Included a small Oled and bluetooth, but you can skip that:
#include <DS3231.h>
#include <Wire.h>
#include <EEPROM.h>
#include "SSD1306Ascii.h"
#include "SSD1306AsciiAvrI2c.h"
#include <SoftwareSerial.h>
#define Mode 2
#define Min 3
#define Plus 4
#define BT_TxD 6
#define BT_RxD 7
#define stripPIN 9
#define dotPIN 10
#define blauw 0x00001F
#define zwart 0x000000
#define rood 0x1F0000
#define stripCOUNT 28
#define dotCOUNT 2
SSD1306AsciiAvrI2c oled;
DS3231 Clock;
Adafruit_NeoPixel strip(stripCOUNT, stripPIN, NEO_RGB + NEO_KHZ800);
Adafruit_NeoPixel dot(dotCOUNT, dotPIN, NEO_GRB + NEO_KHZ800);
SoftwareSerial BlueTooth(6, 7); // (TXD, RXD) of HC-06
int i=0,j=0,k=0;
byte minuten,uren,seconden,datum,maand,jaar,maxdagen;
byte Digit_1,Digit_2,Digit_3,Digit_4,mode=0,flash=0,KleurNummer,helderheid=255;
bool h12,PM,century=false,schrikkeljaar,ShowDate=true,regenboog=false,Ambient=false,puntjes;
int delayval = 500; // delay for half a second
uint32_t DisplayColor;
float CurvePower = 2.5;
unsigned long previousMillisA = 0; // will store last time Flash
const long intervalA = 250; // interval at which to invert Flash
unsigned long previousMillisB = 0; // will store last time LED was updated
const long intervalB = 1000; // interval at which to blink (milliseconds)
unsigned long previousMillisC = 0; // Button SetMode last time read
const long intervalC = 500; // interval at which to read SetMode button
char input;
String SetText = "RUNNING.....",data,segment;
// BlueTooth.begin(9600);
Wire.setClock(400000L);
oled.begin(&Adafruit128x32,0x3C);
oled.setFont(Adafruit5x7);
pinMode(stripPIN, OUTPUT);
pinMode(dotPIN, OUTPUT);
pinMode(BT_RxD, OUTPUT); //Bluetooth RxD PIN
pinMode(BT_TxD, INPUT_PULLUP); //Bluetooth TxD PIN
pinMode(Mode, INPUT_PULLUP);
pinMode(Plus, INPUT_PULLUP);
pinMode(Min, INPUT_PULLUP);
Wire.begin();
strip.begin();dot.begin();
strip.show();dot.show();
// EEPROM.write(1, 255);
KleurNummer= EEPROM.read(0);
helderheid=EEPROM.read(1);
regenboog=EEPROM.read(2);
ShowDate=EEPROM.read(3);
Ambient=EEPROM.read(4);
if(Clock.getYear()%4==0)schrikkeljaar=true;
welkom();
if (BlueTooth.available())
input=(BlueTooth.read());
if (input != '#') {
data += input;
else{
String message_id = String(data.substring(0,1)); //gets only D or T
data.remove(0,1); //data becomes "50" since '!' is not added to data
if(message_id == "D"){
segment = String(data.substring(0,2));datum=segment.toInt();
segment= String(data.substring(2,4));maand=segment.toInt();
segment= String(data.substring(6,8));jaar=segment.toInt();
data="";
Clock.setDate(datum); Clock.setMonth(maand);Clock.setYear(jaar);
// Serial.print(datum);Serial.print("-");Serial.print(maand);Serial.print("-");Serial.println(jaar);
if(message_id== "T"){
segment = String(data.substring(0,2));uren=segment.toInt();
segment = String(data.substring(2,4));minuten=segment.toInt();
data="";
Clock.setMinute(minuten); Clock.setHour(uren);
// Serial.print(uren);Serial.print(":");Serial.println(minuten);
//Interval 1000ms
if (currentMillis - previousMillisB >= intervalB) {
previousMillisB = currentMillis;
datum=Clock.getDate();
maand=Clock.getMonth(century);
jaar=Clock.getYear();
puntjes=!puntjes;
if(puntjes)dot.fill(DisplayColor,0,2);else dot.fill(0,0,2);
dot.show();
//Interval 500ms
if (currentMillis - previousMillisC >= intervalC) {
previousMillisC = currentMillis;
if((seconden<2)&& ShowDate){
Digit_1= int(datum/10);
Digit_2= datum%10;
Digit_3= int(maand/10);
Digit_4= maand%10;
Digit_1= int(uren/10);
Digit_2= uren%10;
Digit_3= int(minuten/10);
Digit_4= minuten%10;
// DisplayColor=Spectrum(KleurNummer);
// strip.clear();
Segment();
strip.show();
//Interval 250ms
if (currentMillis - previousMillisA >= intervalA) {
previousMillisA = currentMillis;
ReadDS3231();
