So i've come to the conclusion I fried my Arduino UNO. Now that I've gotten a little more experience, I thought, maybe I should get a different Arduino. Or even better (possibly), a different microcontroller.
What are you guys's recommendations on this subject? I don't need things like outputs, I can use shift registers.
You likely either pulled >= 40mA from a pin, or shorted a pin to ground, or something like that. Be more careful.
They can all be destroyed in the same ways. More money won't protect it from misuse.
Bigger Arduinos have more outputs by default, for the most part.
All that aside. I'd recommend getting another UNO unless you have some specifically large project. I use a Mega, but that's because I needed a lot of pins.
[A good read.](http://maybe I should get a different Arduino. Or even better)
If you think you need a Mega for SRAM, consider 1284P as this is a DIP chip too and 2X the SRAM!
For times after experimentation and for prototype, the mini Pro, Nano, and other SMT designs are good and less expensive semipermanent use.
The reason the UNO is recommended as a starter Arduino is because the uC is replaceable... Most if us have cremated a few AVRs ... Some more than others.
mees01234:
Arduino's I'm considering: - Nano
Micro
Mega
You maybe fried the 328P chip and not the board itself. In that case you can buy a new 328P, and being a beginner you want to find one with the bootloader on it. That will run you $4 or $5 plus shipping and a little careful work prying the old chip out and inserting the new one. A new empty 328P runs about $2.50 or less. The more you buy, the cheaper they get.
It can't hurt much to have more than one Arduino, especially with some of the new ones out.
You can make your own on a breadboard or PCB or even build right on the chip (not a real good idea).
Here's a complete step by step for 2 different chips:
That's basically it. All you really need is the chip, power, ground and a bypass cap to have a running computer.
I'd go with a socket instead of the protoboard. Want flat headers? Bend the socket pins out and solder headers right to the pins. Solder the cap underneath and glue it to a base after testing. There might be room for a crystal and caps underneath, they should be as close to the chip as possible.
You can even swap chips in and out of the socket, something you can't easily do with a soldered chip.
For me, AVR's were the first to give the term 'stand-alone chips' real meaning.
