However, during playback, I get repeated clicking sounds. This has been tested with a DAC with the same chipset as suggested in the article, as well as with others: always the same result.
Also, when using alsa directly (aplayer), I get the same results with wav files of different sample rates stored on the sd-card.
aplay /mnt/sd/samples/piano2.wav
Anyone have any idea what might be causing this?
To me everything seems to point to the USB-interface dropping packets, but I do not know how to be sure of this or how to solve it... or am I missing something?
We did that, it did improve the audio but did not completely remove this specific crackle. The only solution (for us) was to reduce the audio quality in the mp3 to 32k, 44.1kHz, mono. Then it does work.
I recently added new function in my Yun based project and I have a little .mp3 file that yun plays when i touch a button.. The mp3 is 3 seconds long but if I push the button while mp3 is playing, nothing append !!!
Actually I use madplay and I would to use other application... i found this site but i can't install MPD..
I did opkg update and then opkg install mpd, the download starts, but at the end i get an error: the package can't be installed.
What is wrong ?
There's another way to solve my problem ? The perfect "theorical" way is if exist a madplay command that stops playing mp3 to replay the mp3 from its begin..
mpd-full - 0.16.5-2 - Music Player Daemon (MPD) is a flexible, powerful, server-side application for playing music. It is typically controlled over a network using one of it's many clients including mpc (console), gmpc (gnome), phpmp (php), etc... . This package contains a full-blown Music Player Daemon.
mpd-mini - 0.16.5-2 - Music Player Daemon (MPD) is a flexible, powerful, server-side application for playing music. It is typically controlled over a network using one of it's many clients including mpc (console), gmpc (gnome), phpmp (php), etc... . This package contains a minimal Music Player Daemon, with support for only Flac, MP3 & OGG media types & only file: & http: protocols.
