Will this work? Programming help needed!
I have written this code with help from other program examples that i have sourced and want to know if I am on the right track.
The program is for automatic control of an alcohol still I have.
The servos and relays etc are yet to be wired up, but I have a question about what I have written.
I have several sequences that are to be run in order and I am worried that when each sequence finishes it will move through the earlier sequences as well as the sequence it is up to.
Let me give you an example: (look at the code below...)
The equal sequence runs (equal int = 1) and times out, and the heads integer is then set to = 1.
When the loop comes around again, because equal int still = 1, will it start counting again?
Any help would be greatly appreciated. I thought I would ask the forum as I have a few weeks until I wire the sensors and relays etc.
Matt
int Tmid = 0;  //initialize variables, T is the input from the middle thermistor
int Ttop = 0;  //initialize variables, T is the input from the top thermistor
int waterTmid = 50;   // waterT is the initial temp to turn on water
int safetyTmid = 85;  // the safety middle temp when the heater should turn off
int safetyTtop = 85;  // the safety top temp when the heater should turn off
int boil = 0;  // If boil is 0, then the boil has not started.  If it is 1, then the boil has started.
int equal = 0;  // If equal is 0, then the boil is not to temp.  If it is 1, then the boil is at temp and equalising.
int heads = 0;  // If heads is 0, then the equalisation has not finished.  If it is 1, then the heads has started.
int hearts = 0;  // If hearts is 0, then the heads have not finished.  If it is 1, then the hearts have started.
int shutdown = 0;  // If shut is 0, then the hearts has not finished.  If it is 1, then the shutdown will commence.
int overtemp = 0;  // If overtemp is 0, then all is well.  If it is 1, then the process will shutdown.
int start = 7;   // choose the input pin (for a pushbutton)
int switch1 = 5;     // variable for reading the B1 button pin status
int switch2 = 6;     // variable for reading the B1 button pin status
int val1;            // Variable for reading start button B1
int val2;            // Variable for reading stop button B2
long startone = 0;  // placeholder for the starting time for mash 1
long stopone = 0;  // placeholder for the stop time for mash 1
long remaining = 0; // difference between startone and stopone
int remainsecs = 0;  // convert to something close to a second like integer
void setup(){  // run setup once
pinMode(4, OUTPUT);  // initialize pin 4 as output, will be used to trigger heater relay circuit
pinMode(8, OUTPUT);  // initialize pin 8 as output, will be used to trigger pump relay circuit
pinMode(switch1, INPUT);
pinMode(switch2, INPUT);
Serial.begin(9600);  // sends serial data to pc, allow for reading the temp and status as reported by Serial.print
void loop(){ // loop this as long as Arduino has power or until reset button is pressed
delay(1000); // 1 second delay between loops        ????????????????????????????????????????????
// Temp display
Ttop = analogRead(2);  // get voltage from mid thermistor
Serial.print("Top: ");  // print midthermistor value to pc, this is not really temp but a number between 1 and 1024
Serial.print(Ttop);
Serial.print("\n");
Tmid = analogRead(3);  // get voltage from top thermistor
Serial.print("Mid: ");  // print thermistor value to pc, this is not really temp but a number between 1 and 1024
Serial.print(Tmid);
Serial.print("\n");
// Start
  if (boil == 0){                                    // if process has not started
  Serial.print("Press Start button...");
  val1 = digitalRead(switch1);                       // read input value and store it in val
  if (val1 == HIGH) {                                // check if the advance button is pressed
   boil = 1;    }
// Boil
if (boil == 1){  // Boil process
  digitalWrite(4, HIGH);  // Heat on
  digitalWrite(8, LOW);  // Water off
Serial.println("Boiling...");  // this prints out every second
// Water on
if (Tmid > waterTmid){ // if mid temp is more than safety temp, do this loop
    digitalWrite(8, HIGH); // turn on cooling water
    Serial.println("Heat down, Water on");  // this prints out when water is on
     equal = 1;
        // Servo movement needed!!!!!!!!!!!!!!!!!!!!!!
     startone = millis(); // start mash clock, reads milliseconds from this moment
     stopone = startone + 3600000; // calculate the end of mash, 3.6 million milliseconds or 60 minutes
// Equal
if (equal == 1){  // Equal process
  digitalWrite(8, HIGH);  // Water on
  long curtime = millis(); // set variable curtime to the elapsed time since program started
  remaining = (-1)*(curtime - stopone); // caculate how many milliseconds until mash is complete
  remainsecs = (int)(remaining/1000); // convert into human readable second like intervals but not exact
  Serial.print(remainsecs);  // print it to screen
  Serial.print(" - ");
  Serial.print("Remaining");
  Serial.print("\n");
   heads = 1; }
  if (curtime > stopone){  // if we reach the end of the mash time
   heads = 1;  }
// Collect heads
if (heads == 1){  // Heads process
  Serial.println("Collecting heads...");  // this prints out every second
   hearts = 1;    }
        // Stepping motor needed!!!!!!!!!
// Collect hearts
if (hearts == 1){  // Hearts process
Serial.println("Collecting hearts...");  // this prints out every second
// Shutdown
if (shutdown == 1){  // if process is complete, loop this
  digitalWrite(4, LOW);  // Heat off
Serial.println("Process completed");  // this prints out every second
if (Tmid > safetyTmid){ // if mid temp is more than safety temp, do this loop
    digitalWrite(4, LOW);  // turn off heat and pump
    Serial.println("Overtemp Mid");  // this prints out every second                                               ****need a timer to shut off water!!!!
    shutdown = 1;
if (Ttop > safetyTtop){ // if top temp is more than safety temp, do this loop
    overtemp = 1;
if (overtemp == 1){  // overtemp shutdown
    digitalWrite(4, LOW); // Turn on heat
    digitalWrite(8, HIGH); // Turn on water
    Serial.println("Overtemp Shutdown!");  // Prints boil on screen                                                ****need a timer to shut off water!!!!
