Wishield... need a help
Hello evreybody XD,
I Want to ask about Wishield...
1-How can I connect it to the the real Internet (i.e outside my home network so I can access it anywhere in the world) ?
2-Can I build website with DB and PHP to uplaod the data to DB.?
3- Or I can use the Pachube Only to uplaod the Data ?
Waiting for your answer with my thanks in advance. :blush:..
(not owning an wishield)
  1. you have to configure the IP address and gateway, mostly IP = 192.168.1.X (X is a free subnet number) and GW = 192.168.1.1 (address of your router). In fact similar info as when adding a new laptop to your home network.
    Your router must be configured for the protocols used - 802.11b probably; Furthermore routers often have a list of allowed mac addresses for wifi access.YOu have to add the mac address of the wifi shield
  2. Yes that is possible, a way to do it is to make a PHP webform on an APache server that accepts your log fields, and let the Arduino POST to the php-processor of that form. By doing it this way you can easily test the DB part. [NOTE: Arduino itself is too light to do PHP itself]
Thank You Robtillaart :stuck_out_tongue:
Can give me links for similar projects that can help me ?!
