Hi
I have a WS2812B RGB Led Strip. I want to cotrol my led strip from PC, what i mean is to controll it by serial port monitor. Can i do this by digitalWrite(); command or sth ? I want to controll each diod separately. What I mean control is to Set it OF or ON, set parameters of color R,G,B.
Have anyone some idea how to run my Led strip by Serial port monitor ?
Thank you in advance
No. Those LEDs require a fast, precise pulse train, which is beyond the capabilities of a digitalWrite function call.
You can not do this direct from the Serial port monitor, you need to put an Arduino between your PC and the LED strip. You might know this but it did not come across in your post.
So assuming you have an Arduino then look at the serial port examples in the IDE. Also look at the examples in the fastLED libiary.
Then try the examples and finally when you understand what you are doing write code that does exactly what you want to do.
Thanks for answer. Of course i want to have connection with Arduino PC -> Arduino-> Led Strip.
I was looknig to fastLED library and made some simple code :
#include "FastLED.h"
#define NUM_LEDS 20
#define DATA_PIN 3
CRGB leds[NUM_LEDS];
int r;
int g;
int b;
delay(2000);
FastLED.addLeds<WS2812B, DATA_PIN, GRB>(leds, NUM_LEDS);
r=255;
g=0;
b=0;
while (Serial.available() == 0);
int val = Serial.read() - '0';
Serial.println(val);
leds[val] = CRGB(r,g,b);
FastLED.show();
Now i can control first 9 Leds, and have a problem with controllig rest of Led on my strip. When i write for example diod number 24 it turns On diode nummber 2 and nummber 4, so it works only for Diodes from nummber 0 -9. How to cotrol rest of them ?
You get the characters one at a time from the serial port. To get a number from several characters you have to do a bit more work, see Serial Input Basics - Programming Questions - Arduino Forum
Also
Please read this:-
How to use this forum
Because your post is breaking the rules about posting code.
Thanks it helps me a lot, but i have already one problem. My code works only whent i enter data in this style <text,value d,value r,value g,value b>,
i want to enter data without this text part:
<value d,value r,value g,value b>
Here is my code:
#define NUM_LEDS 144
#define DATA_PIN 3
const byte numChars = 32;
char receivedChars[numChars];
char tempChars[numChars]; // temporary array for use when parsing
// variables to hold the parsed data
char messageFromPC[numChars] = {0};
int d = 0;
int r = 0;
int g = 0;
int b = 0;
boolean newData = false;
FastLED.clear ();
Serial.println("Enter data in this style <text,int d,int r,int g,int b> ");
recvWithStartEndMarkers();
if (newData == true) {
strcpy(tempChars, receivedChars);
// this temporary copy is necessary to protect the original data
// because strtok() used in parseData() replaces the commas with \0
parseData();
showParsedData();
newData = false;
void recvWithStartEndMarkers() {
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = '<';
char endMarker = '>';
char rc;
while (Serial.available() > 0 && newData == false) {
rc = Serial.read();
if (recvInProgress == true) {
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
else if (rc == startMarker) {
recvInProgress = true;
void parseData() { // split the data into its parts
char * strtokIndx; // this is used by strtok() as an index
strtokIndx = strtok(tempChars, ","); // get the first part - the string
strcpy(messageFromPC,strtokIndx); // copy it to messageFromPC
strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
d = atoi(strtokIndx); // convert this part to an integer
d=d/5;
r = atoi(strtokIndx); // convert this part to an integer
g = atoi(strtokIndx); // convert this part to an integer
b = atoi(strtokIndx); // convert this part to an integer
void showParsedData() {
FastLED.clear ();
delay(250);
leds[d-1] = CRGB(r,g,b);
leds[d] = CRGB(r,g,b);
How can i change/delete this text part from char to int ??
Try removing these two lines
When I remove those two lines it does not work properly. I enter data like this : <25,255,255,255> and also like <text,25,255,255,255>. Any diod turns on ...
I print at the end all the values d , r, g and b and they all have value 0
Make the next line not
But
