Compilation error on only esp32 boards
Good Day Friends.
I'm using Arduino IDE v1.8.19. After downloading the board manager for esp32 boards and adding it's release link in the external board management link, located in the preference page. Then i tried to upload this code, as the simplest i could come up with:
#include <Arduino.h>
int flashPin = 4;
    pinMode(flashPin, OUTPUT);
    digitalWrite(flashPin, HIGH);
    digitalWrite(flashPin, LOW);
And then, I don't know why but it gave a compilation error.. Below is the error message:
Arduino: 1.8.19 (Windows 10), Board: "AI Thinker ESP32-CAM, 240MHz (WiFi/BT), QIO, Huge APP (3MB No OTA/1MB SPIFFS), 80MHz, None, Disabled"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\pc\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\pc\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\pc\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none -ide-version=10819 -build-path C:\Users\pc\AppData\Local\Temp\arduino_build_217173 -warnings=none -build-cache C:\Users\pc\AppData\Local\Temp\arduino_cache_469761 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esp32-arduino-libs.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef -prefs=runtime.tools.esp32-arduino-libs-idf-release_v5.1-bd2b9390ef.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef -prefs=runtime.tools.riscv32-esp-elf-gdb.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.riscv32-esp-elf-gdb-12.1_20231023.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.esp-xs2.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-xs2\2302 -prefs=runtime.tools.esp-xs2-2302.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-xs2\2302 -prefs=runtime.tools.dfu-util.path=C:\Users\pc\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=C:\Users\pc\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.xtensa-esp-elf-gdb-12.1_20231023.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.openocd-esp32.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20240318 -prefs=runtime.tools.openocd-esp32-v0.12.0-esp32-20240318.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20240318 -prefs=runtime.tools.esp-xs3.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302 -prefs=runtime.tools.esp-xs3-2302.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302 -prefs=runtime.tools.esp-x32.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302 -prefs=runtime.tools.esp-x32-2302.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302 -prefs=runtime.tools.mklittlefs.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.esptool_py.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.6 -prefs=runtime.tools.esptool_py-4.6.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.6 -prefs=runtime.tools.esp-rv32.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302 -prefs=runtime.tools.esp-rv32-2302.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302 -prefs=runtime.tools.mkspiffs.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -verbose C:\Users\pc\Documents\Arduino archives\esp_test\esp_test.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\pc\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\pc\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\pc\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none -ide-version=10819 -build-path C:\Users\pc\AppData\Local\Temp\arduino_build_217173 -warnings=none -build-cache C:\Users\pc\AppData\Local\Temp\arduino_cache_469761 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esp32-arduino-libs.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef -prefs=runtime.tools.esp32-arduino-libs-idf-release_v5.1-bd2b9390ef.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef -prefs=runtime.tools.riscv32-esp-elf-gdb.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.riscv32-esp-elf-gdb-12.1_20231023.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.esp-xs2.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-xs2\2302 -prefs=runtime.tools.esp-xs2-2302.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-xs2\2302 -prefs=runtime.tools.dfu-util.path=C:\Users\pc\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=C:\Users\pc\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.xtensa-esp-elf-gdb-12.1_20231023.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.openocd-esp32.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20240318 -prefs=runtime.tools.openocd-esp32-v0.12.0-esp32-20240318.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20240318 -prefs=runtime.tools.esp-xs3.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302 -prefs=runtime.tools.esp-xs3-2302.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302 -prefs=runtime.tools.esp-x32.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302 -prefs=runtime.tools.esp-x32-2302.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302 -prefs=runtime.tools.mklittlefs.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.esptool_py.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.6 -prefs=runtime.tools.esptool_py-4.6.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.6 -prefs=runtime.tools.esp-rv32.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302 -prefs=runtime.tools.esp-rv32-2302.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302 -prefs=runtime.tools.mkspiffs.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -verbose C:\Users\pc\Documents\Arduino archives\esp_test\esp_test.ino
Using board 'esp32cam' from platform in folder: C:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2
Using core 'esp32' from platform in folder: C:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2
cmd /c if exist "C:\\Users\\pc\\Documents\\Arduino archives\\esp_test\\partitions.csv" COPY /y "C:\\Users\\pc\\Documents\\Arduino archives\\esp_test\\partitions.csv" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173\\partitions.csv"
cmd /c if not exist "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173\\partitions.csv" if exist "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32\\partitions.csv" COPY "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32\\partitions.csv" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173\\partitions.csv"
cmd /c if not exist "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173\\partitions.csv" COPY "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\tools\\partitions\\huge_app.csv" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173\\partitions.csv"
        1 file(s) copied.
cmd /c IF EXIST "C:\\Users\\pc\\Documents\\Arduino archives\\esp_test\\bootloader.bin" ( COPY /y "C:\\Users\\pc\\Documents\\Arduino archives\\esp_test\\bootloader.bin" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173\\esp_test.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32\\bootloader.bin" ( COPY "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32\\bootloader.bin" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173\\esp_test.ino.bootloader.bin" ) ELSE ( "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.6\\esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173\\esp_test.ino.bootloader.bin" "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.6
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
cmd /c if exist "C:\\Users\\pc\\Documents\\Arduino archives\\esp_test\\build_opt.h" COPY /y "C:\\Users\\pc\\Documents\\Arduino archives\\esp_test\\build_opt.h" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173\\build_opt.h"
cmd /c if not exist "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173\\build_opt.h" type nul > "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173\\build_opt.h"
cmd /c type nul > "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173/file_opts"
Detecting libraries used...
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\pc\\Documents\\Arduino archives\\esp_test" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173/file_opts" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173\\sketch\\esp_test.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\pc\\Documents\\Arduino archives\\esp_test" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173/file_opts" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173\\sketch\\esp_test.ino.cpp" -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\pc\\Documents\\Arduino archives\\esp_test" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173/file_opts" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173\\sketch\\esp_test.ino.cpp" -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173\\sketch\\esp_test.ino.cpp.o"
Compiling libraries...
Compiling core...
cmd /c echo -DARDUINO_CORE_BUILD > "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173/file_opts"
Using precompiled core: C:\Users\pc\AppData\Local\Temp\arduino_cache_469761\core\core_e8af30cea3fa7ee50144c3b75ff4525b.a
Linking everything together...
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/ld_flags" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/ld_scripts" "-Wl,--Map=C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173/esp_test.ino.map" "-LC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/lib" "-LC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/ld" "-LC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi" -Wl,--wrap=esp_panic_handler -Wl,--start-group "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173\\sketch\\esp_test.ino.cpp.o" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_cache_469761\\core\\core_e8af30cea3fa7ee50144c3b75ff4525b.a" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/ld_libs" -Wl,--end-group -Wl,-EL -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_217173/esp_test.ino.elf"
exit status 1
Error compiling for board AI Thinker ESP32-CAM.
I'll really appreciate any help on this please..
Thanks in advance.
turn on verbose mode in IDE Preferences
@juraj, do you mean I should enable it?
I already enabled if for compilation
with verbose mode you should get much more output on the console than what you posted
Are you using th AI Thinker ESP32-CAM board.
Yes Sir.
Although I usually don't plug it to my PC while compiling, and the twice that I did, it made no change.
I'm using IDE 1.8.13 and ESP board package 2.0.11
Selected AI thinker ESP32-cam
Compiled OK
Some people have reported problems with some on the ESP version 3 packages
Hi @ibuchukwu. It seems that one of the commands being run during the compilation process is failing unexpectedly. Unfortunately we aren't getting any error messages that would give us some understanding of why that is happening.
The obvious suspect is the last command printed in the compilation output before the failure:
I'm going to ask you to run the equivalent command directly from a Windows cmd terminal and then tell us what the result was. This will give us some valuable information:
  • Whether it is that command that is failing (vs. another one of the commands Arduino IDE runs during a compilation)
  • If this is the failing command, whether some diagnostic information is available about the failure (which is not being printed in the Arduino IDE output)
Please try this:
:exclamation: This procedure is not intended to solve the problem. The purpose is to gather more information.
  1. Compile a sketch in Arduino IDE for the "AI Thinker ESP32-CAM" board, as usual.
    It is necessary to make a fresh compilation for this procedure rather than using the command from the output you posted some days ago because the command uses a path under a temporary folder which has been deleted since that time.
  2. Wait for the compilation to fail.
  3. Examine the contents of the black output panel at the bottom of the Arduino IDE window. Find the last command line before the "exit status 1" line. It will look something like this:
  4. Drag the mouse pointer over that line until the whole thing is selected.
    :exclamation: Note that the line is very long and you must select it all the way to the end. The easiest way to do that is to click at the start of the line and then drag the pointer downwards rather than to the right.
  5. Press the Ctrl+C keyboard shortcut.
    This will copy the selected text to the clipboard.
  6. Right click on the Windows "Start" button.
    A menu will open.
  7. Select "Run" from the menu.
    The "Run" dialog will open.
  8. Type cmd in the dialog's "Open" field.
  9. Click the "OK" button.
  10. A Windows cmd terminal window will open.
  11. Press the Ctrl+V keyboard shortcut.
    This will paste the command you copied to the command prompt.
  12. Press the Enter key.
    This will run the command.
Now please add a reply here to provide answers to the following questions:
  • Did you see any message printed in the cmd terminal after you performed step (12) of those instructions?
  • Did any separate dialogs appear when you did that, and if so what did they say?
Thanks so much for your response @ptillisch .. I so much appreciate.
I did just as you instructed and the following are the results.
After failed compilation, it came up with this error message:
FQBN: esp32:esp32:esp32cam
cmd /c if exist "C:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer\\partitions.csv" COPY /y "C:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer\\partitions.csv" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\partitions.csv"
        1 file(s) copied.
cmd /c if not exist "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\partitions.csv" if exist "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32\\partitions.csv" COPY "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32\\partitions.csv" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\partitions.csv"
cmd /c if not exist "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\partitions.csv" COPY "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\tools\\partitions\\huge_app.csv" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer\\bootloader.bin" ( COPY /y "C:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer\\bootloader.bin" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\CameraWebServer.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32\\bootloader.bin" ( COPY "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32\\bootloader.bin" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\CameraWebServer.ino.bootloader.bin" ) ELSE ( "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.6\\esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\CameraWebServer.ino.bootloader.bin" "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.6
cmd /c if exist "C:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer\\build_opt.h" COPY /y "C:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer\\build_opt.h" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\build_opt.h"
cmd /c if not exist "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\build_opt.h" type nul > "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\build_opt.h"
cmd /c type nul > "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts"
C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/defines -IC:\Users\pc\AppData\Local\Temp\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\CameraWebServer -iprefix C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/include/ @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/includes -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/qio_qspi/include -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\cores\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\variants\esp32 @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0\sketch\CameraWebServer.ino.cpp -o nul
Alternatives for WiFi.h: [WiFi@2.0.0]
ResolveLibrary(WiFi.h)
  -> candidates: [WiFi@2.0.0]
C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/defines -IC:\Users\pc\AppData\Local\Temp\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\CameraWebServer -iprefix C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/include/ @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/includes -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/qio_qspi/include -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\cores\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\variants\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0\sketch\CameraWebServer.ino.cpp -o nul
Alternatives for Network.h: [Networking@1.0.0]
ResolveLibrary(Network.h)
  -> candidates: [Networking@1.0.0]
C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/defines -IC:\Users\pc\AppData\Local\Temp\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\CameraWebServer -iprefix C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/include/ @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/includes -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/qio_qspi/include -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\cores\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\variants\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0\sketch\CameraWebServer.ino.cpp -o nul
C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/defines -IC:\Users\pc\AppData\Local\Temp\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\CameraWebServer -iprefix C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/include/ @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/includes -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/qio_qspi/include -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\cores\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\variants\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0\sketch\app_httpd.cpp -o nul
C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/defines -IC:\Users\pc\AppData\Local\Temp\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\CameraWebServer -iprefix C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/include/ @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/includes -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/qio_qspi/include -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\cores\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\variants\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts C:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src\AP.cpp -o nul
C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/defines -IC:\Users\pc\AppData\Local\Temp\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\CameraWebServer -iprefix C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/include/ @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/includes -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/qio_qspi/include -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\cores\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\variants\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts C:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src\STA.cpp -o nul
C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/defines -IC:\Users\pc\AppData\Local\Temp\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\CameraWebServer -iprefix C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/include/ @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/includes -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/qio_qspi/include -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\cores\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\variants\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts C:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src\WiFi.cpp -o nul
