Remember the days of stacking eight 1 x n bit RAM chips and bending out the data pin sideways to save on sockets and wire-wrap joints?
And you tell that t'young people today; they won't believe you.
Luxury we used to dream about eight 1 x n bit RAM chips.
Just found an unused Z80B in my parts box!
I know somewhere in my "filing system", I have a diagram for a five chip Z80 board (processor, EPROM, 6116 RAM, UART and PIO).
Hmmm, this could be a long night.
This has been a pretty fun thread to read; I've got a handful of Z80 processors scored from my favorite haunt, Apache Reclamation, here in Phoenix. They've got a back room (full of NOS vaccuum tubes) with these drawers filled with various ICs in tube carriers - I'm sure in one of them is a cache of Z80 processors (found some 6809P once). Heh - in one of the bins there they had a wire-wrap prototyping board - pretty large, lots of area on the top-side, tons of gold plated pins sticking out from the bottom. I wanted to buy it, but they wanted something close to $100.00 for it - well beyond what I was willing to pay (interestingly, years ago they sold me an Altair for about the same amount).
What I don't understand from the OP - is why did he remove the Z80 from the Amstrad CPC? That was his Z80 computer right there; he would've been better off fixing/restoring that machine (its not like they're making more - and these old PCs and such are only climbing in value as the years go by - I was perusing Apple IIe hardware the other day, and saw that while the prices for a system weren't high - they weren't that low, either; still - cheap compared to an Altair system, which is why I consider myself lucky to own one - albeit in non-working condition right now).
I'm sure somewhere on the internet is an Amstrad club or users group of some sort...maybe.
AWOL:
After I got bored toggling in programs (no cassette storage and no UV-EPROM programmer), I bought a Nascom 1, but still couldn't afford an assembler, so I became very adept at hand-assembly - I still remember that "INC HL" is 0x23.
How sad is that?
Not sad at all. Hey, I still think back fondly on my days writing Macro-11 on PDPs. How can you not like an instruction set that contains SOB (Subtract One and Branch). Back then, we worked pretty hard to write really good, clean, elegant, efficient code. I'm guessing any newer embedded system these days has more RAM than we did, and we ran the OS and DECnet, plus our applications. Those were (mostly) fun times.
Hi.
It's very late, I've spent a lot of time trying to make that thing work,
but... it doesn't!
This is how I connected the whole thing: (sorry, didn't find time to draw
a schematic, and I have no dedicated software. Do you know good, open-source ones?)
When I power this on, without any resistor before GND, the CPU overheats
very fast (even if I clock the CPU at 1 Hz... it seems strange to me), and I unplug
it 'cause I'm not sure it won't break.
If I use a resistor, it takes time to heat, but enventually will. And it doesn't work the same.
My sketch is the following :
setup :
set arduino clk & reset to output, arduino A0-A3 to input
reset <- low
clock <- low
every 500 ms, switch the clock output from low to high or high to low
after 3 s, reset <- hi
read A0-A3. if result is different than previously read, display.
When I use a resistor, I've got a fixed 1111 result from A0-A3.
When I don't, it alternates very quickly between 1111 and 0111. (faster
than the clock). But I didn't think of MREQ, maybe I have to check its
value too before displaying A0-A3.
So, still I'm stucked... but I go on searching.
BTW, Rob, thanx for the http://www.z80.info website, I think I will try to
setup the minimum Z80 CPU test circuit (Thomas Scherrer Minimum Z80 tester),
seems a good way to find if the CPU is still OK, and if there is any problem with
the heat...
Time to sleep, I will just try the MREQ thingy before (or I won't be able to sleep!). See ya.
Bozgrul
You can't supply a clock signal to the Z80 from an IO port, you need a high frequency, about 2-4MHz.
You can generate upto 8MHz with any of the timers on the ATmega by directly programming them.
The original Z80 should get hot, its NMOS! Max current 150mA so nearly a watt of heat dissipation (at any clock frequency). The datasheet says static by design but parts only tested down to 5kHz. Have you measured the supply current - if its greater than 150mA you can be sure its fried or overloaded.
I suspect any replacement Z80 you can find these days is CMOS and much less power hungry.
Well, MREQ is alway low (active), A0-A3 is always 1111...
Time to go to bed !
Bozgrul
Hello !
So, I've tried a new circuit, the Z80 test circuit from z80.info (Thomas Scherrer Minimum Z80 tester),
to be sure that the Z80 was working correctly by itself, before going on.
And the result is... the circuit is not working. But I can't tell right now if it's the Z80 that's not working
or a mistake of mine, during the assembly.
A lot of heat, no LED on.... (btw, I assume that the Z80 can overheat even if it's broken. Is it right ?)
I've made a few checks with my voltmeter, and found some weird results : the resistors next to D0-D4 (or D3, not
sure) show something around 1V, the next one (D5 or D4) is 2.5V, and the remaining ones (D6-D7 or D5-D7) are 0V.
It doesn't seem right, but what can it mean, I cannot tell...
I've orderded a few Z80s from Jameco, because I don't know french shops that sell Z80s. So I'll have to wait a few
weeks maybe... (btw, do you know european shops, where shipping might be quicker - and cheaper ?)
During this time, I will try to do the same thing with a 6502 I've just received from eBay. I have more confidence
in it, so maybe I'll be able to make it work (even if it works differently, the clock for instance...).
I'll tell you as soon as I have any interesting results (w/ the arduino, of course!).
Bozgrul
Sorry I don't get the D0-7, there are only 3 diodes on that schematic and they are LEDs.
Yep, it could go either way depending on what's cactus.
Rob
D0..D7 is the Z80 data bus, just as A0..A15 is the address bus.
I think it is the thought of wiring all that lot up more than anything else turned me on to microcontrollers!
My FYP was a 6800 controlled rover, and I damn near sprained my wrist wire-wrapping it.
Doh, I must have written that before my first cup of coffee.
All the data lines should show 0v I would think, if that's not the case then the chip must be stuffed.
Rob
This project sounds prime for an FPGA
That would be cheating
Hello !
Sorry for the long delay (delayWeeks(), a new Arduino function... :)), but
I was waiting for my Z80 - and other electronic stuff - from Jameco (which costed me 44 € for shipping PLUS
44 € for customs... ouch... never again !), and then I became father for the second time... So I'm just beginning
to have a little spare time for me again, before going back to work tomorrow (ouch again).
While waiting for the Z80, I made some tests with a 6502, and it worked perfectly. So, I've done the same tests
with the new Z80, and it works great.
Things I'd like to do now:
Well, that's a lot to do ! It will eventually require a few years...
Thank you again for your advices and help !
cr0sh : sorry, I did'nt have enough time to explain why I'm doing this.
Boz
OK I know this thread is as old as my granddad.
If you're still there Boz, did you do any more with this?
Rob
graynomad said "I had a Microprofessor development board once"
Me too, left it at the office, went on annual leave (late 1983 iirc?... shit, exactly 30 years ago...), and some bar-steward stole it. I was not best pleased.....
Hi, I still have mine...
Tom...
