Will it work? I,m currently working on TP4056 as Proto shiled for my GIGA
Will it work? assume so pin 1 of DW ic is connected to pin 4 od AD ic ( pcb is connected but for some weird reason kicad doesn't show that ?
Depends what you mean by work. If you are trying to build your own charge ONLY board then maybe but if it's more than that then probably not.
A description of what you are trying to do and what you expect is needed as well as what actually happens.
Great you posted a schematic but I cannot follow it. Wires going into the side of R5 and stopping. R7 not sure what is happening? Why are you using a negative supply?
Ohh sorry the -5V should be GND as it is supposed to go into GHD pin of giga , also my plan for this pcb is to be a normal tp 4056 charger but with more outputs ,
The wires going into R5 are then coming out of it to screw terminal to be a negative connection for battery
clean version
It's very dificult to follow.
Don't put text on top of symbols or wires.
Don't run wires through symbols.
Use the ground symbol to connect componets to ground.
DON'T use the ground symbol for connections to anything but ground.
Place component values on schematic.
Spend some time learning how to use your CAD software, it will save you time and money in the long run.
Did you run DRC?
Looking at J2 and J3 you have pin 1 connected to in 1 but why the extra wires, one would suffice, makes it much less complicated to follow. Looking in the area of D2 R2 it is hard to determine what is what.
Not to worry you will get it there and it will work as designed.
Hi, @lionardo2137
Is C2 in the correct way around?
Please edit your schematic to move text into clear areas and do not place wires running through component symbols.
Thanks. Tom.... :smiley: :+1: :coffee: :australia:
