Good evening, colleagues!
After upgrading to the IDE Arduino 1.0, I no longer compile the program to work with the LCD display.
I am using shield with an 1602 LCD display and five buttons like this here - http://www.geeetech.com/arduino-lcd-1602-keypad-shield-p-251.html
I am using Arduino IDE 1.0 for Mac OS X.
I'm downloading the library, and then unpack it and copy in the directory '/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/'.
After starting, IDE is find the library and loads of examples from it.
If you try to compile the sample LCD4Bit_modExample.pde I get the following diagnosis:
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:29:57: error: WConstants.h: No such file or directory
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp: In member function 'void LCD4Bit_mod::pulseEnablePin()':
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:58: error: 'LOW' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:58: error: 'digitalWrite' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:59: error: 'delayMicroseconds' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:61: error: 'HIGH' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:64: error: 'delay' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp: In member function 'void LCD4Bit_mod::pushNibble(int)':
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:73: error: 'digitalWrite' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp: In member function 'void LCD4Bit_mod::commandWriteNibble(int)':
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:99: error: 'LOW' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:99: error: 'digitalWrite' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp: In member function 'void LCD4Bit_mod::commandWrite(int)':
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:106: error: 'LOW' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:106: error: 'digitalWrite' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp: In member function 'void LCD4Bit_mod::print(int)':
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:118: error: 'HIGH' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:118: error: 'digitalWrite' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:119: error: 'LOW' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp: In member function 'void LCD4Bit_mod::clear()':
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:139: error: 'delay' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp: In member function 'void LCD4Bit_mod::init()':
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:146: error: 'OUTPUT' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:146: error: 'pinMode' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:154: error: 'delay' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:160: error: 'delayMicroseconds' was not declared in this scope
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp: In member function 'void LCD4Bit_mod::leftScroll(int, int)':
/Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:225: error: 'delay' was not declared in this scope
All forums are advised to replace on file LCD4Bit_mod.cpp the line '#include "WConstants.h" on "#include "Arduino.h"'.
Alas, this does not lead to success.
It turns out that's what:
In file included from /Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Arduino.h:191,
from /Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:29:
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:116: error: declaration of C function 'StringSumHelper& operator+(const StringSumHelper&, const char*)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:115: error: previous declaration 'StringSumHelper& operator+(const StringSumHelper&, const String&)' here
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:117: error: declaration of C function 'StringSumHelper& operator+(const StringSumHelper&, char)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:116: error: previous declaration 'StringSumHelper& operator+(const StringSumHelper&, const char*)' here
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:118: error: declaration of C function 'StringSumHelper& operator+(const StringSumHelper&, unsigned char)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:117: error: previous declaration 'StringSumHelper& operator+(const StringSumHelper&, char)' here
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:119: error: declaration of C function 'StringSumHelper& operator+(const StringSumHelper&, int)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:118: error: previous declaration 'StringSumHelper& operator+(const StringSumHelper&, unsigned char)' here
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:120: error: declaration of C function 'StringSumHelper& operator+(const StringSumHelper&, unsigned int)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:119: error: previous declaration 'StringSumHelper& operator+(const StringSumHelper&, int)' here
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:121: error: declaration of C function 'StringSumHelper& operator+(const StringSumHelper&, long int)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:120: error: previous declaration 'StringSumHelper& operator+(const StringSumHelper&, unsigned int)' here
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:122: error: declaration of C function 'StringSumHelper& operator+(const StringSumHelper&, long unsigned int)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WString.h:121: error: previous declaration 'StringSumHelper& operator+(const StringSumHelper&, long int)' here
In file included from /Users/ogogon/Documents/Arduino/libraries/LCD4Bit_mod/LCD4Bit_mod.cpp:29:
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Arduino.h:195: error: declaration of C function 'uint16_t makeWord(byte, byte)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Arduino.h:194: error: previous declaration 'uint16_t makeWord(uint16_t)' here
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Arduino.h:205: error: declaration of C function 'long int random(long int)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/include/stdlib.h:504: error: previous declaration 'long int random()' here
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Arduino.h:206: error: declaration of C function 'long int random(long int, long int)' conflicts with
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Arduino.h:205: error: previous declaration 'long int random(long int)' here
How can I overcome this problem?
Ogogon.
