i dont need the serial monitor, but, the problem its that until i dont open the serial monitor arduino wont post anything....
and sorry for my ignorance, but why would i need a debounce?? i just need to recognize the change of state on the pin, so if it bounce, until only post one msg its ok for me....
and for the twitter error for posting the same msg i think that using a counter and 5 different msgs in a switch sentence, and the variablechar msg[] should be declared as a pointer...
do u think this make any logic???, if so later this day i will post a program to do that...
also thanks for your help it really helps me a lot
this is my code but i doesnt compile, i cant find the error...
#include <SPI.h> // needed in Arduino 0019 or later
#include <Ethernet.h>
#include <Twitter.h>
// The includion of EthernetDNS is not needed in Arduino IDE 1.0 or later.
// Please uncomment below in Arduino IDE 0022 or earlier.
//#include <EthernetDNS.h>
int LedState=LOW ;
// Ethernet Shield Settings
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// If you don't specify the IP address, DHCP is used(only in Arduino 1.0 or later).
byte ip[] = { 192, 168, 2, 250 };
// Your Token to Tweet (get it from http://arduino-tweet.appspot.com/)
Twitter twitter("YOUR-TOKEN-HERE");
// Message to post
char* msg[20];
char str1[]="post one";
char str2[]="post two";
char str3[]="post three";
char str4[]="post four";
char str5[]="post five";
char str6[]="post six";
digitalWrite(2, HIGH);
attachInterrupt(0, alarm, RISING);
Ethernet.begin(mac);
// or you can use DHCP for autoomatic IP address configuration.
// Ethernet.begin(mac);
int count=0;
if (ledState == HIGH)
LedState==LOW;
Swtich (count)
{ case 1:
msg =& str1;
count++;
break
case 2:
msg =& str2;
count++;
break
case 3:
msg =& str3;
count++;
break
case 4:
msg =& str4;
count++;
break
case 5:
msg =& str5;
count++;
break
case 6:
msg =& str6;
count=0;
Serial.println("connecting ...");
if (twitter.post(msg)) {
// Specify &Serial to output received response to Serial.
// If no output is required, you can just omit the argument, e.g.
// int status = twitter.wait();
int status = twitter.wait(&Serial);
if (status == 200) {
Serial.println("OK.");
Serial.print("failed : code ");
Serial.println(status);
Serial.println("connection failed.");
void alarm()
ledState = HIGH;
yes, but i need an array with pointer, so in the switch case depending on the counter, the pointer msg will be referenced to the array with the message
ok, i have made some crrections but, still IDE says expected initializer before 'if'
[quote]
[#include <SPI.h> // needed in Arduino 0019 or later
int LedState=LOW ;
// Message to post
char* msg[26];
LedState==LOW;
Swtich (count)
{ case 1:
msg =& str1;
count++;
break
case 2:
msg =& str2;
count++;
break
case 3:
msg =& str3;
count++;
break
case 4:
msg =& str4;
count++;
break
case 5:
msg =& str5;
count++;
break
case 6:
msg =& str6;
count=0;
if (twitter.post(*msg)) {
void alarm()
ledState = HIGH;
Curly braces are NOT optional and not wherever the heck you feel like putting them.
The compiler is right. You DO have stuff before the if statement that doesn't belong there.
and if i just call msg as an char pointer and not an array????
like char *msg;
still the compiler says im wrong in the if funtion
int LedState=LOW ;
// Message to post
char* msg[26];
LedState==LOW;
Swtich (count)
{ case 1:
msg =& str1;
count++;
break
case 2:
msg =& str2;
count++;
break
case 3:
msg =& str3;
count++;
break
case 4:
msg =& str4;
count++;
break
case 5:
msg =& str5;
count++;
break
case 6:
msg =& str6;
count=0;
void alarm()
ledState = HIGH;
int count;
int LedState=LOW ;
// Message to post
char msg;
if (LedState == HIGH)
LedState==LOW;
switch (count)
{ case 1:
*msg =& str1;
count++;
case 2:
msg =& str2;
count++;
case 3:
msg =& str3;
count++;
case 4:
msg =& str4;
count++;
case 5:
msg =& str5;
count++;
case 6:
msg =& str6;
count=0;
void alarm()
LedState = HIGH;
SimplePost.ino: In function 'void loop()':
SimplePost:50: error: invalid type argument of 'unary *'
SimplePost:55: error: invalid conversion from 'char (*)[9]' to 'char'
SimplePost:60: error: invalid conversion from 'char (*)[11]' to 'char'
SimplePost:66: error: invalid conversion from 'char (*)[10]' to 'char'
SimplePost:71: error: invalid conversion from 'char (*)[10]' to 'char'
SimplePost:75: error: invalid conversion from 'char (*)[9]' to 'char'
SimplePost:84: error: invalid conversion from 'char' to 'const char*'
SimplePost:84: error: initializing argument 1 of 'bool Twitter::post(const char*)'
