Someone help me connect my ZA620_M5 fingerprint with Arduino uno,
I have tried what is provided at (Basic Fingerprint Sensor With Socket Header Cable : ID 4690 : $19.95 : Adafruit Industries, Unique & fun DIY electronics and kits ) without success,
Running the code shows Did not find fingerprint sensor
The images below shows the scanner and my connection, with the errors
awneil
September 20, 2023, 12:26pm
2
Thank you for reply, I tried following but seems the sensors are different, mine is eight-pin while the one you have provided link for 6 pin...
The description provided for the eight-pin sensor is as
1 Vi Module power supply positive input terminal.
2 Tx Rate line data output TTL logic level
3 Rx Serial data input. TTL logic level
4 GND signal ground. Internally connected to power ground
5 WAK sensing signal output high level is active by default
6 Vi Touch induction power input terminal, 3 - 65V power supply ____
awneil
September 20, 2023, 2:37pm
4
It is the link that you provided:
So where did you get the sensor that you actually have?
Have you contacted them for support?
Please give a link
Yes, I buy from AliExpress..
I ask for support, I receive a document written in Chinese, some Important information I was able to get is what I sent you
I use google translate to extract information...
Regards
awneil
September 20, 2023, 3:52pm
6
jmuthoni2000:
This is what you get when you do that!
If you want stuff with decent support & documentation, Adafruit et al are the places to go!
Thank you, I bought another fingerprint sensor that is detected by arduino, but I am not able to register a fingerprint, this is my output logs
22:55:17.818 -> Ready to enroll a fingerprint!
22:55:17.851 -> Please type in the ID # (from 1 to 127) you want to save this finger as...
22:55:27.452 -> Enrolling ID #1
22:55:27.452 -> Waiting for valid finger to enroll as #1
22:55:27.486 -> .
22:55:27.486 -> .
22:55:27.523 -> .
22:55:27.523 -> .
The timestamp is not ending, even after I place my fingerprint on the sensor
system
Closed
April 28, 2024, 8:02pm
8
