im currently using a 595 and 4021 to decode a 8x8 button pad.
the 595 output pins are connected directly to the 4021 input pins, and each of the 4021 input pins also have a resistor to ground like the arduino.cc examples. each button has a 1n4148 diode. i do have a .1uf cap to prevent flickering like the tutorials show.
the problem im having is ... without the delayMicroseconds(20) after shifting in the value to the 595, the 4021 reads what appears to be a >> 1 shifted value. it works fine with the added delay the problem is that the delays are starting to add up with 8 iterations.... so the button presses aren't immediate, and lowering the delay much more than 20ms results in poorly shifted data.
any thoughts on how to speed it up while maintaining data integrity?
reasons for it requiring such a long delay? flickering on 595 outputs... flickering on input signal? diode delay? you can see my schematic a few topics down.
thanks for any help. - unsped
the outputs of the following code as an example while holding down appropriate button:
d[8][8] is a boolean array that stores my led states. the code below is simplified and doesn't debounce input or check for existing states. mrow[8] is a byte array that stores the value being sent to the max72XX for each row.
(commas separate each iteration)
with delay and 595 value of 1:
4021 output - N,0,0,0,0,0,0,0
without delay and 595 value of 1:
4021 output - 0,N,0,0,0,0,0,0
with delay and 595 value of 128:
4021 output - 0,0,0,0,0,0,0,N
without delay and 595 value of 128:
where N is the 4021 output value 0-255
inputrow = 0;
for (i=1; i<=128; i=i*2) {
// 595
digitalWrite(outlatchPin, 0);
shiftOut(outdataPin, outclockPin, i); // set each 595 output high through iteration
digitalWrite(outlatchPin, 1);
delayMicroseconds(20);// lag on output pin being triggered
// 4021 Pulse the latch pin:
digitalWrite(inlatchPin,1);
digitalWrite(inlatchPin,0);
switchVar[inputrow] = shiftIn(indataPin, inclockPin);
//migrate switchvar data into d[]
d[7][inputrow] += (switchVar[inputrow] & 1);
d[6][inputrow] += (switchVar[inputrow] & 2) >> 1;
d[5][inputrow] += (switchVar[inputrow] & 4) >> 2;
d[4][inputrow] += (switchVar[inputrow] & 8) >> 3;
d[3][inputrow] += (switchVar[inputrow] & 16) >> 4;
d[2][inputrow] += (switchVar[inputrow] & 32) >> 5;
d[1][inputrow] += (switchVar[inputrow] & 64) >> 6;
d[0][inputrow] += (switchVar[inputrow] & 128) >> 7;
//end migration
inputrow++;
//construct displays from d[] array
for (e=0; e<=7; e++) {
mrow[e] = (d[e][7]) + (d[e][6] << 1) + (d[e][5] << 2) + (d[e][4] << 3) + (d[e][3] << 4) + (d[e][2] << 5) + (d[e][1] << 6) + (d[e][0] << 7);
maxSingle(e+1,mrow[e]);
}// end loop()
standard shiftin() function
////// ----------------------------------------shiftIn function
///// just needs the location of the data pin and the clock pin
///// it returns a byte with each bit in the byte corresponding
///// to a pin on the shift register. leftBit 7 = Pin 7 / Bit 0= Pin 0
byte shiftIn(int myDataPin, int myClockPin) {
int i;
int temp = 0;
int pinState;
byte myDataIn = 0;
pinMode(myClockPin, OUTPUT);
pinMode(myDataPin, INPUT);
//we will be holding the clock pin high 8 times (0,..,7) at the
//end of each time through the for loop
//at the begining of each loop when we set the clock low, it will
//be doing the necessary low to high drop to cause the shift
//register's DataPin to change state based on the value
//of the next bit in its serial information flow.
//The register transmits the information about the pins from pin 7 to pin 0
//so that is why our function counts down
for (i=7; i>=0; i--)
digitalWrite(myClockPin, 0);
delayMicroseconds(0.2);
temp = digitalRead(myDataPin);
if (temp) {
pinState = 1;
//set the bit to 0 no matter what
myDataIn = myDataIn | (1 << i);
else {
//turn it off -- only necessary for debuging
//print statement since myDataIn starts as 0
pinState = 0;
//Debuging print statements
//Serial.print(pinState);
//Serial.print(" ");
//Serial.println (dataIn, BIN);
digitalWrite(myClockPin, 1);
//debuging print statements whitespace
//Serial.println();
//Serial.println(myDataIn, BIN);
return myDataIn;
