I got a MPU 6050 connected to a RPi. The RPi reads the MPU 6050 does some math and sends DC servo torque data to a Arduino Mega. The Arduino Mega, sends formatted torque info to X and Y DC servos to keep a platform 'level' The system works fairly well.
That thing I been looking at to 'fix' is that the DC servos do not handle degree increments of less than 1 degree.
I been toying with the idea of using a dc motor geared to 2 or 3 degrees per min to see if I can bring the X Y platform down to .2 of a degree or less off level. Perhaps, I'll only get .5 degree off level but I'll not know till I give it a try.
Is there a way to cause the DC Servos to move in increments of less than 1 degree?
I am, also, open to suggestions about what would be a good DC motor controller to use with the Arduino Mega that would be home hobbyist suitable for such a project?
Consider replacing the servos you have with better ones, that offer higher resolution.
Most do, you control it with the writeMicroseconds function of the servo libiary.
According to Servo.h the pulse width is between 544 and 2400 µs. I do not fully understand Servo.cpp, but I think that a 2 MHz base frequency is used and a pulse every 20 ms.
Then a 16-bit timer uses 40000 counts for 20ms and the period between 544 and 2400 µs has 3712 counts. With 180 degrees full scale that is 0.05° accurate.
I'm not sure if my calculations are okay
If they are okay, that is more than the integer accuracy for the degrees of the Arduino function.
However, I can not find a library that uses this.
I suppose that the Servo.writeMicroseconds() will calculate the best Timer value for the pulse in microseconds. That calculation rounds to the nearest timer value. The 544 to 2400 µs are a span of 1856 µs, that is 0.1° accurate. Perhaps 0.15° due to calculation rounding.
It seems that for now you should try the Servo.writeMicroseconds().
I will most certainty give Servo.writeMicroseconds() a try. Thanks.
Idahowalker:
Are you sure there is not an error at some place in your code which is unintentionally truncating to 1 degree?
I been using servo.write() which I was under the impression took, as an argument, an int representing a whole number degree.
I changed my X servo to use servo.writeMicroseconds(). After doing a few relational math tweaks, on the Raspberry Pi side, I got the X Gyro bouncing around 0 degrees, with the X servo being tweaked by servo.writeMicroseconds(). I am really liking this change.
I'll watch, for a day or two, the results, perhaps a refinement here and there, before applying the change to the Y servo.
I've yet to determine the +/- mean X Gyro bounce around zero; that will take a bit of time.
Thanks for the heads up on servo.writeMicroseconds().
