Wire Library not found
Hello All,
When I install the Arduino package, Standard Wire Library is missing from the list and I cannot find it anywhere.
Can you help me where can I get it.
Best Regards
Pk
You don't need to find it, just use it in the sketch.
For the normal basic Arduino boards (for example the Arduino Uno), you can find it here:
On harddisk: hardware / arduino / avr / libraries / wire
Online: https://github.com/arduino/Arduino/tree/master/hardware/arduino/avr/libraries/Wire
Thanks Kopel,
When I use it, it is unable to locate in libraries and is not in library folder.
pkorivi:
Post your code and links to any 3rd party libraries you are using. Please use code tags(</> button on the toolbar).
Post the full text of the error message you are getting when you try to compile. There is a button "Copy error messages" on the right side of the orange bar shown when there is a compile error. Click that button and then paste it into a message here using code tags.
pkorivi:
Koepel already explained where it is located, you're looking in the wrong folder:
Koepel:
Here's an easy way to find it:
  • File > Examples > Wire > digital_potentiometer(or any other Wire library example if that one is not present)
  • Sketch > Show Sketch Folder
This will put you in the examples folder inside of the Wire library folder for the board you had selected in the Tools > Board menu.
