Writing a timing library, asking for suggestions
I am writing a timing library. (Well I am playing around)
Can you think of other functions that could be useful to add?
#include <CheckTime.h>
//Instantiate objects
CheckTime MyTimer;
CheckTime My2ndTimer;
CheckTime My3rdTimer;
CheckTime FlashLED;
CheckTime Flash2ndLED;
  MyTimer.StartTiming(5000UL);    //Start this timer with 5 second delay
  FlashLED.StartTiming(100UL);    //Start this timer with 1/10 second delay
  My2ndTimer.StartTiming(6000UL); //Start this timer with 6 second delay
  Flash2ndLED.StartTiming(500UL); //Start this timer with 1/2 second delay
  My3rdTimer.StartTiming(10000UL); //Start this timer with 10 second delay
  pinMode(13,OUTPUT); //LED connected to this pin
  pinMode(12,OUTPUT); //LED connected to this pin
  pinMode(11,OUTPUT); //LED connected to this pin
  pinMode(10,OUTPUT); //LED connected to this pin
  //Ex: #1, limits how long something is done before a delay period is up
  if(MyTimer.DoUntil())    //As long as we have not reached the delay time, execute the code within
    if(FlashLED.Repeat())  //When this delay is over execute the code within, then start again.
      digitalWrite(13,!digitalRead(13));
  //Ex: #2, executes something once after a delay period
  if(My2ndTimer.DoWhen())   //When the timer delay is over, execute the code within
    Serial.println("Time is UP");
    digitalWrite(12,!digitalRead(12)); //Toggle LED on then off
    delay(1); //so you can see the LED flash
    //Ex: #3, executes something after a delay period then start the delay period again
  if(My3rdTimer.DoWhen())   //When the timer delay is over, execute the code within
    digitalWrite(11,!digitalRead(11));
    My3rdTimer.StartTiming(10000UL);  //Restart this delay period
  //Ex: #4, executes something over and over again after a delay period
  if(Flash2ndLED.Repeat())  //When the delay is over, execute the code within, then start again.
    digitalWrite(10,!digitalRead(10));
} //END of loop()
#include <Arduino.h>
// CheckTime.cpp
// CheckTime.h"
// Rev 1.00   October 3, 2015 functional code
//                    F U N C T I O N    P R O T O T Y P E S
//                       C l a s s   C h e c k T i m e
class CheckTime
public:
  //CheckTime();
  void begin();
  void StartTiming(unsigned long);
  void ResetTiming();
  void EnableTiming();
  void DisableTiming();
  void SetDelay(unsigned long);
  bool IsEnabled();
  bool Repeat();
  bool DoWhen();
  bool DoUntil();
private:
  bool enabled;
  unsigned long _Delay;
  unsigned long lastMillis;
};  // END of CheckTime class
// In C++ you must have a ; at the end of a class definition
#include "CheckTime.h"
//Constructor
//CheckTime::CheckTime()
//} // END of CheckTime()
//Initialization
//void CheckTime::begin()
//} // END of begin()
void CheckTime::StartTiming(unsigned long Delay)
  _Delay = Delay;
  lastMillis = millis();
  enabled = true;
} // END of StartTimer()
void CheckTime::EnableTiming()
  enabled = true;
} // END of EnableTimer()
void CheckTime::DisableTiming()
  enabled = false;
} // END of DisableTimer()
bool CheckTime::IsEnabled()
  return enabled;
} // END of IsEnabled()
void CheckTime::ResetTiming()
} // END of ResetTimer()
void CheckTime::SetDelay(unsigned long Delay)
  _Delay = Delay;
} // END of SetDelay()
bool CheckTime::Repeat()
  if(enabled && millis() - lastMillis >= _Delay)
    lastMillis = lastMillis + _Delay;
    return true;
  return false;
} // END of Repeat()
bool CheckTime::DoWhen()
    enabled = false;
    return true;
  return false;
} // END of DoWhen()
bool CheckTime::DoUntil()
  if(enabled && millis() - lastMillis <= _Delay)
    return true;
  enabled = false;
  return false;
} // END of DoUntil()
DoWhen() and DoUntil() don't actually DO anything. So, the choice of names is poor.
CheckTime doesn't adequately define what the class is for.
as opposed to timingStarted? What a lousy name.
Should the user or the instance keep track of whether timing is enabled, when ResetTiming() is called? That function restarts the timer. So, again, could use a better name.
SetDelay() sets the interval, not the delay.
But, the most important problem is that it is up to each instance to check, periodically, to see if it is time to do something. The instances can't say "call me when...".
Otherwise, nice first attempt.
I would like the ladder logic equivalent of a timer
makeTimer(name,timeBase); //in set up
startTimer(name);
timerTiming(name); // something I can use in a "if"
timerDone(name); // something I can use in a "if"
timerDisplay(name,type);//time countdown, count up, etc
resetTimer(name);
one day I will learn to code as my first few attempts at this were so bad I deleted them....lol
Here's my take:
Timer.h:
// Timer.h
// OO based timer class by aarg, Arduino forum 2015-10-04
#define MILLIS_PER_SEC 1000UL
class Timer {
  private:
    unsigned long interval;
    unsigned long previousMillis;
  public:
    Timer(unsigned long interval);
    void start();
    byte complete();
    unsigned long elapsed();
    unsigned long remaining();
// end class
Timer.cpp:
// Timer.cpp
#include "Timer.h"
Timer::Timer(unsigned long iv)  //class constructor
  interval = iv;
void Timer::start()
  previousMillis = millis();
unsigned long Timer::elapsed()
  return millis() - previousMillis;
byte Timer::complete()
  if (elapsed() >= interval)  //if the time interval has elapsed
    previousMillis += interval;                //save the time of change
    return true;
    return false;
unsigned long Timer::remaining()
  return interval - elapsed();
// end class definition
The sketch:
// OO based blink sketch by aarg, Arduino forum 2015-10-04
#include <Timer.h>
Timer LEDtimer(5 * MILLIS_PER_SEC);
Timer SerialTimer(MILLIS_PER_SEC / 2);
  pinMode(LED_BUILTIN, OUTPUT);
  LEDtimer.start();
  SerialTimer.start();
  // toggle the LED on/off every 5 seconds
  if (LEDtimer.complete())
    digitalWrite(LED_BUILTIN, not digitalRead(LED_BUILTIN));
    LEDtimer.start();
  // print the LED timer's remaining time 10 times a second
  if (SerialTimer.complete())
    Serial.println(LEDtimer.remaining());
I am not in favour of timing libraries - especially if they are just dressing up millis() in a nice party frock. Spend the same amount of effort writing a tutorial on the use of millis() and the end-user will be much better served.
Teach a man to fish and he can feed his family for his lifetime. Give him a fish and they will all be hungry again tomorrow.
...R
@PaulS
Naming is poor.
Agreed, I too am not am excited about the naming.
MayBe:
CheckTime CreateTimer
DoWhen() Done()
DoWhile() While()
After() New function, same as !While() would be.
ResetTimer() Restart()
SetDelay() SetInterval()
@gpop1
Timer, Done, Display are reasonable
@Robin2
I fully agree.
And then there is the man only likes candy.
Robin2:
...especially if they are just dressing up millis() in a nice party frock...
It's encapsulation.
Robin2:
...R
I like the party frock
I find the hardest part to explain to people is when to take a new time stamp. For some reason people just struggle with the concept of where in the program to add the new time stamp. If telling them this is the point we start and this is the point we say that the timer is done then they will get the idea. Once they get the idea of where to do things in a logical order the use of millis() prevmillis will become easier.
sometimes small steps work better
aarg:
It's encapsulation.
I much prefer party frocks. :slight_smile:
...R
Depends on who's wearing them...
@aarg
Got some ideas from your code.
Thank you very much.
@Robin2
Or no party frocks at all. :wink:
Here is version 1.01 of the library:
#include <CreateTimer.h>
CreateTimer MyTimer;
CreateTimer My1stTimer;
CreateTimer My2ndTimer;
CreateTimer My3rdTimer;
CreateTimer FlashLED;
CreateTimer Flash2ndLED;
  MyTimer.Start(5000UL);     //Start this timer with 5 second Interval
  My1stTimer.Start(4000UL);  //Start this timer with 4 second Interval
  FlashLED.Start(100UL);     //Start this timer with 100ms Interval
  My2ndTimer.Start(6000UL);  //Start this timer with 6 second Interval
  Flash2ndLED.Start(500UL);  //Start this timer with 500ms Interval
  My3rdTimer.Start(10000UL); //Start this timer with 10 second Interval
  pinMode(9,OUTPUT);  //LED connected to this pin
  //Ex: #1, executes code as in an Interval period
  if(MyTimer.While())     //As long as we have not reached the Interval time, execute the code within
    if(FlashLED.Repeat()) //When this Interval is over execute the code within, then start again.
  Serial.print("Time left in MyTimer = ");
  Serial.println(MyTimer.Remaining()); //Output the time left in this timer
  //Example #2 executes code after an Interval has passed. This will continue.
  if(My1stTimer.After())   //After we have reached the Interval time, continue to execute this code
    digitalWrite(9,!digitalRead(9));
    delay(50);             //so you can see the LED flash
  //  Serial.print("Time left in My1stTimer = ");
  //  Serial.println(My1stTimer.Remaining()); //Output the time left in this timer
  //Ex: #3, executes code "ONCE ONLY" after an Interval period
  if(My2ndTimer.Finished()) //When the timer Interval is over, execute the code within
    Serial.println("My2ndTimer Interval has expired");
  //  Serial.print("Time left in My2ndTimer = ");
  //  Serial.println(My2ndTimer.Remaining()); //Output the time left in this timer
  //Ex: #4, executes code after an Interval period, then starts the Interval period again
  if(My3rdTimer.Finished())    //When the timer Interval is over, execute the code within
    My3rdTimer.Start(10000UL); //Restart this Interval period
  //  Serial.print("Time left in My3rdTimer = ");
  //  Serial.println(My3rdTimer.Remaining()); //Output the time left in this timer
  //Ex: #5, executes code over and over again, i.e. after an Interval period
  if(Flash2ndLED.Repeat()) //When the Interval is over, execute the code within, then start again.
  //  Serial.print("Time left in Flash2ndLED = ");
  //  Serial.println(Flash2ndLED.Remaining()); //Output the time left in this timer
} //END of loop()
// CreateTimer.cpp
// CreateTimer.h"
// Rev
// 1.00   October 2, 2015 Functional code
// 1.01   October 4, 2015 Renamed variables and functions. Added: After() Remaining() Elapsed()
//                      C l a s s   C r e a t e T i m  e r
class CreateTimer
public:
  //CreateTimer();
  void begin();
  void Start(unsigned long);
  void Restart();
  void Enable();
  void Disable();
  void SetInterval(unsigned long);
  bool IsEnabled();
  unsigned long Elapsed(); //1.01
  unsigned long Remaining(); //1.01
  bool Repeat();
  bool Finished();
  bool While();
  bool After(); //1.01
private:
  bool enabled;
  unsigned long _Interval;
  unsigned long _temp; //temporary variable 1.01
};  // END of CreateTimer class
#include "CreateTimer.h"
//Constructor
//CreateTimer::CreateTimer()
//} // END of CreateTimer()
//Initialization
//void CreateTimer::begin()
void CreateTimer::Start(unsigned long Interval)
  _Interval = Interval;
  enabled = true;
} // END of Start()
void CreateTimer::Enable()
  enabled = true;
} // END of Enable()
void CreateTimer::Disable()
  enabled = false;
} // END of Disable()
bool CreateTimer::IsEnabled()
  return enabled;
void CreateTimer::Restart()
} // END of Restart()
unsigned long CreateTimer::Elapsed() //1.01
  return millis() - lastMillis;
} // END of Elapsed()
unsigned long CreateTimer::Remaining() //1.01
  _temp = _Interval - Elapsed();
  if(_Interval >= _temp)
  return _temp;
  return 0;  //if there was an under flow, return zero
} // END of Remaining()
void CreateTimer::SetInterval(unsigned long Interval)
} // END of SetInterval()
bool CreateTimer::Repeat()
  if(enabled && Elapsed() >= _Interval)
    lastMillis = lastMillis + _Interval;
    return true;
  return false;
bool CreateTimer::Finished()
    enabled = false;
    return true;
  return false;
} // END of Finished()
bool CreateTimer::While()
  if(enabled && Elapsed() <= _Interval)
    return true;
  enabled = false;
  return false;
} // END of While()
bool CreateTimer::After() //1.01
    return false;
  enabled = false;
  return true;
} // END of After()
// END of CreateTimer class definition
Attached is the zip file.
CreateTimer.zip (2.8 KB)
Robin2:
...R
But then, isn't millis() just timer 0 wearing pretty underwear?
aarg:
Now you are getting me all steamed up :slight_smile:
You are, of course, quite correct. But I think millis() does add some useful simplification - and it is itself very simple. There is really no need to read its documentation.
...R
Her s the latest version of the library:
CreateTimer::Start(unsigned long);              Starts your timer, requires an Interval
CreateTimer::StartRepeat(unsigned long, long);  Starts your timer, requires an Interval, requires a "Repeat" value
CreateTimer::Restart();                         The timer Interval is restarted
CreateTimer::Enable();                          Allow timer action
CreateTimer::Disable();                         Disable timer action
CreateTimer::SetInterval(unsigned long);        Change timer Interval
CreateTimer::IsEnabled();                       bool returns the timer enable status
CreateTimer::Remaining();	                unsigned long returns the ms left in this timer
CreateTimer::Repeat();                          bool true when interval is reached, may repeat timing
                                                     if you used StartRepeat() to start the timer
CreateTimer::Once();                            bool true when interval is reached, then false there after
CreateTimer::While();                           bool true until interval is reached, false there after
CreateTimer::After();                           bool false until interval is reached, true there after
  MyTimer.Start(5000UL);             //Start this timer with a 5 second Interval
  My1stTimer.Start(4000UL);          //Start this timer with a 4 second Interval
  FlashLED.Start(100UL);             //Start this timer with a 100ms Interval
  My2ndTimer.Start(6000UL);          //Start this timer with a 6 second Interval
  Flash2ndLED.StartRepeat(500UL,20); //Start this timer with a 500ms Interval, Repeat 20 times
  My3rdTimer.Start(10000UL);         //Start this timer with a 10 second Interval
  // The following 6 examples are non blocking
  //Ex: #1, This timer was started by: MyTimer.Start(5000UL);
  //executes code while in an Interval period.
