Hey there! I was hoping I could receive some help with trying to write to a new file on an SD card.
I am having trouble with trying to modify this code where I'm trying to allow the user to input text through the serial monitor which is then written to a newly created file on an SD card. I was hoping I could find out what mistakes are or how this is possible. I am using Arduino Uno and Nano.
The goal is for the user to open the serial monitor, type in a string of letters/numbers to input into the file, have a new line generated, repeat this process several times, and then on the last line when the user enters the last few inputs these are then separated only by a blank space. The loop has a fixed amount of iterations for our application.
Other details include creating the file, using a different file type then .txt (.info in our case), and closing the file.
Serial.println("Creating box.info");
myFile = SD.open("box.txt", FILE_WRITE);
Serial.println("Enter input for box.info");
while (counter < counterlimit){
if(myFile) {
if (counter >= 8){
while(Serial.available()==0){}
value = Serial.readString();
myFile.println(value);
myFile.println(" ");
counter++;
}else {
myFile.println("\n");
counter++;
myFile.close();
On the serial monitor window, when I input something I don't see that text then returned in the window for me to see (Serial.println(value)) and the code gets stuck at the loop it seems (the rest of the code which I will share outputs fine when while (counter < counterlimit) is removed.
I tried
serial.println("1");
// break;
if(myFile) {``
And the 1 will get continuously printed to the monitor without ending the loop so it seems like the if (MyFile) statement is not working.
Here is the rest of the code
#include <SPI.h>
#include <Wire.h>
#include "SdFat.h"
#include "FreeStack.h"
#include "DS1390_SPI.h"
SdFat SD;
/* Initialization_Check.ino
Simple script to verify the RTC and SD Card connections
- Displays all files stored in the SD Card, and allowing user to delete all files (excluding 'box.info').
We only want new binary files on the SD Card when we receive it back from a deployment.
- Loops the RTC's time to verify
// SPI Settings (rising edge or falling edge)
SPISettings settingsA(8000000, MSBFIRST, SPI_MODE0); //rising edge (for ADC, POT, SD card)
SPISettings settingsB(8000000, MSBFIRST, SPI_MODE1); //falling edge (for DAC)
// SPI Chip Select Pins
const uint8_t POT_CS_PIN = 7; //CS_SEL[2], PCB layout ####
const uint8_t SD_CD_PIN = 4; //SD card reader chip-detected
const uint8_t SD_CS_PIN = A5; //SD card chip-select pin, physically connected to pin A6 ####S
DS1390 Clock (1);
DS1390DateTime Time;
File myFile; // File Declaration
// Open serial port
digitalWrite(POT_CS_PIN, LOW); //CS for SPI DIGPOT, (also used for RTC and TEMP)
pinMode(POT_CS_PIN, OUTPUT);
SPI.begin();
SdFat sd;
SdFile dirFile;
SdFile file;
int AirboxByte = 0; // Character being added to box.info file
String value = ""; // Value read by user
int counterlimit = 11; // Count for the serial monitor loop
int counter = 0;
char value_byte = 0;
uint16_t FileCount = 0;
uint16_t dirIndex[300]; // Position of file's directory entry.
if (!sd.begin(SD_CS_PIN, SD_SCK_MHZ(50))){
sd.initErrorHalt();
Serial.println("Creating Airbox.info");
myFile = SD.open("Airbox.txt", FILE_WRITE);
//while (option != 'y'){
Serial.println("Enter input for Airbox.info");
// break;
if(myFile) {
Serial.println("2");
if (counter >= 8){
Serial.println("3");
Serial.println("4");
Serial.println("erger");
counter++;
}else {
Serial.println("ret444");
counter++;
myFile.close();
if(dirFile.open("/", O_READ)){
Serial.println("SD card contains:");
while (file.openNext(&dirFile, O_READ)){
if(file.isHidden()){
}else{
file.printName(&Serial);
}file.close();
Serial.println("Would you like to erase files from the SD card (excluding AirBox.info)? (y/n): ");
int input = 3;
while(input != 110 && input != 121){
while(!Serial.available()){}
input = Serial.read();
if(input == 110){
Serial.println("Keeping files on the SD card");
}else{
Serial.println("Removing files from the SD card");
SdFile dirFile;
sd.initErrorHalt();
dirFile.open("/", O_READ);
int DeleteCount = 0;
int MaxNameSize = 30;
while(file.openNext(&dirFile, O_RDWR)){
}else{
char f_name[MaxNameSize+1];
file.getName(f_name,MaxNameSize);
f_name[MaxNameSize] = 0;
if(strcmp(f_name,"AirBox.info")){ //If file name is NOT "AirBox.info"
if(!file.remove()) Serial.println("Error file remove");
DeleteCount++;
}file.close();
}Serial.print("Deleted ");
Serial.print(DeleteCount);
Serial.println(" files.");
}else{
Serial.println("SD card empty");
void printDirectory (SdFile CFile, int numTabs, uint16_t dirIndex[300], int FileCount){
SdFile file;
while (file.openNext(&CFile, O_READ)){
if (file.isHidden()||false){
//file hidden, skip
else{
for (uint8_t i = 0; i < numTabs; i++){
Serial.print('\t');
if (file.isSubDir()){
SdFile SubDirFile;
//Serial.print(file.dirIndex());
//Serial.write(' ');
//file.printName(&Serial);
//Serial.println();
if(SubDirFile.open(&CFile, file.dirIndex(), O_READ)){
printDirectory(SubDirFile, numTabs+1, dirIndex, FileCount);
else{
// Save dirIndex of file in directory.
dirIndex[FileCount] = file.dirIndex();
// Print the file number and name.
FileCount++;
Serial.print(FileCount);
Serial.write(' ');
file.close();
Serial.println("RTC time:");
Clock.getDateTimeAll (Time); //update clock
char CurrentTime[] = {char(Time.Day / 10 + 48), char(Time.Day % 10 + 48), '-', char(Time.Month / 10 + 48), char(Time.Month % 10 + 48), '-', char(Time.Year / 10 + 48), char(Time.Year % 10 + 48),
'_', char(Time.Hour / 10 + 48), char(Time.Hour % 10 + 48), '-', char(Time.Minute / 10 + 48), char(Time.Minute % 10 + 48), '-', char(Time.Second / 10 + 48), char(Time.Second % 10 + 48)};
Serial.println(CurrentTime);
Thank you!
