Wrong frequency somehow
Hi all
I have a PCB I made with an ATmega328p onboard (TQFN I think is the footprint? - can never remember).
Added a 16mhz crystal with a pair of 22pf caps pulling the lines to ground... usual layout.
Programming it using an USBASP over SPI to program it. That all works fine.
But, using Pro Mini as I usually do in the Arduino IDE, with 328p 5v 16Mhz selected, the blink test routine is running VERY slowly.
Instead of blinking the led once a second, it's about once every 14 seconds.
Changed the crystal to a new 16Mhz, still the same, so not sure what I check next? It uploads code fine, just runs biblically slow.
Most likely, the divide by 8 fuse (CKDIV8) is still set. They come that way from the manufacturer, as documented in the data sheet.
:roll_eyes: Oh that sounds like fun....
Google time. Thanks!
Oh.... select UNO, press flash bootloader. Done
Thanks jremington
If you are going to be programming via ISP, and don't need the bootloader, MCUdude's Minicore has a no-bootloader option. May seem contradictory, but you still need to flash the bootloader with the no-bootloader setting in order to set the fuses correctly.
Does this free up any memory/space?
Using the no-bootloader option frees up the flash memory allocated for the bootloader (512 bytes on an UNO).
Is the problem with CPU Freq solved?
Yes problem solved. Thank you
