 SC
16:04:17.237 -> Connected to WiFi
16:04:17.284 -> SSID: FRITZ!Box 7590 SC
16:04:17.284 -> IP Address: 192.168.178.57
16:04:17.331 -> signal strength (RSSI):-45 dBm
16:04:17.378 ->
16:04:17.378 -> Starting connection to server...
16:04:27.479 -> Received packet of size 681
16:04:27.526 -> From 192.168.178.20, port 63741
16:04:27.573 -> Contents:
16:04:27.573 -> {"MessageType":"Event","MessageVerb":"Shot","Sequential":true,"R
Und so würde der String weitergehen:
{"MessageType":"Event","MessageVerb":"Shot","Sequential":true,"Ranges":1,"Objects":[....
Eine Warnung kommt nach dem kompilieren:
avrdude: WARNING: invalid value for unused bits in fuse "fuse5", should be set to 1 according to datasheet
Das kann bei einem Puffer von 256 Byte schon mal nicht zusammen passen.
Wer sendet das UDP-Paket und wie lang ist es real?
Gruß Tommy
Real sind es 1058 Zeichen und wird von einer Software als JSON-Broadcast gesendet.
Selbst wenn der Puffer größer ist, kommen nur die 64 Zeichen an.
Ich habe auch mit der Software "PacketSender" einen String geschickt, hier werden ebenfalls längere Pakete nach 64 Zeichen abgeschnitten.
Ich vermute Dir geht irgendwas zu Ende...
Mach mal den Buffer ab 64 bytes aufwärts Stück für Stück größer. Ab wann gehts nicht mehr?
Ab 64 Byte ist Ende mit 65 steht genauso viel drin wie mit 64. Mit 63 fehlt dann das letzte Zeichen:
17:01:01.621 -> {"MessageType":"Event","MessageVerb":"Shot","Sequential":true,"
Egal wie, die falsche Anzahl bei der Paketlänge deutet auf ein grundlegendes Problem (evtl. in der WiFiNina-Firmware) hin, ich setze sie selbst nicht ein, kann dazu also keine Erfahrung mitteilen.
Und einen Payload von 1058 Zeichen kannst Du nicht mit einem Puffer von 256 empfangen.
Was passiert, wenn Du mit dem Paketsender 50 Bytes überträgst? Wird dann die richtige Länge angezeigt? Wenn ja, dann erhöhe die Länge schrittweise, bis die Länge falsch wird bzw. der Text abgeschnitten wird.
Gruß Tommy
Las Dir mal len ausgeben.
    Serial.print("Länge: "); Serial.println(len);
Nicht das Du da irgendwo ein \0 drin hast.
@Tommy56 Das Paket ist größer als der Inhalt - da gehört noch so ein wenig Header etc. dazu.,.,
Da ist die Länge 64
17:27:35.178 -> Starting connection to server...
17:27:40.075 -> Received packet of size 687
17:27:40.122 -> From 192.168.178.20, port 55223
17:27:40.170 -> Länge: 64
17:27:40.170 -> Contents:
17:27:40.170 -> {"MessageType":"Event","MessageVerb":"Shot","Sequential":true,"R
Deshalb habe ich ja vorgeschlagen bei einer Payload-Länge von 50 zu beginnen, damit die 8 Headerbytes noch mit rein passen.
Gruß Tommy
Also wenn ich 50 Bytes verschicke kommen auch 50 an, bis ich 65 verschicke dann kommen 64 an.
Und Received packet size wird wie groß?
Pardon ich habe 49 verschickt, aber auch die Packetsize ist dann 49. Und wenn ich 65 verschicke ist die Packetsize auch 65 aber nur 64 werden angezeigt. Bei 63 kommen 63 an und 63 ist die Packetsize.
17:35:26.061 -> Received packet of size 49
17:35:26.107 -> From 192.168.178.20, port 50786
17:35:26.154 -> Länge: 49
17:35:26.154 -> Contents:
17:35:26.154 -> {"MessageType":"Event","MessageVerb":"Shot","Sequ
17:35:53.933 -> Received packet of size 65
17:35:53.933 -> From 192.168.178.20, port 50786
17:35:53.979 -> Länge: 64
17:35:53.979 -> Contents:
17:35:54.026 -> {"MessageType":"Event","MessageVerb":"Shot","Sequential":true,"R
17:37:27.157 -> Received packet of size 63
17:37:27.157 -> From 192.168.178.20, port 50786
17:37:27.204 -> Länge: 63
17:37:27.204 -> Contents:
17:37:27.204 -> {"MessageType":"Event","MessageVerb":"Shot","Sequential":true,"
Ich glaube noch immer, das nach 64bytes ein \0 oder anderes Control drin ist, was das Ende der Übernahme des Inhaltes bewirkt oder das payload dort zwangsgetrennt wird.
Die Größe wird ja richtig erkannt, der Inhalt verworfen.
Wie sieht das denn auf der Senderseite Codemäßig aus?
Ich finde eher die falsche Paketlänge von Udp.parsePacket(); im #3 merkwürdig.
Wenn Du Steuerzeichen vermutest, hilft eigentlich nur die HEX-Ausgabe.
Gruß Tommy
Der String wird aus einer Software herausgesendet, da habe ich keinen Zugriff auf den Code.
Die Versuche habe ich aus der Software "PacketSender" verschickt.
Und die großen Packets wurden aus der eigentlichen Software, die den JSON-Broadcast als Schnitstelle verwendet, gesendet.
Hier habe ich 123 mal die "1" versendet.
Dazu der Hex Code:
31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31
17:51:16.595 -> Received packet of size 123
17:51:16.595 -> From 192.168.178.20, port 50786
17:51:16.642 -> Länge: 64
17:51:16.642 -> Contents:
17:51:16.689 -> 1111111111111111111111111111111111111111111111111111111111111111
Kannst Du mal was probieren? - Teil ersetzen:
    if (len > 0)
      for (byte b = 0; b < packetsize - 1; b++)
        Serial.print(packetBuffer[b], HEX); Serial.print(' ');
      if (b % 8 == 0) Serial.println();
Und dann sende mal deine 123 einsen.
ok jetzt kommen wir der Sache näher.
18:21:27.960 -> Received packet of size 115
18:21:28.008 -> From 192.168.178.20, port 50786
18:21:28.055 -> Contents:
18:21:28.055 -> 3131313131313131313131313131313131313131313131313131313131313131313131313131313131313131313131313131313131313131313131313131313100000000000000000000000000000000000000000000000000
18:21:28.242 -> 1111111111111111111111111111111111111111111111111111111111111111