// Stop Button
  val2 = digitalRead(switch2);                       // read input value and store it in val
  if (val2 == HIGH) {                                // check if the button is pressed
   overtemp = 1;    }
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
"When the loop comes around again, because equal int still = 1, will it start counting again?"
Yes, unless you clear it back to 0 at some point.
You can also put some checks around items and only initialize them if they haven't been already:
if (equal == 0){
then equal == 1, this part is skipped.
I suggest you Google "State machine".
Are these mutually exclusive states? It looks like it, as you won't be "not started" and "not finished" at the same time. So you really want one variable rather than a whole lot of different ones. Something like:
enum { BOIL, EQUAL, HEADS, HEARTS, SHUTDOWN };
int state = BOIL;
So you start off in the first state. Then when that is done you add 1 to it and move onto the next state. And so on.
Thanks for the replies!!
Nick, you are right in thinking that each state is mutually exclusive, when the boil is finished I wish to move to the next state and so on...
I am unfamiliar with the enum command, but I assume this is placed in the void setup?? is this right?
Also, could give an axample of adding a 1 to the 'int state = BOIL;' command?
I apologise for my questions and lack of knowledge, I have been spending a lot of time researching this language but it is still fairly new to me!
Thanks
int state = BOIL;
void setup ()
void loop ()
 state++; //next state
 if (state > SHUTDOWN)
   exit (0);  // done!
   //blah blah
Thanks, I have adjusted the code, could you have a quick look and let me know what you think?
Thanks
#include <Morse.h>
//int boil = 0;  // If boil is 0, then the boil has not started.  If it is 1, then the boil has started.
//int equal = 0;  // If equal is 0, then the boil is not to temp.  If it is 1, then the boil is at temp and equalising.
//int heads = 0;  // If heads is 0, then the equalisation has not finished.  If it is 1, then the heads has started.
//int hearts = 0;  // If hearts is 0, then the heads have not finished.  If it is 1, then the hearts have started.
int manshutdown = 0;  // If shut is 0, then the hearts has not finished.  If it is 1, then the shutdown will commence.
enum { BEGIN, BOIL, EQUAL, HEADS, HEARTS, SHUTDOWN, };
int state = BEGIN;
// Temp display
Serial.print(Ttop);
Serial.print("\n");
Serial.print(Tmid);
Serial.print("\n");
// Start
  if (state == BEGIN){                                    // if process has not started
    state++; //next state     }
// Boil
if (state == BOIL){  // Boil process
// Water on
// Equal
if (state == EQUAL){  // Equal process
  Serial.print("\n");
// Collect heads
if (state == HEADS){  // Heads process
// Collect hearts
if (state == HEARTS){  // Hearts process
// Shutdown
if (manshutdown == 1 ){  // if process is complete, loop this
   delay(100000);
    overtemp = 1;
    overtemp = 1;
    delay(100000);
// Stop Button
   manshutdown = 1;    }
The braces on your if statements don't seem to make sense. Could you hit contol-t in the editor, check that the blocks are what you wanted, and post the code again?
There are some lines with closing braces in comments.
A control-t (or command-t, if you're a Mac user) would have told you that you had a brace mismatch.
In this bit:
   // Equal
You aren't reading val1, it is just the value left over from way back. Plus is "val1" a useful data name? How about "buttonB1Press"?
What's with the blank lines? key got stuck?
It looks better than the original, I'm glad you used the state machine. Now for readability, put each state into a function, like this:
//#include <Morse.h>
enum {
int state = BEGIN;
{  // run setup once
void beginState ()
  if (val1 == HIGH)
}  // end of beginState
void boilState ()
}  // end of boilState
void equalState ()
  Serial.print("\n");
  if (val1 == HIGH)
}  // end of equalState
void headsState ()
  if (val1 == HIGH)
}  // end of headsState
void heartsState ()
}  // end of heartsState
  // Temp display
  Serial.print(Ttop);
  Serial.print("\n");
  Serial.print(Tmid);
  Serial.print("\n");
  // state machine
  switch (state)
  case BEGIN:
    beginState ();
  case BOIL:
    boilState ();
  case EQUAL:
    equalState ();
  case HEADS:
    headsState ();
  case HEARTS:
    heartsState ();
  }  // end of switch
  // Water on
  }  // end of temperature too high
  // Shutdown
    delay(100000);
  }  // end of manual shutdown
    overtemp = 1;
  }  // end of mid temperature test
    overtemp = 1;
  }  // end of top temperature test
  if (overtemp == 1)
    delay(100000);
    // Stop Button
    if (val2 == HIGH)
      manshutdown = 1;
  }// end of overtemp
} // end of loop
It isn't perfect by any means, but it shows the idea of moving things like processing each state into their own function where you can more clearly see what it is doing. Now you can inspect each state function and make sure it does what you want, and glance over the main loop to see if that looks right. I see a few problems, I'll let you find them. :slight_smile:
Even with Nick's surgery, loop is still huge - try moving some more of that stuff into separate functions - the state machine piece would be one obvious candidate, but you'll need others too ideally.
The spaces make it a bit easier for me to digest the information and search through it. I was planning on removing the spaces when complete.
Thanks again Nick, the changes look great. I am planning on reading and learning from the changes over the next couple of days.....