ButtonsSet();
if(regenboog){k=k+1; if(k>255)k=0;KleurNummer=k;} //KleurNummer=KleurNummer&0x7F;}
if(!digitalRead(Mode))delay(10);
if(!digitalRead(Mode)) mode = mode + 1;
if(mode > 10)mode = 0;
while(!digitalRead(Mode)){}
strip.clear();
printOLED();
void ReadDS3231(){
uren=Clock.getHour(h12, PM);
minuten=Clock.getMinute();
seconden=Clock.getSecond();
void welkom(){
oled.clear();
oled.set2X();
oled.println(" JUMBO LED");
oled.set1X();
oled.println(" made in Fryslan ");
oled.println(" by TechGraphix ");
strip.clear();strip.setPixelColor(5,DisplayColor);strip.setPixelColor(12,DisplayColor);strip.setPixelColor(19,DisplayColor);strip.setPixelColor(26,DisplayColor);strip.show();
delay(500);strip.clear();
strip.setPixelColor(0,DisplayColor);strip.setPixelColor(7,DisplayColor);strip.setPixelColor(14,DisplayColor);strip.setPixelColor(21,DisplayColor);strip.show();
strip.setPixelColor(2,DisplayColor);strip.setPixelColor(9,DisplayColor);strip.setPixelColor(16,DisplayColor);strip.setPixelColor(23,DisplayColor);strip.show();
strip.setPixelColor(4,DisplayColor);strip.setPixelColor(3,DisplayColor);strip.setPixelColor(27,DisplayColor);strip.setPixelColor(22,DisplayColor);strip.show();
strip.setPixelColor(1,DisplayColor);strip.setPixelColor(6,DisplayColor);strip.setPixelColor(25,DisplayColor);strip.setPixelColor(24,DisplayColor);strip.show();
strip.setPixelColor(10,DisplayColor);strip.setPixelColor(11,DisplayColor);strip.setPixelColor(20,DisplayColor);strip.setPixelColor(15,DisplayColor);strip.show();
strip.setPixelColor(8,DisplayColor);strip.setPixelColor(13,DisplayColor);strip.setPixelColor(18,DisplayColor);strip.setPixelColor(17,DisplayColor);strip.show();
delay(500);strip.clear();strip.show();oled.clear();
void printOLED(){
switch (mode){
case 0: printtijd();printdatum();break;
case 1: printtijd();oled.println("SET HOURS ");break;
case 2: printtijd();oled.println("SET MINUTS");break;
case 3: printtijd();oled.println("RESET SECS");break;
case 6: oled.setCursor(0,0);printdatum();oled.println(" SET DATE ");break;
case 5: oled.setCursor(0,0);printdatum();oled.println("SET MONTH ");break;
case 4: oled.setCursor(0,0);printdatum();oled.println(" SET YEAR ");break;
case 7: oled.setCursor(0,0);oled.println("RAINBOW ");if(regenboog)oled.print("CYCLE ON");else oled.print("CYCLE OFF");break;
case 8: oled.setCursor(0,0);oled.println("SET COLOR ");oled.print(" ");oled.print(KleurNummer);oled.println(" ");break;
case 9: oled.setCursor(0,0);oled.println("DISP. DATE");if(ShowDate){oled.println("SHOW DATE");} else oled.println("ONLY TIME");break;
case 10: oled.setCursor(0,0);oled.println(" AMBIENT ");if(Ambient){oled.println(" AMBI- ON");} else oled.println(" AMBI-OFF");break;
void printdatum(){
oled.set2X();
oled.print(" ");
if(datum<10)oled.print("0");
oled.print(datum);
oled.print("-");
if((maand)<10)oled.print("0");
oled.print(maand);
oled.print("-");
if((jaar)<10)oled.print("0");
oled.println(jaar);
void printtijd() {
oled.set2X();
oled.print(" ");
if(uren<10)oled.print("0");
oled.print(uren);
oled.print(":");
if((minuten)<10)oled.print("0");
oled.print(minuten);
oled.print(":");
if((seconden)<10)oled.print("0");
oled.println(seconden);
void Segment(){
switch(Digit_1){
case 0 : nul(0);break;
case 1 : een(0);break;
case 2 : twee(0);break;
case 3 : drie(0);break;
default : nulll(0);break;
switch(Digit_2){
case 0 : nul(1);break;
case 1 : een(1);break;
case 2 : twee(1);break;
case 3 : drie(1);break;
case 4 : vier(1);break;
case 5 : vijf(1);break;
case 6 : zes(1);break;
case 7 : zeven(1);break;
case 8 : acht(1);break;
case 9 : negen(1);break;
default : nulll(1); break;
switch(Digit_3){
case 0 : nul(2);break;
case 1 : een(2);break;
case 2 : twee(2);break;
case 3 : drie(2);break;
