Yamaha Midi Out -> Arduino Uno
I've made a simple project that sends Midi output from a keyboard to a USB host shield stacked on an Arduino UNO. This then sends a signal to a WS2182B LED strip and succesfully lights up the corresponding light. So pressing Middle C lights up one of the LEDs in the middle of the strip.
I tested this with an M-AUDIO keystation 49e keyboard and it worked great!. Then I swapped it with a Yamaha Arius YDP-142 keyboard. Windows detects the keyboard in device manager and recieves signals in MIDI OX software but for some reason not via the UNO.
^This is the MIDI guide for the arius. Has anyone else had a similar issue with Yamaha keyboard midi programs?
Here's the hardware: USB Host shield stacked on UNO. Dig pin 6 -> LED strip. Powered by 5v PSU. Yamaha Arius YDP142 piano
Here's my code:
#include <Usb.h>
#include <usbh_midi.h>
#define PIN 6
#define NUM_LEDS 120
// Create NeoPixel strip object
Adafruit_NeoPixel strip(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
USB Usb;
USBH_MIDI Midi(&Usb);
const char* noteNames[] = {
  "C", "C#", "D", "D#", "E", "F", "F#", "G", "G#", "A", "A#", "B"
// Map MIDI note to LED index
int noteToLEDIndex(int note) {
  if (note < 21 || note > 108) return -1;
  return (int)((note - 21) * (NUM_LEDS - 1) / (108 - 21));
// Array to track active notes
bool activeNotes[88]; // MIDI notes 21-108
bool deviceConnected = false; // track device connection status
// For note flashing
unsigned long flashWhiteEndTime = 0;
bool flashingWhite = false;
// For connect/disconnect flash
void flashColor(uint8_t r, uint8_t g, uint8_t b) {
  for (int i = 0; i < NUM_LEDS; i++) {
    strip.setPixelColor(i, strip.Color(r,g,b));
  strip.show();
  delay(300);
  // Turn off after flash
    strip.setPixelColor(i, 0);
  strip.show();
// Flash white briefly when note pressed
void flashWhite() {
    strip.setPixelColor(i, strip.Color(255,255,255));
  strip.show();
  flashingWhite = true;
  flashWhiteEndTime = millis() + 100; // flash for 100ms
void initActiveNotes() {
  for (int i = 0; i < 88; i++) activeNotes[i] = false;
  while (!Serial);
  Serial.println("Starting MIDI monitor...");
  if (Usb.Init() == -1) {
    Serial.println("USB Host Shield did not start");
    while (1);
  Serial.println("USB Host started");
  strip.begin();
  strip.show(); // all off
  // Flash blue for 2 seconds on startup
  for (int i=0; i<NUM_LEDS; i++) {
    strip.setPixelColor(i, strip.Color(0,0,255));
  strip.show();
  delay(2000);
  initActiveNotes();
  Usb.Task();
  // Detect device connect/disconnect
  bool prevConnected = deviceConnected;
  deviceConnected = (bool)Midi; // if Midi object is valid
  if (deviceConnected && !prevConnected) {
    // Device just connected
    Serial.println("Device connected");
    flashColor(0, 255, 0); // green flash
  } else if (!deviceConnected && prevConnected) {
    // Device just disconnected
    Serial.println("Device disconnected");
    flashColor(255, 0, 0); // red flash
  bool noteChanged = false;
  if (Midi) {
    uint8_t buffer[64];
    uint16_t bytesReceived = 0;
    uint8_t result = Midi.RecvData(&bytesReceived, buffer);
    if (result == 0 && bytesReceived > 0) {
      for (uint16_t i=0; i<bytesReceived;) {
        if (buffer[i] >= 0x80) {
          uint8_t status = buffer[i];
          if (((status & 0xF0) == 0x90) || ((status & 0xF0) == 0x80)) {
            if (i+2 < bytesReceived) {
              uint8_t note = buffer[i+1];
              uint8_t velocity = buffer[i+2];
              int noteIndex = note - 21;
              if (noteIndex >=0 && noteIndex < 88) {
                if ((status & 0xF0) == 0x90 && velocity > 0) {
                  // note on
                  activeNotes[noteIndex] = true;
                  Serial.print("Note ON: ");
                  Serial.println(getNoteName(note));
                  flashWhite(); // flash white when pressed
                  noteChanged = true;
                  // note off
                  activeNotes[noteIndex] = false;
                  Serial.print("Note OFF: ");
                  noteChanged = true;
                i += 3;
                i++;
              break; // incomplete message
            i++;
          i++;
  if (noteChanged) {
    // Update LEDs based on activeNotes
    for (int i=0; i<88; i++) {
      if (activeNotes[i]) {
        turnOnLED(noteToLEDIndex(i+21));
        turnOffLED(noteToLEDIndex(i+21));
    strip.show();
  // Handle white flash timing
  if (flashingWhite && millis() > flashWhiteEndTime) {
    // turn off white flash
    for (int i=0; i<NUM_LEDS; i++) strip.setPixelColor(i, 0);
    strip.show();
  delay(10);
void turnOnLED(int index) {
  if (index >= 0 && index < NUM_LEDS) {
    strip.setPixelColor(index, strip.Color(255, 0, 0));
void turnOffLED(int index) {
    strip.setPixelColor(index, 0);
String getNoteName(int note) {
  int octave = (note / 12) - 1;
  int noteIndex = note % 12;
  return String(noteNames[noteIndex]) + String(octave);
