Howdy y'all,
Heres some code I found really handy. This sketch turns your arduino w attached xBee into a loopback device for X-CTU's loopback test. It uses newSoftSerial to make a second serial port on pins 2&3, and uses pin 4 for flow control, specifically the CTS line (pin DIO7 on the xBee).
#include "NewSoftSerial.h"
#define CTS 4
NewSoftSerial xbeeSerial = NewSoftSerial(2, 3);
char data[220];
byte ctsStatus;
pinMode(13, OUTPUT);
pinMode(CTS,INPUT);
Serial.println("Arduino Console");
xbeeSerial.begin(9600);
xbeeSerial.println("xBee Port");
int i = 0;
data[0] = 0;
while (xbeeSerial.available())
{ //read the aether
data[i] = (char) xbeeSerial.read();
Serial.print(data[i], BYTE);
i++;
ctsStatus = digitalRead(CTS);
if (ctsStatus == 0) // inverse logic, we are clear on 0
for (int j = 0; (i != j); j++)
{ // spray it back
Serial.print(data[j], BYTE);
xbeeSerial.print(data[j], BYTE);
