Will this Circuit Work as an Analog Output? <SOLVED>
Hello
I have an opto-isolator driven by PWM which is smoothed out by a low pass filter. The high voltage side of the isolator
is tied to a separate 10 VDC power supply. I'm attempting to modulate a proportional Belimo actuator from the high voltage
side of the opto-isolator. The funny thing is, when no load is connected to the output of the opto-isolator the output is linear to the input signal. For example 2.5VDC input from the UNO equals 5 volts. The problem is, any time the actuator is connected, my voltage drops dramatically.
Is the load on the isolator to much causing a voltage drop?
Hopefully a diagram will explain it better than I can.
Thanks for any help in advance.
P_Titty
Actuator Cut Sheet:
https://docs.google.com/viewer?a=v&q=cache:aoqmZI21SmIJ:www.ruskin.com/catalog/servefile.aspx%3Fid%3D1123+AF24-SR+US&hl=en&gl=us&pid=bl&srcid=ADGEEShmkHOJF-GxrE49Ek9xlRijk-1s2AXWbwmxfgq9AA0TI7e_X32CpRsJRGXuCwTmvMJmkBJc5lJZ_6xFcuRR2BY15wnXDqgOSpJPduMDhmB8gPYryB_UmWT3x5-dNCc5veWDOiLv&sig=AHIEtbQwEvy1U0xFirPEYLHo6sTcdU3zuQ
C and R need to be mirrored, R needs to be on the PWM pin and C on the far side of R bypassing to ground. However your opto circuit is going to try to be on or off. Try this circuit:
Opto isolators work better at transmitting digital signals, so you would be better off smoothing the signal on the actuator side, not the Arduino side.
Can someone help me size a low pass filter for this circuit on the actuator side?
I've found many sites telling how this is done yet i dont understand sizing the cap or resistor.
Have you seen this one:-
http://www.thebox.myzen.co.uk/Tutorial/PWM.html
It depends on now fast you want to operate the actuator and how tolerant it is of ripple in the input voltage. I suggest something like this:
  • increase the 10v DC supply to 12v
  • 2K resistor between Q2 collector and +12v
  • 18K resistor between Q2 collector and actuator input
  • 10uF capacitor between actuator input and local 0V (Q2 emitter)
This give a time constant of around 0.2 seconds. If the actuator chatters or its current consumption remains high even when it has moved to the correct position, use a bigger capacitor. If you need faster response, use a smaller capacitor, and increase the PWM frequency if neccessary.
I would like to thank all who replied to this thread.
With your wealth of knowledge I've successfully completed my
analog circuit and utilizing the actuator.
Once Again, thanks for your time.
P_Titty
