WiFly Httpget
I bought bad wifi shield from seedstudio, shield with rn-171 model named WLS06201P
I wanted to try send multiple http get parameters but fails. I need a help. Maybe somebody knows how this bad shield work
when I run this code below, I am opening serial monitor and only I see "Failed to parse URL" and "Path buffer is too small"
#include <Arduino.h>
#include <SoftwareSerial.h>
#include <WiFly.h>
#include "HTTPClient.h"
#define SSID "Your-SSID"
#define KEY "passphrase"
// WIFLY_AUTH_OPEN / WIFLY_AUTH_WPA1 / WIFLY_AUTH_WPA1_2 / WIFLY_AUTH_WPA2_PSK
#define AUTH WIFLY_AUTH_WPA2_PSK
#define HTTP_GET_URL "http://myserver.com/workingservice.aspx?sectiona=12345&sectionb=98765"
// Pins' connection
// Arduino WiFly
// 2 <----> TX
// 3 <----> RX
WiFly wifly(2, 3);
HTTPClient http;
char get;
Serial.println("------- WIFLY HTTP --------");
// Wait WiFly to init
// delay(3000);
wifly.reset();
while (1) {
Serial.println("Try to join " SSID );
if (wifly.join(SSID, KEY, AUTH)) {
Serial.println("Succeed to join " SSID);
wifly.clear();
Serial.println("Failed to join " SSID);
Serial.println("Wait 1 second and try again...");
Serial.println("\r\nTry to get url - " HTTP_GET_URL);
Serial.println("------------------------------");
while (http.get(HTTP_GET_URL, 10000) < 0) {
while (wifly.receive((uint8_t *)&get, 1, 1000) == 1) {
Serial.print(get);
int c;
while (wifly.available()) {
c = wifly.read();
if (c > 0) {
Serial.write((char)c);
while (Serial.available()) {
c = Serial.read();
if (c >= 0) {
wifly.write((char)c);
if I change the
to
#define HTTP_GET_URL "http://myserver.com/workingservice.aspx?sectiona=1234&sectionb=98"
the code is working. What the hell is this I dont know :frowning:
is there anybody for fix this problem ?
Maybe I must change something in cpp file ?
#include <string.h>
#include "Debug.h"
HTTPClient::HTTPClient()
wifly = WiFly::getInstance();
int HTTPClient::get(const char *url, int timeout)
return connect(url, "GET", NULL, NULL, timeout);
int HTTPClient::get(const char *url, const char *headers, int timeout)
return connect(url, "GET", headers, NULL, timeout);
int HTTPClient::post(const char *url, const char *data, int timeout)
return connect(url, "POST", NULL, data, timeout);
int HTTPClient::post(const char *url, const char *headers, const char *data, int timeout)
return connect(url, "POST", headers, data, timeout);
int HTTPClient::connect(const char *url, const char *method, const char *data, int timeout)
return connect(url, method, NULL, data, timeout);
int HTTPClient::connect(const char *url, const char *method, const char *headers, const char *data, int timeout)
char host[HTTP_MAX_HOST_LEN];
uint16_t port;
char path[HTTP_MAX_PATH_LEN];
if (parseURL(url, host, sizeof(host), &port, path, sizeof(path)) != 0) {
DBG("Failed to parse URL.\r\n");
return -1;
if (!wifly->connect(host, port, timeout)) {
DBG("Failed to connect.\r\n");
return -2;
// Send request
char buf[HTTP_MAX_BUF_LEN];
snprintf(buf, sizeof(buf), "%s %s HTTP/1.1\r\n", method, path);
wifly->send(buf);
// Send all headers
snprintf(buf, sizeof(buf), "Host: %s\r\nConnection: close\r\n", host);
wifly->send(buf);
if (data != NULL) {
snprintf(buf, sizeof(buf), "Content-Length: %d\r\nContent-Type: text/plain\r\n", strlen(data));
wifly->send(buf);
if (headers != NULL) {
wifly->send(headers);
// Close headers
wifly->send("\r\n");
// Send body
if (data != NULL) {
wifly->send(data);
return 0;
int HTTPClient::parseURL(const char *url, char *host, int max_host_len, uint16_t *port, char *path, int max_path_len)
char *scheme_ptr = (char *)url;
char *host_ptr = (char *)strstr(url, "://");
if (host_ptr != NULL) {
if (strncmp(scheme_ptr, "http://", 7)) {
DBG("Bad scheme\r\n");
return -1;
host_ptr += 3;
host_ptr = (char *)url;
int host_len = 0;
char *port_ptr = strchr(host_ptr, ':');
if (port_ptr != NULL) {
host_len = port_ptr - host_ptr;
port_ptr++;
if (sscanf(port_ptr, "%hu", port) != 1) {
DBG("Could not find port.\r\n");
return -3;
*port = HTTP_DEFAULT_PORT;
char *path_ptr = strchr(host_ptr, '/');
if (host_len == 0) {
host_len = path_ptr - host_ptr;
if (max_host_len < (host_len + 1)) {
DBG("Host buffer is too small.\r\n");
return -4;
memcpy(host, host_ptr, host_len);
host[host_len] = '\0';
int path_len;
char *fragment_ptr = strchr(host_ptr, '#');
if (fragment_ptr != NULL) {
path_len = fragment_ptr - path_ptr;
path_len = strlen(path_ptr);
if (max_path_len < (path_len + 1)) {
DBG("Path buffer is too small.\r\n");
return -5;
memcpy(path, path_ptr, path_len);
path[path_len] = '\0';
return 0;
