I am running WiFiServer & WiFiClient on a Arduino WiFi Rev2. After a day or more, the web server becomes unresponsive, causing an ERR_EMPTY_RESPONSE on my Chrome browser. Tracing the Ethernet traffic, I can see that Arduino accepts the tcp connection, and acknowledges my "GET /" http request, but immediately after this closes the tcp connection with a FIN packet.
Anybody out there also having stability problems with WiFiServer ?
I initially thought that the USB connection would provide a good debug backdoor to my Arduino, but when I plug-in a USB cable to my hanging Arduino and connect it to the web-based Arduino Editor, the Arduino is reset when I start the Monitor. Also Monitor data is often garbled (suspect bad USB driver on pc, since garbling requires a pc reboot to be fixed).
Does anybody have an idea how I can establish a backdoor to my hanging Arduino, to tweak out some data from it ?
#include "DHT.h"
#include <WiFiNINA.h>
#define DHTPIN 2 // Digital pin connected to the DHT sensor
#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
DHT dht(2, DHT22);
char ssid[] = "home_network"; // your network SSID (name) between the " "
char pass[] = "password"; // your network password between the " "
int status = WL_IDLE_STATUS; //connection status
WiFiServer server(80); //server socket
WiFiClient client = server.available();
int ledPin = 2;
int statHttpRequests = 0;
int statSensorOk = 0;
int statSensorZero = 0;
int statSensorError = 0;
int statWifiReconnects = 0;
long unsigned statLoopCnt = 0;
long unsigned statLoopCntHigh = 0;
long unsigned watchdogCnt = 0;
void resetFunc() { asm volatile ("jmp 0"); }
void printStatus() {
client.print("<br>http_request ");
client.print(statHttpRequests);
client.print("<br>sensor_ok ");
client.println(statSensorOk);
client.print("<br>sensor_zero ");
client.println(statSensorZero);
client.print("<br>sensor_err ");
client.println(statSensorError);
client.print("<br>wifi_rssi ");
client.print(WiFi.RSSI());
client.print("dBm<br>");
client.print("wifi_reconnects ");
client.print(statWifiReconnects);
client.print("<br>statLoopCnt ");
client.print(statLoopCnt);
void printHumTemp() {
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
float t = dht.readTemperature();
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t)) {
statSensorError++;
client.println("sensor1 ?? ??");
// The 'F' macro moves the constant string from the 6KB ram to the 48KB flash
Serial.println(F("Warning: failed to read from DHT sensor"));
return;
} else if (h == 0.0 || t == 0.0) {
statSensorZero++;
statSensorOk++;
// Rendering of html removes multiple spaces.
client.print("sensor1 ");
client.print(h, 1);
client.print("%RH ");
client.print(t, 1);
client.println("degC<br>");
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
Serial.print("To see this page in action, open a browser to http://");
Serial.println(ip);
void webWifiStatus () {
// same as 'printWifiStatus' but as a web line
client.print("SSID ");
client.println(WiFi.SSID());
client.print("RSSI ");
client.print(rssi);
client.println(" dBm");
void enable_WiFi() {
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
String fv = WiFi.firmwareVersion();
if (fv < "1.0.0") {
Serial.println("Please upgrade the firmware");
void connect_WiFi() {
// attempt to connect to Wifi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
void printWEB() {
if (client) { // if you get a client,
Serial.println("---------- Received from browser client: -----------------");
statHttpRequests++;
String currentLine = "";
String httpGetLine = "";
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c); // echo http request on terminal
if (c != '\n' && c != '\r')
currentLine += c;
if (c == '\n') {
if (currentLine.startsWith("GET "))
httpGetLine = currentLine;
if (currentLine.length() == 0) {
// got a blank line meaning http request header is done, and we can send a http response
if (httpGetLine.startsWith("GET / ")) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println();
printHumTemp();
printStatus();
//client.println("</body></html>");
else {
// GET on anything else than '/' is not supported. This was a bug with the original web server code, where the browser
// would also request some icon file, causing the web server to resend the page
client.println("HTTP/1.1 404 Not Found");
client.println();
// The http request header was processed and a response was sent. Now exit the request-reading loop
currentLine = "";
} // done processing http request header line
} // done processing http character
// close tcp connection:
client.stop();
Serial.println("Info: browser client link closed");
pinMode(ledPin, OUTPUT);
while (!Serial);
enable_WiFi();
connect_WiFi();
server.begin();
printWifiStatus();
dht.begin();
// 1372 count/second
statLoopCnt++;
watchdogCnt++;
if (statLoopCnt == 0) {
statLoopCntHigh++;
// Reset if no web requests has been received for 2 hours. Observed that Arduino web server would stop working,
// for unknown reason. ping showed that WiFi connection was working.
if (watchdogCnt > 1372*60*60*2) {
resetFunc();
if (client) {
watchdogCnt = 0;
printWEB();
status = WiFi.status();
if (status != WL_CONNECTED) {
Serial.print("Wifi connection lost, WiFi.status = ");
Serial.println(WiFi.status());
statWifiReconnects++;
connect_WiFi();
printWifiStatus();
