UKHeliBob:
Note that the code I posted that works for me and not for you uses a basic RFID library
But you also had to download the ZIP library of the link I sent, right? (Here is the link again http://www.instructables.com/id/Arduino-RFID-Reader-MFRC522-Turorial/ ). I added two libraries within Arduino for this code. The one inside that ZIP file and the MRFC522 that you can find by clicking on "Managing Libraries".
UKHeliBob:
but I have no idea where I downloaded it from
I think that this one is the MRFC522 library. If you click on 'More information', you're sent to this page GitHub - miguelbalboa/rfid: Arduino RFID Library for MFRC522 . It is indeed created by Miguel Balboa. Which version of this library are you using?
Furthermore, I was trying to take another code and start working from there. I picked the code for reading the NUID (see below).
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 rfid(SS_PIN, RST_PIN); // Instance of the class
MFRC522::MIFARE_Key key;
// Init array that will store new NUID
byte nuidPICC[4];
SPI.begin(); // Init SPI bus
rfid.PCD_Init(); // Init MFRC522
for (byte i = 0; i < 6; i++) {
key.keyByte[i] = 0xFF;
Serial.println(F("This code scan the MIFARE Classsic NUID."));
Serial.print(F("Using the following key:"));
printHex(key.keyByte, MFRC522::MF_KEY_SIZE);
// Look for new cards
if ( ! rfid.PICC_IsNewCardPresent())
return;
// Verify if the NUID has been readed
if ( ! rfid.PICC_ReadCardSerial())
return;
Serial.print(F("PICC type: "));
MFRC522::PICC_Type piccType = rfid.PICC_GetType(rfid.uid.sak);
Serial.println(rfid.PICC_GetTypeName(piccType));
// Check is the PICC of Classic MIFARE type
if (piccType != MFRC522::PICC_TYPE_MIFARE_MINI &&
piccType != MFRC522::PICC_TYPE_MIFARE_1K &&
piccType != MFRC522::PICC_TYPE_MIFARE_4K) {
Serial.println(F("Your tag is not of type MIFARE Classic."));
return;
if (rfid.uid.uidByte[0] != nuidPICC[0] ||
rfid.uid.uidByte[1] != nuidPICC[1] ||
rfid.uid.uidByte[2] != nuidPICC[2] ||
rfid.uid.uidByte[3] != nuidPICC[3] ) {
Serial.println(F("A new card has been detected."));
// Store NUID into nuidPICC array
for (byte i = 0; i < 4; i++) {
nuidPICC[i] = rfid.uid.uidByte[i];
Serial.println(F("The NUID tag is:"));
Serial.print(F("In hex: "));
printHex(rfid.uid.uidByte, rfid.uid.size);
Serial.print(F("In dec: "));
printDec(rfid.uid.uidByte, rfid.uid.size);
else Serial.println(F("Card read previously."));
// Halt PICC
rfid.PICC_HaltA();
// Stop encryption on PCD
rfid.PCD_StopCrypto1();
* Helper routine to dump a byte array as hex values to Serial.
void printHex(byte *buffer, byte bufferSize) {
for (byte i = 0; i < bufferSize; i++) {
Serial.print(buffer[i] < 0x10 ? " 0" : " ");
Serial.print(buffer[i], HEX);
* Helper routine to dump a byte array as dec values to Serial.
void printDec(byte *buffer, byte bufferSize) {
Serial.print(buffer[i], DEC);
I decided to focus on the DEC instead of HEX, so I removed the HEX part. Also, you can remove all the sentences that are printed to the serial monitor like "This code scan the MIFARE Classsic NUID." and stuff. Makes it easier to read. Eventually, you end up with this code:
#include <SPI.h>
#define SS_PIN 10
#define RST_PIN 9
byte nuidPICC[4];
return;
return;
return;
// Halt PICC
rfid.PICC_HaltA();
On the bottom of the code, the void can be found with which printDec is created. When scanning a card, it only gives a specific number of the card (provided by the void printDec). However, I don't succeed in getting it written to the serial port instead of printed. Tried different things (inside the void loop and the void printDec), but it does not work. Do you see a solution inside this code?
P.S. The message was too long, so I removed the explanatory comments that were shown at head of the code. I will post them as a new message.
