I have been trying to figure out how to make my controller shoot rapid fire in Call of Duty but it doesn't seem to work with the scripts I found.
This is my controller. Those three solid core wires are soldered each to three pins inside the controller. It doesn't show in the pictures but the first wire goes into the ground pin and the black one goes into 2 pin. In the tutorial I saw, the guy had a little button that he soldered to activate the rapid fire.
I am using two scripts I have found but none of them seem to make me shoot rapid fire.
Here are the scripts:
int val = 0; // stores values of the digitalread of the button
int button = 4; // positive leg of buttton connected fromm 3.3v to pin 4
int shoot = 2; // positive wire comming form the trigger/button on xbox controller
void setup() { // setting pinmode and starting serial connection
Serial.begin (9600);
pinMode ( button, INPUT);
pinMode (shoot,OUTPUT);
val = digitalRead (button); // reading button storing value
Serial.println (val); // just checking make sure button works
if (val == HIGH) { // if button is pressed
digitalWrite (shoot,HIGH); // needs to go high then low inorder
digitalWrite (shoot,LOW);// to fool conntroller
val = LOW; // resting val
and the other is
int button = 4; //The pin to connect one leg of the button (the other goes to ground)
int val1 = 0; //variable used to read the button
int shoot = 2; //The pin to econnect to the "middle" pin of the trigger pot on the controller
int led=13; //onboard arduino led pin
//setup the pins for in/out
pinMode (button,INPUT);
pinMode(led, OUTPUT);
digitalWrite(shoot,HIGH); //set the trigger to high as default (this is off)
val1 = digitalRead (button); //read the button
if ( val1 == HIGH ) { //iff the button is pressed
digitalWrite ( shoot,LOW); //set the trigger to low (this is on)
delay(50); //wait 50 milliseconds
digitalWrite (shoot,HIGH); //set the trigger to back to high (this is of)
delay(35); //wait 35 milliseconds
if ( val1 == LOW ) delay (50); //not needed, I think I added this out of habbit to not consume 100% cpu lol... (this doesnt matter with arduino)
digitalWrite(led,val1); //write the value of the button, to the led (so we can see whats going on)
Although I don't have rapid fire, there is still a connection that is being made because sometimes I start shooting without even touching the controller.
I followed this tutorial http://www.instructables.com/id/Mod-Xbox-360-Controller-Using-Arduino-MW3/?ALLSTEPS
Any suggestions? Thank you.
