XBee - Problem with sending Remote AT commands [resolved]
Hello,
I am trying to remotely control digital I/O pins on a XBee from an Arduino Uno. I am using 2 Series 1 Xbees, a Xbee Explorer, and a Xbee Arduino shield. The Xbee attached to the Arduino has its API mode disabled, while the remote XBee's API mode is enabled.
I am using a program, shown in this video tutorial, that will send a frame, toggling DIO pin 3 high or low. When I try to send a remote AT command frame, it is displayed in XCTU as a RX Packet 16-bit address, instead of an AT command. I noticed that there are 8 bytes before my desired frame, and one byte right after it, as shown in the attached image. Correspondingly, DIO 3 of the remote XBee is not set to high or low when viewed in XCTU. This is the code for the Arduino, also from the video tutorial:
//code by tunnelsup
//youtube tutorial: https://www.youtube.com/watch?v=CzH146rR-7I
//toggles local LED and remote XBee LED on and off
int led = 13;
void setup(){
  pinMode(led, OUTPUT);
void loop(){
  digitalWrite(led, HIGH);
  setRemoteState(0x5);
  delay(5000);
  digitalWrite(led, LOW);
  setRemoteState(0x4);
  delay(5000);
void setRemoteState (char value){
  Serial.write(0x7E); //start byte
  Serial.write((byte)0x0); //high part of length (always zero)
  Serial.write(0x10);  //low part of length
  Serial.write(0x17); //0x17 is remote AT command
  Serial.write((byte)0x0);  //frame ID set to zero for no reply
  //ID of recipient, or use 0xFFFF for broadcast
  Serial.write(0xFF);
  Serial.write(0xFF);
  //16 bit of recipient of 0xFFFE
  Serial.write(0xFF);
  Serial.write(0xFE);
  Serial.write(0x02);
  //command name in ASCII character
  Serial.write('D');
  Serial.write('3');
  //command data in as many bytes
  Serial.write(value);
  //checksum
  long sum = 0x17 + 0xFF + 0xFF + 0xFF + 0xFE + 0x02 + 'D' + '3' + value;
  Serial.write(0xFF - (sum & 0xFF));
I feel that there might be a setting that I am missing, since it appears that everything sent to the remote Xbee is interpreted as a RX packet.
I appreciate any help. Thanks!
Does anyone know how to solve this issue?
I got it! I followed this tutorial from Digi:
http://www.digi.com/blog/community/xbee-broadcast-tech-tip-using-remote-at-commands-to-toggle-an-io/
Hi Valhalah
I have the same problem.
I Followed the tutorial from Digi and it works fine, but if i wont to use those AT Command and send to my coordinator from my arduino like the yputube tutorial, the command do not work.
Can you help my?
Hey Oscaroto,
Are you using a series 1 or series 2 XBee? I was using Series 1 Xbees, but I believe the YouTube tutorial was using Series 2 XBees.
