I am trying to do a project with the Seedstudio EMG, but it involves two LEDs and 2 EMG devices, and, whilst the code for one is easy, I want to know what changes I need to make to this code for one with 2 EMGs.
// Grove - EMG Sensor demo code
// This demo will need a Grove - Led Bar to show the motion
// Grove - EMG Sensor connect to A0
// Grove - LED Bar connect to D8, D9
// note: it'll take about serval seconds to detect static analog value
// when you should hold your muscle static. You will see led bar from level 10 turn to
// level 0, it means static analog value get ok
#include <Grove_LED_Bar.h>
Grove_LED_Bar bar(9,8,0);
Grove_LED_Bar bar1(8,7,0);
int max_analog_dta = 300; // max analog data
int min_analog_dta = 100; // min analog data
int static_analog_dta = 0; // static analog data
// get analog value
int getAnalog(int pin)
long sum = 0;
for(int i=0; i<32; i++)
sum += analogRead(pin);
int dta = sum>>5;
max_analog_dta = dta>max_analog_dta ? dta : max_analog_dta; // if max data
min_analog_dta = min_analog_dta>dta ? dta : min_analog_dta; // if min data
return sum>>5;
long sum = 0;
for(int i=0; i<=10; i++)
for(int j=0; j<100; j++)
sum += getAnalog(A0);
sum += getAnalog(A1);
delay(1);
bar.setLevel(10-i);
sum /= 1100;
static_analog_dta = sum;
int level = 5;
int level_buf = 5;
int val = getAnalog(A0); // get Analog value
int val1 = getAnalog(A3);
int level2;
if(val>static_analog_dta) // larger than static_analog_dta
level2 = 5 + map(val, static_analog_dta, max_analog_dta, 0, 5);
level2 = 5 - map(val, min_analog_dta, static_analog_dta, 0, 5);
// to smooth the change of led bar
if(level2 > level)
level++;
else if(level2 < level)
level--;
if(level != level_buf)
level_buf = level;
bar.setLevel(level);
Serial.print(level);
Serial.print(" ");
Serial.println(level2);
delay(10);
