Is there anyone who can give an explanation. Why I get a longer delay sometimes on PORTD,3 Normal delay should be 26 uS but sometimes 32 uS between high and low. I use a logic analyzer 10 mhz to test portd,3
int _1_bit_delay = 82;
DDRD = B00001000; // all indput
bitSet(PORTD, 3);
bitSet(PORTD, 3);
_delay_bit(_1_bit_delay);
bitClear(PORTD, 3);
I have tried first using timer micros() but there were even more delay errors. So I chose to make my own function delay but still sometimes get the error delay of 32 uS
bitSet(PORTD, 3);
void myLoop() {
bitSet(PORTD, 3);
bitClear(PORTD, 3);
int main()
setup();
while (1)
myLoop();
bitSet(PORTD, 3);
void myLoop() {
bitSet(PORTD, 3);
bitClear(PORTD, 3);
void _delay_bit(int d_bit){
int i = 0;
while(i < d_bit ){
asm volatile("nop");
i++;
It is not the hardware UART that is the problem. I'm writing a sketch where I have some "while" run with timeout so I can't even use interrupt or software serial, it causes too many delays in my sketch
const int rxPin = 2; // the number of the LED pin
const int txPin = 4; // the number of the LED pin
int _1h_bit_delay = 108;
//DDRC = B11101110;
bool timeout = false;
bool flag_ok = false;
void test_syn();
void test_idle();
void _delay_bit(int);
//ISR(TIMER1_COMPA_vect)
//timeout = true;
bitSet(PORTD, 3);
pinMode(rxPin, INPUT);
digitalWrite(rxPin, HIGH);
//cli(); // disable interrupts during setup
TCCR1A = 0;
TCCR1B = 0;
TCCR1B = 0<<WGM12 | 0<<CS12 | 0<<CS11 | 1<<CS10;
TCNT1 = 0; // reset Timer 1 counter
TIMSK1 = 1<<OCIE1A; // Enable Timer 1 interrupt
//sei(); // re-enable interrupts
//bitSet(PORTD, 3);
test_syn();
if(flag_ok == true)
test_idle();
if(flag_ok == true)
Serial.write(0x77);
int i = 0;
while(i < d_bit ){
i++;
void test_syn(){
flag_ok = false;
int i = 0;
TCNT1 = 22500; // timeout 2.7 ms
bitSet(TIFR1, TOV1); //clear TOV1 flag by putting HIGH at this bit position
while(bitRead(TIFR1, TOV1) != HIGH)
bitClear(PORTD, 3);
while(bitRead(PIND,rxPin) == 0) // wait for rx line go hig
if(bitRead(TIFR1, TOV1) == HIGH)
while(bitRead(PIND,rxPin) == 1) // wait for rx line go low for start bit of byte
//bitClear(PORTD, 3);
break; // timeout exit while
_delay_bit(_1h_bit_delay); // wait 1.5 bit time to center
int d = 0;
for (int j=8; j > 0; --j) // recive 8 bit
bitSet(PORTD, 3);
d >>= 1;
if(bitRead(PIND,rxPin) == 1)
d |= 0x80;
bitClear(PORTD, 3);
_delay_bit(_1_bit_delay); // wait 1 bit time
//Serial.write(d);
if(d == 0x55) // if 0x55 count up need 3 x 0x55
i++;
i = 0; // reset syn word counter
//Serial.write(i);
if (i == 3){ // Test if 3 syn word in row are recive
flag_ok = true;
bitSet(PORTD, 3);
void test_idle(){
flag_ok = false;
int i = 0;
bitSet(TIFR1, TOV1); //clear TOV1 flag by bitset
i = 0;
while(bitRead(PIND,rxPin) == 1){
i++;
bitClear(PORTD, 3);
if(i > 200){
flag_ok = true; // ilde ok
//if(timeout == true)
bitSet(PORTD, 3);
if(flag_ok == true )
@2000nico2000 how often/regularly does the badly timed pulse come along?
I am unable to recreate your results. I am using a cheap 24 MHz logic analyzer and TBH can't see the problem no matter the use of personal main() or no.
But it is like looking for a needle in a pinstack.
Have tried disconnecting the USB and using a different power supply for the nano board. now there is no delay error in my pulse sketch. But the error is still there in my second setup. Where I use two nano board one to simulate some signal, the other I am writing a sketch to capture signal from it first. I have common GND for both nano boards. I have tried a different power supply for that setup. Still the same problem. Still longer delay than expected sometimes. I use function delay between bitRead. I finish writing my sketch and see if it can work without errors. Thanks for trying to help me.