C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/defines -IC:\Users\pc\AppData\Local\Temp\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\CameraWebServer -iprefix C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/include/ @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/includes -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/qio_qspi/include -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\cores\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\variants\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts C:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src\WiFiAP.cpp -o nul
C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/defines -IC:\Users\pc\AppData\Local\Temp\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\CameraWebServer -iprefix C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/include/ @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/includes -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/qio_qspi/include -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\cores\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\variants\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts C:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src\WiFiGeneric.cpp -o nul
C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/defines -IC:\Users\pc\AppData\Local\Temp\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\CameraWebServer -iprefix C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/include/ @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/includes -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/qio_qspi/include -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\cores\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\variants\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts C:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src\WiFiMulti.cpp -o nul
C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/defines -IC:\Users\pc\AppData\Local\Temp\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\CameraWebServer -iprefix C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/include/ @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/includes -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/qio_qspi/include -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\cores\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\variants\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts C:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src\WiFiSTA.cpp -o nul
C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/defines -IC:\Users\pc\AppData\Local\Temp\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\CameraWebServer -iprefix C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/include/ @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/includes -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/qio_qspi/include -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\cores\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\variants\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts C:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src\WiFiScan.cpp -o nul
C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/defines -IC:\Users\pc\AppData\Local\Temp\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\CameraWebServer -iprefix C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/include/ @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/includes -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/qio_qspi/include -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\cores\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\variants\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts C:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src\NetworkClient.cpp -o nul
C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/defines -IC:\Users\pc\AppData\Local\Temp\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\CameraWebServer -iprefix C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/include/ @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/includes -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/qio_qspi/include -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\cores\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\variants\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts C:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src\NetworkEvents.cpp -o nul
C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/defines -IC:\Users\pc\AppData\Local\Temp\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\CameraWebServer -iprefix C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/include/ @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/includes -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/qio_qspi/include -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\cores\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\variants\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts C:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src\NetworkInterface.cpp -o nul
C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/defines -IC:\Users\pc\AppData\Local\Temp\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\CameraWebServer -iprefix C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/include/ @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/includes -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/qio_qspi/include -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\cores\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\variants\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts C:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src\NetworkManager.cpp -o nul
C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/defines -IC:\Users\pc\AppData\Local\Temp\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\CameraWebServer -iprefix C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/include/ @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/includes -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/qio_qspi/include -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\cores\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\variants\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts C:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src\NetworkServer.cpp -o nul
C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/defines -IC:\Users\pc\AppData\Local\Temp\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\CameraWebServer -iprefix C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/include/ @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/includes -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/qio_qspi/include -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\cores\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\variants\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts C:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src\NetworkUdp.cpp -o nul
C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_huge_app -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/defines -IC:\Users\pc\AppData\Local\Temp\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\CameraWebServer -iprefix C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/include/ @C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/flags/includes -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef\esp32/qio_qspi/include -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\cores\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\variants\esp32 -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi\src -IC:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network\src @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h @C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts C:\Users\pc\AppData\Local\Temp\arduino\sketches\2A9DDFE7A5247DB007DF1E108282A9B0\sketch\CameraWebServer.ino.cpp -o C:\Users\pc\AppData\Local\Temp\3095754130\sketch_merged.cpp
C:\Users\pc\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\pc\AppData\Local\Temp\3095754130\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -Wall -Wextra -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\sketch\\CameraWebServer.ino.cpp" -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\sketch\\CameraWebServer.ino.cpp.o"
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -Wall -Wextra -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\sketch\\app_httpd.cpp" -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\sketch\\app_httpd.cpp.o"