case 4 : vier(2);break;
case 5 : vijf(2);break;
default : nulll(2); break;
switch(Digit_4)
case 0 : nul(3);break;
case 1 : een(3);break;
case 2 : twee(3);break;
case 3 : drie(3);break;
case 4 : vier(3);break;
case 5 : vijf(3);break;
case 6 : zes(3);break;
case 7 : zeven(3);break;
case 8 : acht(3);break;
case 9 : negen(3);break;
default : nulll(3);break;
void nul(int a){
i=a*7;
strip.setPixelColor(i,zwart);
strip.fill(DisplayColor,i+1,6);
void een(int a){
i=a*7;
strip.setPixelColor(i+1,DisplayColor);
strip.fill(zwart,i+2,4);
strip.setPixelColor(i+6,DisplayColor);
void twee(int a){
i=a*7;
strip.setPixelColor(i,DisplayColor);
strip.setPixelColor(i+1,zwart);
strip.fill(DisplayColor,i+2,2);
strip.setPixelColor(i+4,zwart);
strip.fill(DisplayColor,i+5,2);
void drie(int a){
i=a*7;
strip.fill(DisplayColor,i,3);
strip.fill(zwart,i+3,2);
void vier(int a){
i=a*7;
strip.fill(DisplayColor,i,2);
strip.fill(zwart,i+2,2);
strip.setPixelColor(i+4,DisplayColor);
strip.setPixelColor(i+5,zwart);
void vijf(int a){
i=a*7;
strip.setPixelColor(i+3,zwart);
strip.fill(DisplayColor,i+4,2);
strip.setPixelColor(i+6,zwart);
void zes(int a){
i=a*7;
strip.fill(DisplayColor,i,6);
void zeven(int a){
i=a*7;
strip.fill(zwart,i+2,3);
void acht(int a){
i=a*7;
strip.fill(DisplayColor,i,7);
void negen(int a){
i=a*7;
strip.fill(DisplayColor,i+4,3);
void nulll(int a){
i=a*7;
strip.fill(zwart,i,7);
uint32_t Spectrum(uint8_t SpectrumPos) {
byte rx,gx,bx;
if(SpectrumPos < 85) {
rx=255 - SpectrumPos * 3; gx=0; bx=SpectrumPos * 3;
return Color(rx, gx,bx );
if(SpectrumPos < 170) {
SpectrumPos -= 170;
rx=0; gx=SpectrumPos * 3; bx= 255 - SpectrumPos * 3;
return Color(rx,gx ,bx );
SpectrumPos -= 170;
rx=SpectrumPos * 3; gx=255 - SpectrumPos * 3; bx= 0;
return Color(rx ,gx, bx);
uint32_t Color(byte r, byte g, byte b)
uint32_t c;
c = r;
c <<= 8;
c |= g;
c <<= 8;
c |= b;
return c;
void ButtonsSet(){
int tempset; //void
switch(mode)
case 0:
if(!digitalRead(Plus) && (!flash)){
helderheid=helderheid+1;
if(helderheid>254)helderheid=254;
if(!digitalRead(Min) && (!flash)){
helderheid=helderheid-1;
if(helderheid <1)helderheid=1;
strip.setBrightness(helderheid);dot.setBrightness(helderheid);
EEPROM.write(1, helderheid);
case 1:
tempset = Clock.getHour(h12, PM);
tempset = tempset + 1;
if(tempset > 23){tempset = 0;}
Clock.setHour(tempset);
if (tempset == 0){tempset = 23;} else tempset = tempset - 1;
case 2:
tempset =Clock.getMinute();
if(tempset > 59){tempset = 0;}
Clock.setMinute(tempset);
if (tempset == 0){tempset = 59;}else tempset = tempset - 1;
case 3:
Clock.setSecond(0);}
Clock.setSecond(0);
// EEPROM.write(0,KleurNummer);
case 4:
tempset =Clock.getYear();
if(tempset > 99){tempset = 0;}
Clock.setYear(tempset);
if (tempset < 0){tempset = 99;}else tempset = tempset - 1;
schrikkeljaar=false;
if(tempset%4==0)schrikkeljaar=true;
case 5:
tempset =Clock.getMonth(century);
if(tempset > 12){tempset = 1;}
Clock.setMonth(tempset);
if (tempset <1 ){tempset = 12;}
switch(tempset){
case 1: case 3: case 5: case 7: case 8: case 10: case 12: maxdagen = 31; break;
case 2: maxdagen= 28; if(schrikkeljaar)maxdagen++; break;
case 4: case 6: case 9: case 11: maxdagen = 30; break;
// Serial.println(maxdagen);
case 6:
tempset =Clock.getDate();
if(tempset > maxdagen){tempset = 1;}
Clock.setDate(tempset);
if (tempset < 1)tempset = maxdagen;
case 7:
regenboog=true;
EEPROM.write(2, regenboog);
regenboog=false;
case 8: if(regenboog){ mode=9;break;}
KleurNummer = KleurNummer + 1;
if(KleurNummer > 255){KleurNummer = 0;}
if (KleurNummer == 0){KleurNummer = 255;}else KleurNummer = KleurNummer - 1;
DisplayColor = Spectrum(KleurNummer);
case 9:
ShowDate=true;
EEPROM.write(3, ShowDate);
ShowDate=false;
case 10:
Ambient=true;
EEPROM.write(4, Ambient);
Ambient=false;
