I have a Wiznet wizfi360-EVB-Pico board here ( WizFi360-EVB-Pico | WIZnet Document System ) and of course the corresponding board file installed. (GitHub - Wiznet/WizFi360_arduino_library: Arduino library and examples for WizFi360)
Now I want to use this board with the TR-064 library (GitHub - Aypac/Arduino-TR-064-SOAP-Library: Arduino library for the TR-064 protocol, most commonly used by the Fritz!Box router API), but I just can't get it to work. I keep getting error messages in the IDE. The TR library doesn't match the board file. Has anyone ever got this to work?
Hi @trtra. I'm going to ask you to provide the full output from a compilation.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
- Select Sketch > Verify/Compile from the Arduino IDE menus.
- Wait for the compilation to fail.
- You will see a "Compilation error: ..." notification at the bottom right corner of the Arduino IDE window. Click the "COPY ERROR MESSAGES" button on that notification.
- Open a forum reply here by clicking the "Reply" button.
- Click the
<CODE/>icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
- Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
This will paste the compilation output into the code block. - Move the cursor outside of the code block markup before you add any additional text to your reply.
- Click the "Reply" button to post the output.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here.
Click here for attachment instructions
- Open any text editor program.
- Paste the copied output into the text editor.
- Save the file in
.txtformat. - Open a forum reply here by clicking the "Reply" button.
- Click the "Upload" icon (
) on the post composer toolbar:
The "Open" dialog will open. - Select the
.txtfile you saved from the "Open" dialog. - Click the "Open" button.
The dialog will close. - Click the "Reply" button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
