However, I didn't have this chip on hand. Knowing that Arduinos have on-board EEPROM, I grabbed a nearby Nano and tried to write to it. Confusingly, it was looking like it worked - it was reading the data (1-127 from the tutorial) correctly back, but when I tried to write a custom array, it just read the original array back to me. Confused, I then plugged the Nano in directly and read the EEPROM, which told me that it was full of 255's.
Ok, I got some SPI EEPROM chips, specifically this one:
Any it seemed (at first) to respond to writing from a Nano. However, I noticed that after a few loops, the serial feed started to look strange, so I re-downloaded the original tutorial code:
#define DATAOUT 11//MOSI
#define DATAIN 12//MISO
#define SPICLOCK 13//sck
#define SLAVESELECT 10//ss
//opcodes
#define WREN 6
#define WRDI 4
#define RDSR 5
#define WRSR 1
#define READ 3
#define WRITE 2
byte eeprom_output_data;
byte eeprom_input_data=0;
byte clr;
int address=0;
//data buffer
char buffer [128];
void fill_buffer()
for (int I=0;I<128;I++)
buffer[I]=I;
char spi_transfer(volatile char data)
SPDR = data; // Start the transmission
while (!(SPSR & (1<<SPIF))) // Wait the end of the transmission
return SPDR; // return the received byte
pinMode(DATAOUT, OUTPUT);
pinMode(DATAIN, INPUT);
pinMode(SPICLOCK,OUTPUT);
pinMode(SLAVESELECT,OUTPUT);
digitalWrite(SLAVESELECT,HIGH); //disable device
// SPCR = 01010000
//interrupt disabled,spi enabled,msb 1st,master,clk low when idle,
//sample on leading edge of clk,system clock/4 rate (fastest)
SPCR = (1<<SPE)|(1<<MSTR);
clr=SPSR;
clr=SPDR;
delay(10);
//fill buffer with data
fill_buffer();
//fill eeprom w/ buffer
digitalWrite(SLAVESELECT,LOW);
spi_transfer(WREN); //write enable
delay(10);
spi_transfer(WRITE); //write instruction
address=0;
spi_transfer((char)(address>>8)); //send MSByte address first
spi_transfer((char)(address)); //send LSByte address
//write 128 bytes
spi_transfer(buffer[I]); //write data byte
digitalWrite(SLAVESELECT,HIGH); //release chip
//wait for eeprom to finish writing
delay(3000);
Serial.write('h');
Serial.write('i');
Serial.write('\n');//debug
byte read_eeprom(int EEPROM_address)
//READ EEPROM
int data;
spi_transfer(READ); //transmit read opcode
spi_transfer((char)(EEPROM_address>>8)); //send MSByte address first
spi_transfer((char)(EEPROM_address)); //send LSByte address
data = spi_transfer(0xFF); //get data byte
digitalWrite(SLAVESELECT,HIGH); //release chip, signal end transfer
return data;
eeprom_output_data = read_eeprom(address);
Serial.print(eeprom_output_data,DEC);
Serial.write('\n');
address++;
if (address == 128)
address = 0;
delay(500); //pause for readability
This SPI tutorial (not my site) includes how-to and code to make Arduino work as an SPI slave device.
There are bootloaders that let you write to flash. If it won't change, flash is good storage. EEPROM has 10x as many writes as flash at 100K guaranteed.
