Hello All,
I bricked one of my Yuns and used an AVRISP mkII to reload the bootloader. I can now boot it and upload sketches to it but I can not access it via the ethernet port. I loaded the YunSerialTerminal and was going to try and restore it to factory defaults, but I can never get to the fail-safe mode. So I went through the process of reflashing decribed at
Now when I reboot, I get hung at:
Starting kernel ...
[ 0.000000] Linux version 3.3.8 (build@build-base) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #1 Tue Oct 14 15:28:09 CEST 2014
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 00019374 (MIPS 24Kc)
[ 0.000000] SoC: Atheros AR9330 rev 1
[ 0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 04000000 @ 00000000 (usable)
[ 0.000000] User-defined physical RAM map:
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone PFN ranges:
[ 0.000000] Normal 0x00000000 -> 0x00004000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00004000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyS0,115200 root=31:02 rootfstype=squashfs init=/sbin/init mtdparts=ar7240-nor0:256k(u-boot),64k(u-boot-env),14656k(rootfs),1280k(uImage),64k(NVRAM),64k(ART) mem=64M rootfstype=squashfs,jffs2 noinitrd
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 61004k/65536k available (2416k kernel code, 4532k reserved, 686k data, 216k init, 0k highmem)
[ 0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:256
[ 0.000000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
[ 0.080000] pid_max: default: 32768 minimum: 301
[ 0.080000] Mount-cache hash table entries: 512
[ 0.080000] NET: Registered protocol family 16
[ 0.090000] gpiochip_add: registered GPIOs 0 to 29 on device: ath79
[ 0.090000] MIPS: machine is Generic AR71XX/AR724X/AR913X based board
[ 0.110000] bio: create slab at 0
[ 0.120000] Switching to clocksource MIPS
[ 0.120000] NET: Registered protocol family 2
[ 0.120000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.130000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.130000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.130000] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.130000] TCP reno registered
[ 0.130000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.140000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.140000] NET: Registered protocol family 1
[ 0.160000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.160000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.170000] msgmni has been set to 119
[ 0.170000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.170000] io scheduler noop registered
[ 0.180000] io scheduler deadline registered (default)
[ 0.180000] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.190000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11) is a AR933X UART
[ 0.200000] TCP cubic registered
[ 0.200000] NET: Registered protocol family 17
[ 0.210000] Bridge firewalling registered
[ 0.210000] 8021q: 802.1Q VLAN Support v1.8
[ 0.210000] turn off boot console early0
Any ideas on how I can get the Yun back to factory defaults?
Thanks in advance,
Murrah Boswell
