error compiling
hi all,
i try to run my teacher codes for my homework.
when i open it, the code doesnt seem working neither verify nor upload. i pretty sure no problem with the port or cable because i tried with another code and it worked just well.
could someone please help?
thanks
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
\claudius.science.mq.edu.au\44613156.Desktop\Smart_City_Client_3_Final_Hopefully_\Smart_City_Client_3_Final_Hopefully_.ino:11:21: fatal error: RH_RF95.h: No such file or directory
#include <RH_RF95.h>
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
here is my code:
#include <String.h>
#include <TimerOne.h>
// Hardware configuration ////////////////////////////////////////////////////////
int PIR1 = A0; // the pin that the sensor is atteched to
int PIR2 = A1;
int PIR3 = A2;
int state = LOW; // by default, no motion detected
int sam, isam; int state1 = LOW, state2 = LOW;
// Variable declaration ******************************************************
#define MINUTE_VALUE 1
int i = 0; // variable to store the sensor status (value)
int counter = 0, backup = 0;
int second = 0, minute = 0;
int flag_status = 0;
// Function Prototypes &&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&
void dataUpload();
void sensor1();
void sensor2();
void sensor3();
RH_RF95 rf95;
byte bGlobalErr;
String stringOne;
float frequency = 915.0;
if (!rf95.init())
Serial.println("init failed");
// Setup ISM frequency
rf95.setFrequency(frequency);
// Setup Power,dBm
rf95.setTxPower(13);
Serial.println("START");
pinMode(PIR1, INPUT); // initialize sensor as an input
pinMode(PIR2, INPUT); // initialize sensor as an input
pinMode(PIR3, INPUT); // initialize sensor as an input
Timer1.initialize(1000000);
Timer1.attachInterrupt(dataUpload);
uint16_t calcByte(uint16_t crc, uint8_t b)
uint32_t i;
crc = crc ^ (uint32_t)b << 8;
for ( i = 0; i < 8; i++)
if ((crc & 0x8000) == 0x8000)
crc = crc << 1 ^ 0x1021;
crc = crc << 1;
return crc & 0xffff;
uint16_t CRC16(uint8_t pBuffer, uint32_t length)
uint16_t wCRC16 = 0;
uint32_t i;
if (( pBuffer == 0 ) || ( length == 0 ))
return 0;
for ( i = 0; i < length; i++)
wCRC16 = calcByte(wCRC16, pBuffer
  • return wCRC16;*
  • char data[50] = {0} ;*
  • // Use data[0], data[1],data[2] as Node ID*
  • data[0] = 3 ;*
  • data[1] = 2 ;*
  • data[2] = 1 ;*
  • data[3] = 10;*
  • data[4] = 20;*
  • sensor1();*
  • sensor2();*
  • sensor3();*
  • if (flag_status)*
  • backup = counter;*
  • data[3] = backup;*
  • Serial.println("Number of pedestarians in the last 2 minutes:");*
  • Serial.println(backup);*
  • int dataLength = strlen(data);//CRC length for LoRa Data*
  • //Serial.println(dataLength);*
    uint16_t crcData = CRC16((unsigned char*)data, dataLength); //get CRC DATA
  • //Serial.println(crcData);*
  • unsigned char sendBuf[50] = {0};*
  • int i;*
  • for (i = 0; i < 8; i++)*
    sendBuf = data ;
    * sendBuf[dataLength] = (unsigned char)crcData; // Add CRC to LoRa Data*
    * //Serial.println( sendBuf[dataLength] );*
    * sendBuf[dataLength + 1] = (unsigned char)(crcData >> 8); // Add CRC to LoRa Data*
    * //Serial.println( sendBuf[dataLength+1] );*
    _ rf95.send(sendBuf, strlen((char*)sendBuf));//Send LoRa Data_
    _ //Serial.print(strlen((char*)sendBuf));
    * uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];//Reply data array*
    * uint8_t len = sizeof(buf);//reply data length*
    * if (rf95.waitAvailableTimeout(3000))// Check If there is reply in 3 seconds.
    // Should be a reply message for us now*
    * if (rf95.recv(buf, &len))//check if reply message is correct*
    if (buf[0] == 1 || buf[1] == 1 || buf[2] == 1) // Check if reply message has the our node ID*
    Serial.print("got reply: ");//print reply*
    Serial.println((char*)buf);
    * delay(400);
    //Serial.print("RSSI: "); // print RSSI*
    * //Serial.println(rf95.lastRssi(), DEC);
    else*
    Serial.println("recv failed");//
    rf95.send(sendBuf, strlen((char)sendBuf));//resend if no reply_
    * else*
    * Serial.println("No reply, is rf95_server running?");//No signal reply*
    _ rf95.send(sendBuf, strlen((char*)sendBuf));//resend data_
    * flag_status = 0;
    _ }
    // Function defination ////////////////////////////////////////////////////////////////////////
    void dataUpload() {
    second++;
    if (second == 59) {
    second = 0;
    minute++;
    }_
    if (minute == MINUTE_VALUE) {
    _ second = 0;
    minute = 0;_
    flag_status = 1;
    _ }
    void sensor1() {
    i = digitalRead(PIR1); // read sensor value*
    * if (i == HIGH) { // check if the sensor is HIGH*
    * delay(100); // delay 100 milliseconds*
    * if (state == LOW) {
    Serial.println("SENSOR 111 is detected!");
    state = HIGH; // update variable state to HIGH*
    * counter++;
    else {
    delay(200); // delay 200 milliseconds*
    * if (state == HIGH) {
    Serial.println("SENSOR 111 is stopped!");
    state = LOW; // update variable state to LOW*
    void sensor2() {
    sam = digitalRead(PIR2); // read sensor value*
    * if (sam == HIGH) { // check if the sensor is HIGH*
    * if (state1 == LOW) {
    Serial.println("SENSOR 222 is detected!");
    state1 = HIGH; // update variable state to HIGH*
    * counter++;
    else {
    * if (state1 == HIGH) {
    Serial.println("SENSOR 222 is stopped!");
    state1 = LOW; // update variable state to LOW*
    void sensor3() {
    isam = digitalRead(PIR3); // read sensor value*
    * if (isam == HIGH) { // check if the sensor is HIGH*
    * delay(100);
    if (state2 == LOW) {
    Serial.println("SENSOR 333 is detected!");
    state2 = HIGH; // update variable state to HIGH*
    * counter++;
    else {
    * if (state2 == HIGH) {
    Serial.println("SENSOR 333 is stopped!");
    state2 = LOW; // update variable state to LOW*
    }*_
The error is probably telling you that the compiler can't find the RH_RF95 library. You need to properly install that library.
The RH_RF95 library.
How to install library.
Read the "how to use this forum-please read" sticky to see how to properly post code and errors.
When you get the "Error compiling for board..." type of error, you can be sure the problem has nothing to with the port selection or USB cable and is something wrong with the code. When troubleshooting, it's very important to learn how to narrow down the cause of the problem, otherwise you won't even know where to start to try to fix it.
