Dear all,
I need simple code to detect the pulse output coming from this sensor. I also need additional circuit to detect the pulse when it has been connected to interrupt pin. Because I found variation in output.
//volatile unsigned int pulses=0;
static int pulses=0;
unsigned long button_time = 0;
unsigned long last_button_time = 0;
int pin=8;
attachInterrupt(1, countpulses,RISING); // interrupt 0 = pin 2
/* int count=0;
count=pulses+1;
Serial.println("count is");*/
//Serial.println(pulses);
/*Serial.println("\n");*/
//delay(1000);
void countpulses() {
button_time = millis();
if(button_time - last_button_time >50){
if(digitalRead(pin)==1){
pulses=pulses+1;
pulses=pulses-1;
last_button_time = button_time;
wind speed Sensor WS120 pulse.pdf (80.2 KB)
Which interrupt are you actually using ?
Do you really want the pulses variable to be static ? Should it not be volatile ?
Serial.println(pulses);Does this work in an ISR ?
UKHeliBob:
I am using interrupt pin 2 as Hardware .YES i want to calculate wind sensor for exactly 5 min.
What board are you using ?
Check which interrupt you are attaching the ISR to.
What has the 5 mins go to do with anything ?
UKHeliBob:
I want to carryout the test for Every min or 5 min . I am using Arduino UNO board.
Here what i want to expect. If interrupt is attached only the Increment has to be taken , Else should not read anything
You are using a Uno
The Uno has 2 hardware interrupts
Interrupt 0 is on pin 2. Interrupt 1 is on pin 3 http://arduino.cc/en/Reference/AttachInterrupt
attachInterrupt() takes the interrupt number as its first parameter
Your code isattachInterrupt(1, countpulses,RISING); // interrupt 0 = pin 2
Therefore you are using interrupt 1
Using the information above you will see that interrupt 1 is on pin 3
You say that you are using pin 2
Something is wrong
