xtensa-esp32-elf-g++: error: CreateProcess: No such file or directory
exit status 1
Compilation error: exit status 1`Use code tags to format code for the forum
Hint the file you specified is not where you implied it was or it does not exist.
The easiest solution is to reformat using code tags and post your code.
Hi @memo_233. I'm going to ask you to post the full verbose output from a compilation.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
- Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
The "Preferences" dialog will open. - Check the box next to "Show verbose output during: ☐ compilation" in the "Preferences" dialog.
- Click the "OK" button.
The "Preferences" dialog will close. - Select Sketch > Verify/Compile from the Arduino IDE menus.
- Wait for the compilation to fail.
- You will see a "Compilation error: ..." notification at the bottom right corner of the Arduino IDE window. Click the "COPY ERROR MESSAGES" button on that notification.
- Open a forum reply here by clicking the "Reply" button.
- Click the
<CODE/>
icon on the post composer toolbar.
This will add the forum's code block markup (```
) to your reply to make sure the error messages are correctly formatted.
- Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
This will paste the compilation output into the code block. - Move the cursor outside of the code block markup before you add any additional text to your reply.
- Click the "Reply" button to post the output.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt
file and then attach that file to a reply here:
- Open any text editor program.
- Paste the copied output into the text editor.
- Save the file in
.txt
format. - Open a forum reply here by clicking the "Reply" button.
- Click the "Upload" icon () on the post composer toolbar:
The "Open" dialog will open. - Select the
.txt
file you saved from the "Open" dialog. - Click the "Open" button.
The dialog will close. - Click the "Reply" button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt
file onto the post composer field to attach it.
FQBN: esp32:esp32:esp32
Using board 'esp32' from platform in folder: C:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14
Using core 'esp32' from platform in folder: C:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14
cmd /c if exist "C:\\Users\\Mo'men\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024321-28524-lxyw17.lvx8j\\BlinkRGB\\partitions.csv" COPY /y "C:\\Users\\Mo'men\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024321-28524-lxyw17.lvx8j\\BlinkRGB\\partitions.csv" "C:\\Users\\Mo'men\\AppData\\Local\\Temp\\arduino\\sketches\\B94F8AC87A68F90354C363851A4072E7\\partitions.csv"
cmd /c if not exist "C:\\Users\\Mo'men\\AppData\\Local\\Temp\\arduino\\sketches\\B94F8AC87A68F90354C363851A4072E7\\partitions.csv" if exist "C:\\Users\\Mo'men\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\variants\\esp32\\partitions.csv" COPY "C:\\Users\\Mo'men\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\variants\\esp32\\partitions.csv" "C:\\Users\\Mo'men\\AppData\\Local\\Temp\\arduino\\sketches\\B94F8AC87A68F90354C363851A4072E7\\partitions.csv"
cmd /c if not exist "C:\\Users\\Mo'men\\AppData\\Local\\Temp\\arduino\\sketches\\B94F8AC87A68F90354C363851A4072E7\\partitions.csv" COPY "C:\\Users\\Mo'men\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\tools\\partitions\\default.csv" "C:\\Users\\Mo'men\\AppData\\Local\\Temp\\arduino\\sketches\\B94F8AC87A68F90354C363851A4072E7\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\Mo'men\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024321-28524-lxyw17.lvx8j\\BlinkRGB\\bootloader.bin" ( COPY /y "C:\\Users\\Mo'men\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024321-28524-lxyw17.lvx8j\\BlinkRGB\\bootloader.bin" "C:\\Users\\Mo'men\\AppData\\Local\\Temp\\arduino\\sketches\\B94F8AC87A68F90354C363851A4072E7\\BlinkRGB.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\Mo'men\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\variants\\esp32\\bootloader.bin" ( COPY "C:\\Users\\Mo'men\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\variants\\esp32\\bootloader.bin" "C:\\Users\\Mo'men\\AppData\\Local\\Temp\\arduino\\sketches\\B94F8AC87A68F90354C363851A4072E7\\BlinkRGB.ino.bootloader.bin" ) ELSE ( "C:\\Users\\Mo'men\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.5.1/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\Mo'men\\AppData\\Local\\Temp\\arduino\\sketches\\B94F8AC87A68F90354C363851A4072E7\\BlinkRGB.ino.bootloader.bin" "C:\\Users\\Mo'men\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\tools\\sdk\\esp32\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.5.1
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
cmd /c if exist "C:\\Users\\Mo'men\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024321-28524-lxyw17.lvx8j\\BlinkRGB\\build_opt.h" COPY /y "C:\\Users\\Mo'men\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024321-28524-lxyw17.lvx8j\\BlinkRGB\\build_opt.h" "C:\\Users\\Mo'men\\AppData\\Local\\Temp\\arduino\\sketches\\B94F8AC87A68F90354C363851A4072E7\\build_opt.h"
cmd /c if not exist "C:\\Users\\Mo'men\\AppData\\Local\\Temp\\arduino\\sketches\\B94F8AC87A68F90354C363851A4072E7\\build_opt.h" type nul > "C:\\Users\\Mo'men\\AppData\\Local\\Temp\\arduino\\sketches\\B94F8AC87A68F90354C363851A4072E7\\build_opt.h"
cmd /c type nul > "C:\\Users\\Mo'men\\AppData\\Local\\Temp\\arduino\\sketches\\B94F8AC87A68F90354C363851A4072E7/file_opts"
Detecting libraries used...
C:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++ -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.6-dirty" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/newlib/platform_include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/freertos/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions/freertos -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/freertos/port/xtensa/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_hw_support/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32 -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32 -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/heap/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/log/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/lwip/include/apps -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/lwip/include/apps/sntp -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/lwip/lwip/src/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include/arch -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/soc/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/soc/esp32 -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/soc/esp32/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/hal/esp32/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/hal/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/hal/platform_port/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_rom/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_rom/include/esp32 -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_rom/esp32 -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_common/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_system/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_system/port/soc -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_system/port/public_compat -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp32/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/xtensa/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/xtensa/esp32/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/driver/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/driver/esp32/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_pm/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_ringbuf/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/efuse/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/efuse/esp32/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/vfs/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_wifi/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_event/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_netif/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_eth/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/tcpip_adapter/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_phy/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_phy/esp32/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_ipc/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/app_trace/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_timer/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/mbedtls/port/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/mbedtls/mbedtls/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/app_update/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/spi_flash/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bootloader_support/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/nvs_flash/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/pthread/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_gdbstub/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_gdbstub/xtensa -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_gdbstub/esp32 -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espcoredump/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espcoredump/include/port/xtensa -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/wpa_supplicant/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/wpa_supplicant/port/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/ieee802154/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/console -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/asio/asio/asio/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/asio/port/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/common/osi/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/include/esp32/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/common/api/include/api -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/cbor/port/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/unity/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/unity/unity/src -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/cmock/CMock/src -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/coap/port/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/coap/libcoap/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/nghttp/port/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-tls -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-tls/esp-tls-crypto -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_adc_cal/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_hid/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/tcp_transport/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_http_client/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_http_server/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_https_ota/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_https_server/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_lcd/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_lcd/interface -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/protobuf-c/protobuf-c -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/protocomm/include/common -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/protocomm/include/security -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/protocomm/include/transports -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/mdns/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_local_ctrl/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/sdmmc/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_serial_slave_link/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_websocket_client/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/expat/expat/expat/lib -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/expat/port/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/wear_levelling/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/fatfs/diskio -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/fatfs/vfs -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/fatfs/src -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/freemodbus/freemodbus/common/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/idf_test/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/idf_test/include/esp32 -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/jsmn/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/json/cJSON -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/libsodium/port_include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/mqtt/esp-mqtt/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/openssl/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/perfmon/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/spiffs/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/ulp/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/wifi_provisioning/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/rmaker_common/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_diagnostics/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/rtc_store/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_insights/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/json_parser/upstream/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/json_parser/upstream -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/json_generator/upstream -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_schedule/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_rainmaker/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/gpio_button/button/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/qrcode/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/ws2812_led -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_littlefs/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-dl/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-dl/include/tool -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-dl/include/typedef -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-dl/include/image -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-dl/include/math -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-dl/include/nn -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-dl/include/layer -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-dl/include/detect -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-dl/include/model_zoo -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp32-camera/driver/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp32-camera/conversions/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/fb_gfx/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/qio_qspi/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Mo'men\AppData\Local\Temp\arduino\sketches\B94F8AC87A68F90354C363851A4072E7/build_opt.h @C:\Users\Mo'men\AppData\Local\Temp\arduino\sketches\B94F8AC87A68F90354C363851A4072E7/file_opts -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14\cores\esp32 -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14\variants\esp32 C:\Users\Mo'men\AppData\Local\Temp\arduino\sketches\B94F8AC87A68F90354C363851A4072E7\sketch\BlinkRGB.ino.cpp -o nul
Error while detecting libraries included by C:\Users\Mo'men\AppData\Local\Temp\arduino\sketches\B94F8AC87A68F90354C363851A4072E7\sketch\BlinkRGB.ino.cpp
Generating function prototypes...
C:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++ -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.6-dirty" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/newlib/platform_include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/freertos/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions/freertos -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/freertos/port/xtensa/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_hw_support/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32 -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32 -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/heap/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/log/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/lwip/include/apps -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/lwip/include/apps/sntp -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/lwip/lwip/src/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include/arch -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/soc/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/soc/esp32 -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/soc/esp32/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/hal/esp32/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/hal/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/hal/platform_port/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_rom/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_rom/include/esp32 -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_rom/esp32 -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_common/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_system/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_system/port/soc -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_system/port/public_compat -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp32/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/xtensa/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/xtensa/esp32/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/driver/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/driver/esp32/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_pm/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_ringbuf/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/efuse/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/efuse/esp32/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/vfs/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_wifi/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_event/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_netif/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_eth/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/tcpip_adapter/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_phy/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_phy/esp32/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_ipc/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/app_trace/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_timer/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/mbedtls/port/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/mbedtls/mbedtls/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/app_update/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/spi_flash/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bootloader_support/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/nvs_flash/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/pthread/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_gdbstub/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_gdbstub/xtensa -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_gdbstub/esp32 -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espcoredump/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espcoredump/include/port/xtensa -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/wpa_supplicant/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/wpa_supplicant/port/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/ieee802154/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/console -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/asio/asio/asio/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/asio/port/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/common/osi/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/include/esp32/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/common/api/include/api -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/cbor/port/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/unity/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/unity/unity/src -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/cmock/CMock/src -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/coap/port/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/coap/libcoap/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/nghttp/port/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-tls -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-tls/esp-tls-crypto -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_adc_cal/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_hid/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/tcp_transport/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_http_client/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_http_server/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_https_ota/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_https_server/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_lcd/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_lcd/interface -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/protobuf-c/protobuf-c -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/protocomm/include/common -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/protocomm/include/security -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/protocomm/include/transports -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/mdns/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_local_ctrl/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/sdmmc/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_serial_slave_link/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_websocket_client/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/expat/expat/expat/lib -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/expat/port/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/wear_levelling/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/fatfs/diskio -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/fatfs/vfs -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/fatfs/src -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/freemodbus/freemodbus/common/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/idf_test/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/idf_test/include/esp32 -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/jsmn/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/json/cJSON -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/libsodium/port_include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/mqtt/esp-mqtt/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/openssl/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/perfmon/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/spiffs/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/ulp/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/wifi_provisioning/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/rmaker_common/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_diagnostics/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/rtc_store/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_insights/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/json_parser/upstream/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/json_parser/upstream -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/json_generator/upstream -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_schedule/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_rainmaker/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/gpio_button/button/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/qrcode/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/ws2812_led -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp_littlefs/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-dl/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-dl/include/tool -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-dl/include/typedef -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-dl/include/image -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-dl/include/math -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-dl/include/nn -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-dl/include/layer -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-dl/include/detect -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp-dl/include/model_zoo -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp32-camera/driver/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/esp32-camera/conversions/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/include/fb_gfx/include -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14/tools/sdk/esp32/qio_qspi/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Mo'men\AppData\Local\Temp\arduino\sketches\B94F8AC87A68F90354C363851A4072E7/build_opt.h @C:\Users\Mo'men\AppData\Local\Temp\arduino\sketches\B94F8AC87A68F90354C363851A4072E7/file_opts -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14\cores\esp32 -IC:\Users\Mo'men\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14\variants\esp32 C:\Users\Mo'men\AppData\Local\Temp\arduino\sketches\B94F8AC87A68F90354C363851A4072E7\sketch\BlinkRGB.ino.cpp -o C:\Users\Mo'men\AppData\Local\Temp\1509407707\sketch_merged.cpp
exit status 1
I moved your topic to a more appropriate forum category @memo_233.
The Nano ESP32 category you chose is only used for discussions directly related to the Arduino Nano ESP32 board.
In the future, please take the time to pick the forum category that best suits the subject of your question. There is an "About the _____ category" topic at the top of each category that explains its purpose.
Thanks in advance for your cooperation.
ESP_WROOM-32
