Hello!
I'm currently writing a library, but have some questions concerning the constructor.
The device I'm writing the library for has a few modules on board that need initialization.
For example an UART devise, so that would need the "Serial1.begin" function. But also an SPI devise that needs to receive a few instructions before normal operation, and a shift register that needs to be cleared.
Is it good practice to place this "initialization" code in the constructor of the library, so that they get executed when creating the object? See code below where I did this for Serial1.begin.
Or should I put this code in an initialization function like GameCode::initialization() that the user would have to call in the void setup()?
Thanks in advance!
Main sketch:
#include "GameCode.h"
const byte statusled = 13;
GameCode MyGameCode;
Serial.begin(9600); //initialise UART for USB feedback
pinMode(17, OUTPUT);
pinMode(30, OUTPUT);
MyGameCode.MP3PlayTrack(01, 02);
while (true) {
Serial.print("test");
digitalWrite(17, HIGH);
digitalWrite(30, HIGH);
digitalWrite(17, LOW);
digitalWrite(30, LOW);
.h file:
#ifndef GameCode_h
#define GameCode_h
#include <Arduino.h>
class GameCode {
public:
GameCode(); //constructor
void MP3SendCommand(byte command, byte para1_highbyte, byte para2_lowbyte);
void MP3PlayTrack(byte Directory, int Track);
private:
#endif
.cpp file:
#include "Arduino.h"
GameCode::GameCode(){
//Constructor
//Use for initialization?
Serial1.begin(9600); //initialise UART for MP3 module
void GameCode::MP3SendCommand(byte command, byte para1_highbyte, byte para2_lowbyte) {
const byte startbyte = 0x7E;
const byte versioninfo = 0xFF;
const byte numberofbytes = 0x06;
const byte feedback = 0x00;
const byte endbyte = 0xEF;
unsigned int checksum;
byte checksum_high;
byte checksum_low;
//Calculate checksum
checksum = versioninfo + numberofbytes + command + feedback + para1_highbyte + para2_lowbyte;
checksum = 0 - checksum;
checksum_low = checksum & 0xFF;
checksum_high = (checksum & 0xFF00) >> 8;
//Send datastream to MP3 module
Serial1.write(startbyte);
Serial1.write(versioninfo);
Serial1.write(numberofbytes);
Serial1.write(command);
Serial1.write(feedback);
Serial1.write(para1_highbyte);
Serial1.write(para2_lowbyte);
Serial1.write(checksum_high);
Serial1.write(checksum_low);
Serial1.write(endbyte);
void GameCode::MP3PlayTrack(byte Directory, int Track) {
if (Directory > 101) { //Not permitted operation, exit this function.
return;
byte command;
byte para1_highbyte;
byte para2_lowbyte;
//Process parameters
if (Directory == 0) {
//Play from ROOT folder.
command = 0x03;
para1_highbyte = (Track >> 8) & 0xFF;
para2_lowbyte = Track & 0xFF;
} else if (Directory < 100) {
//Play from selected folder. "01" to "99".
command = 0x0F;
para1_highbyte = Directory;
para2_lowbyte = Track;
} else if (Directory == 100) {
//Play from "MP3" folder.
command = 0x12;
} else if (Directory == 101) {
//Play Advert
command = 0x13;
//Send processed parameters
MP3SendCommand(command, para1_highbyte, para2_lowbyte);