Compiling library "WiFi"
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -Wall -Wextra -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts" "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src\\AP.cpp" -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\WiFi\\AP.cpp.o"
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -Wall -Wextra -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts" "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src\\WiFiAP.cpp" -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\WiFi\\WiFiAP.cpp.o"
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -Wall -Wextra -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts" "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src\\STA.cpp" -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\WiFi\\STA.cpp.o"
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -Wall -Wextra -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts" "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src\\WiFi.cpp" -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\WiFi\\WiFi.cpp.o"
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -Wall -Wextra -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts" "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src\\WiFiGeneric.cpp" -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\WiFi\\WiFiGeneric.cpp.o"
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -Wall -Wextra -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts" "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src\\WiFiMulti.cpp" -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\WiFi\\WiFiMulti.cpp.o"
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -Wall -Wextra -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts" "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src\\WiFiSTA.cpp" -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\WiFi\\WiFiSTA.cpp.o"
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -Wall -Wextra -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts" "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src\\WiFiScan.cpp" -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\WiFi\\WiFiScan.cpp.o"
Compiling library "Networking"
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -Wall -Wextra -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts" "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src\\NetworkClient.cpp" -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\Network\\NetworkClient.cpp.o"
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -Wall -Wextra -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts" "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src\\NetworkManager.cpp" -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\Network\\NetworkManager.cpp.o"
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -Wall -Wextra -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts" "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src\\NetworkEvents.cpp" -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\Network\\NetworkEvents.cpp.o"
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -Wall -Wextra -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts" "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src\\NetworkInterface.cpp" -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\Network\\NetworkInterface.cpp.o"
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -Wall -Wextra -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts" "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src\\NetworkServer.cpp" -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\Network\\NetworkServer.cpp.o"
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -Wall -Wextra -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashFreq=80,FlashMode=qio,PartitionScheme=huge_app,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\pc\\AppData\\Local\\Temp\\.arduinoIDE-unsaved202463-11960-14uw7jk.4mw5k\\CameraWebServer" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts" "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src\\NetworkUdp.cpp" -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\Network\\NetworkUdp.cpp.o"
Compiling core...
cmd /c echo -DARDUINO_CORE_BUILD > "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts"
Using precompiled core: C:\Users\pc\AppData\Local\Temp\arduino\cores\88f14de087da47e138a8fa9753b3c517\core.a
cmd /c type nul > "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/file_opts"
Linking everything together...
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/ld_flags" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/ld_scripts" "-Wl,--Map=C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/CameraWebServer.ino.map" "-LC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/lib" "-LC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/ld" "-LC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi" -Wl,--wrap=esp_panic_handler -Wl,--start-group "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\sketch\\CameraWebServer.ino.cpp.o" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\sketch\\app_httpd.cpp.o" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\WiFi\\AP.cpp.o" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\WiFi\\STA.cpp.o" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\WiFi\\WiFi.cpp.o" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\WiFi\\WiFiAP.cpp.o" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\WiFi\\WiFiGeneric.cpp.o" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\WiFi\\WiFiMulti.cpp.o" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\WiFi\\WiFiSTA.cpp.o" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\WiFi\\WiFiScan.cpp.o" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\Network\\NetworkClient.cpp.o" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\Network\\NetworkEvents.cpp.o" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\Network\\NetworkInterface.cpp.o" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\Network\\NetworkManager.cpp.o" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\Network\\NetworkServer.cpp.o" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0\\libraries\\Network\\NetworkUdp.cpp.o" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\cores\\88f14de087da47e138a8fa9753b3c517\\core.a" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/ld_libs" -Wl,--end-group -Wl,-EL -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/CameraWebServer.ino.elf"
Using library WiFi at version 2.0.0 in folder: C:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi
Using library Networking at version 1.0.0 in folder: C:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network
exit status 1
Compilation error: exit status 1
I took this line in the current error message as :
Then, I followed through intruction 4 to 11. And attached to this m,essage is a screen shot of what i saw in the terminal, I waited for a minute before i took the screenshot after pasting that text on the command prompt.
From my observation, there was no message printed in the cmd terminal after i performed step (12).
Thanks so much for your help so far on this.. I do appreciate so much.
I'll be on standby for your response.
OK, this indicates that it is not that command that is the one causing the failure.
Arduino IDE does normally run several other commands after this point where your output stopped. Normally it would print those commands to the "Output" panel though, but perhaps the failure is somehow pre-empting that.
What happens if you run this command from the Windows cmd terminal?
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-size" -A "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino\\sketches\\2A9DDFE7A5247DB007DF1E108282A9B0/CameraWebServer.ino.elf"
You can use the same procedure as before for starting a cmd terminal. But this time run the command I shared above instead of the one copied from the Arduino IDE Output panel.
Arduino IDE would normally run that xtensa-esp32-elf-size command around the time it is printing the "Using library ..." messages we see at the very end of your output before the error.
