Wrong Password?
The following sketch is for a entry exit system.
The password should be set in serial monitor, then entry via a 44 matrix keyboard.
when setting the passcode serial monitor reports for example passcode set to 1234
I then enter 1234* on the matrix keyboard only to be told wrong even though it then reports the passcode is 1234*.
I can not see where I am going wrong, any help!
//  ||  Simple Password Entry Using Matrix Keypad
//* is to validate password
//# is to reset password attempt
#include <Password.h> //http://www.arduino.cc/playground/uploads/Code/Password.zip
#include <Keypad.h> //http://www.arduino.cc/playground/uploads/Code/Keypad.zip
String inputString = "";         // a string to hold incoming data
String inString = "";
Password password = Password(inString.toInt());
boolean stringComplete = false;  // whether the string is complete
const byte ROWS = 4; // Four rows
const byte COLS = 4; //  columns
// Define the Keymap
char keys[ROWS][COLS] = {
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins[ROWS] = {10, 9, 8, 7}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {6, 5, 4, 3};//connect to the column pinouts of the keypad
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
  keypad.addEventListener(keypadEvent); //add an event listener for this keypad
  keypad.getKey();
//take care of some special events
void keypadEvent(KeypadEvent eKey) {
  switch (keypad.getState()) {
    case PRESSED:
      Serial.print(eKey);
      switch (eKey) {
        case '*': checkPassword(); break;
        case '#': password.reset(); break;
        default: password.append(eKey);
void checkPassword() {
  if (password.evaluate()) {
    Serial.println("Success");
    //Add code to run if it works
    password.reset();
    Serial.println("Wrong");
    Serial.println(inString.toInt());
    //add code to run if it did not work
    // Read serial input:
    while (Serial.available() > 0) {
      int inChar = Serial.read();
      if (isDigit(inChar)) {
        // convert the incoming byte to a char
        // and add it to the string:
        inString += (char)inChar;
      // if you get a newline, print the string,
      // then the string's value:
      if (inChar == '*') {// If carriage return
        Serial.print("PassCode:");
        stringComplete = true;
        if (inChar == 'C') {
          inString = "";
        if (stringComplete) {
          Serial.print("Pin Set To : ");
          password.reset();
          password.set(inString.toInt());
          inString = "";
You never store any received characters into a char array to compare agsinst a known password. You only print.
Not familiar with the password library; assuming that it comes with examples, study them.
Call me thick, I am really finding it difficult to get my head round a char array.
How do I set up a char array to expect 6 digits starting # and ending * "#1234*"
Password password = Password(inString.toCharArray());
  keypad.getKey();
    case PRESSED:
      Serial.print(eKey);
      switch (eKey) {
    password.reset();
    Serial.println(inString.toCharArray());
      if (inChar == '#') {
        inString = "";
        if (inChar == '*') {  // If carriage return
          password.reset();
          password.set(inString.toCharArray());
          //inString = "";
Ok, I missed your default case in the switch so I'm probably the one that is thick :wink:
Sorry, as said no experience with the password library.
If it helps here are the password library files
Password.cpp
|| @file Password.cpp
|| @version 1.2
|| @author Alexander Brevig
|| @contact alexanderbrevig@gmail.com
||  4/5/2012 Updates Nathan Sobieck: Nathan@Sobisource.com
||   Now v1.2 Arduino IDE v1.0 With BAckwards compatibility
|| @description
|| | Handle passwords easily
|| @license
|| | This library is free software; you can redistribute it and/or
|| | modify it under the terms of the GNU Lesser General Public
|| | License as published by the Free Software Foundation; version
|| | 2.1 of the License.
|| | This library is distributed in the hope that it will be useful,
|| | but WITHOUT ANY WARRANTY; without even the implied warranty of
|| | MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
|| | Lesser General Public License for more details.
|| | You should have received a copy of the GNU Lesser General Public
|| | License along with this library; if not, write to the Free Software
|| | Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
#include "Password.h"
//construct object in memory, set all variables
Password::Password(char* pass){
 set( pass );
 reset();
//set the password
void Password::set(char* pass){
 target = pass;
//evaluate a string, is it equal to the password?
bool Password::is(char* pass){
 byte i=0;
 while (*pass && i<MAX_PASSWORD_LENGTH){
 guess[i] = pass[i];
 i++;
 return evaluate();
//append a char to the guessed password
bool Password::append(char character){
 if (currentIndex+1==MAX_PASSWORD_LENGTH){
 return false;
 }else{
 guess[currentIndex++] = character;
 guess[currentIndex] = STRING_TERMINATOR; //ensure a valid c string
 return true;
//reset the guessed password, one can guess again
void Password::reset(){
 currentIndex = 0;
//is the current guessed password equal to the target password?
bool Password::evaluate(){
 char pass = target[0];
 char guessed = guess[0];
 for (byte i=1; i<MAX_PASSWORD_LENGTH; i++){
 //check if guessed char is equal to the password char
 if (pass==STRING_TERMINATOR && guessed==STRING_TERMINATOR){
 return true; //both strings ended and all previous characters are equal
 }else if (pass!=guessed || pass==STRING_TERMINATOR || guessed==STRING_TERMINATOR){
 return false; //difference OR end of string has been reached
 //read next char
 pass = target[i];
 guessed = guess[i];
 return false; //a 'true' condition has not been met
//set password using operator =
Password &Password::operator=(char* pass){
 set( pass );
 return *this;
//test password using ==
bool Password::operator==(char* pass){
 return is( pass );
//test password using !=
bool Password::operator!=(char* pass){
 return !is( pass );
//append to currently guessed password using operator <<
Password &Password::operator<<(char character){
 append( character );
 return *this;
|| @changelog
|| | 2009-06-17 - Alexander Brevig : Added assignment operator =, equality operators == != and insertion operator <<
|| | 2009-06-17 - Alexander Brevig : Initial Release
*//code]
and
Password.h
[code]/*
|| @file Password.h
|| @version 1.2
|| @description
|| @license
|| | 2.1 of the License.
#ifndef PASSWORD_H
#define PASSWORD_H
// Arduino versioning.
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h" // for digitalRead, digitalWrite, etc
#else
#include "WProgram.h"
#endif
#define MAX_PASSWORD_LENGTH 20
#define STRING_TERMINATOR '\0'
class Password {
public:
 Password(char* pass);
 void set(char* pass);
 bool is(char* pass);
 bool append(char character);
 void reset();
 bool evaluate();
 //char* getPassword();
 //char* getGuess();
 //operators
 Password &operator=(char* pass);
 bool operator==(char* pass);
 bool operator!=(char* pass);
 Password &operator<<(char character);
private:
 char* target;
 char guess[ MAX_PASSWORD_LENGTH ];
 byte currentIndex;
#endif
|| @changelog
|| | 1.1 2009-06-17 - Alexander Brevig : Added assignment operator =, equality operators == != and insertion operator <<
|| | 1.0 2009-06-17 - Alexander Brevig : Initial Release
[/code]
  char someName[8];
What you expect to store in the array is completely irrelevant.
Your current password is an empty string. Not very secure.
  keypad.getKey();
Why do you bother reading the key that is pressed when you don't give a shit what key is pressed?
Reading serial data in the function to check the password is silly. You need to do that in setup() or loop().
The password library expects a char array that contains the valid password. If you change the password, the password library does NOT make a copy of the new password. It simply says "hey, the new password is over here". "Over here" being the current string wrapped by the String class is a REALLY bad idea.
Thank you for all your input
Now solved.