  if(MyTimer.While())
    //Ex: #2, This timer was started by: FlashLED.Start(100UL);
    //executes code after an Interval period, the timer restarts automatically
  Serial.println(MyTimer.Remaining());     //Outputs the time in ms left in this timer
  //Example #3 This timer was started by: My1stTimer.Start(4000UL);
  //executes code after an Interval has passed
  //  Serial.println(My1stTimer.Remaining()); //Outputs the time in ms left in this timer
  //Ex: #4, This timer was started by: My2ndTimer.Start(6000UL);
  //executes code "ONCE ONLY" after an Interval period
  if(My2ndTimer.Once())
    digitalWrite(11,!digitalRead(11)); //Toggle LED on then off
    delay(10);                         //so you can see the LED flash
  //  Serial.println(My2ndTimer.Remaining()); //Outputs the time in ms left in this timer
  //Ex: #5, This timer was started by: My3rdTimer.Start(10000UL);
  //executes code after an Interval period, then starts the Interval period timing again
  if(My3rdTimer.Once())
    Serial.println("My3rdTimer Interval has expired");
    My3rdTimer.Start(10000UL); //Start this Interval period again
  //  Serial.println(My3rdTimer.Remaining()); //Outputs the time in ms left in this timer
  //Ex: #6, This timer was started by:  Flash2ndLED.StartRepeat(500UL,20);
  //executes code after an Interval, this happens "Repeat" number of times
    delay(100);               //so you can see and count the the LED flashes
  //  Serial.println(Flash2ndLED.Remaining()); //Outputs the time in ms left in this timer
} //END of loop()
Attached is the zip file for the library.
CreateTimer.zip (3.41 KB)
// CreateTimer.cpp
// CreateTimer.h"
//  Rev
//  1.02   October 10, 2015 Added the Repeat option to the Start function
class CreateTimer
public:
  //CreateTimer();
  //void begin();
  void StartRepeat(unsigned long, long);  //1.02
  void Restart();
  void Enable();
  void Disable();
  bool IsEnabled();
  bool Repeat();
  bool Once();
  bool While();
private:
  unsigned long Elapsed();         //1.01  No access to the user
  long _Repeat;                          //1.02
  bool enabled;
//Constructor
//Initialization
// Initialize the timer. This starts the timing for this timer.
  _Repeat = -1;               //1.02
  enabled = true;
} // END of Start()
// Initialize the timer. This starts the timing for this timer. "Repeat" is the number of repeating intervals.
void CreateTimer::StartRepeat(unsigned long Interval,long Repeat)   //1.02
  _Repeat = Repeat;
  enabled = true;
} // END of StartRepeat()
// Enable the timer
  enabled = true;
// Disable the timer
  enabled = false;
// Return true if the timer is enabled false if disabled
  return enabled;
// Restart the timing sequence
// Return the time left in the timer: >=0 time left <= interval
    return _temp;
    return 0;  //under flow, return zero
// Change the timer interval
// Return false in the interval, return true at the end of the interval, then restart the timer
    //_Repeat being negative indicates this is a continuous timer.
    if(_Repeat < 0)
      return true;
    //_Repeat being positive, indicates this is a timer that "Repeats" a given number of times.
 //2,147,483,647 is the maximum number the timer can repeat
    else if(_Repeat-- != 0)
      return true;
      //We have now completed this _Repeat sequence
      enabled = false;
      return false;
  return false;
// Return false in the interval, return true "at" the end of the interval, then false there after
bool CreateTimer::Once()
    enabled = false;
    return true;
  return false;
} // END of Once()
// Return true while in the interval and false after the interval has expired
    return true;
  enabled = false;
  return false;
} // END of While()
// Return false in the interval and true after the interval has expired
    return false;
  enabled = false;
  return true;
} // END of After()
  void Restart();
  void Enable();
  void Disable();
It is usually a good idea to provide a name for the variable, do the user can make a reasonable guess what the arguments mean. I HATE guessing games.
Thanks PaulS
Edit:
Made some name changes in the library
Attached version 1.03
CreateTimer.zip (3.77 KB)
larryd:
I like it, thank you! and please, don't abandon it ..
