I am having an issue with Wire and interrupts. When I attach an interrupt under LOW mode, and use the Wire library, the program ends up crashing when Wire tries to finish transmitting. The program itself is quite long, but I was able to create a minimal sketch that I think effectively illustrates the issue:
#include <Wire.h>
void do_nothing(){}
// Comment out (will work) or Uncomment (will not work).
// Crashes under any interrupt number [0 - 7] inclusive only
// using LOW mode. Works for all other modes.
attachInterrupt(0, do_nothing, LOW);
Wire.begin(); // start I2C as master
// Send something random to some random slave
Wire.beginTransmission(0xAA);
Wire.write((byte) 0xBB);
// Program will crash or deadlock HERE
Wire.endTransmission();
// If program is *working* LED should light up
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);
void loop(){}
Altering or removing the attachInterrupt line will let the program run to the end of setup() and turn the LED on. Otherwise, it will hang at Wire.endTransmission() and the LED will never go on (indicating failure).
Wire seems to work with the other modes, but not LOW mode. I could not see anything about this issue in attachInterrupt(), but perhaps there is info about it somewhere else that I missed. My project is using a library that requires the use of a LOW mode interrupt, so I am unable to alter it. I am using a Seeeduino w/ ATMega1280. Any help or input would be greatly appreciated (even if just testing that it also fails for you).
What is connected to pin 2? If nothing, and the pin is INPUT (as it is by default) and LOW, the useless interrupt handler will be called over and over, since the pin is LOW. There will never be time for other interrupts.
LOW interrupts are called repeatedly while the level is low. Once the interrupt handler is exited, it does one more instruction, then goes back into the interrupt handler if the level is still low. This will very seriously degrade performance. You probably want a FALLING interrupt, not a LOW one.
Thanks for getting back to me so quickly. I might be misunderstanding your explanation, but I tried adding two extra lines:
pinMode(2, INPUT);
digitalWrite(2, HIGH);
and the code is still not turning on the LED. There could be something I missed, but by setting it HIGH the interrupt should never fire, yet it is still crashing / deadlocking.
What is connected to pin 2? What is the purpose of this? I don't understand why you are using LOW interrupts, and you acknowledge that this is causing the problem. Clearly the interrupt is firing or it would not lock up. Try turning on an LED in the interrupt handler to prove this.
I spent a few hours fiddling with the library and altered it to use FALLING (Side note: pin 2 is the int0 for the Seeeduino Mega). The problem I was having is resolved. Apologies for this goose chase and thanks again for your help.
