OS:Windows 7
board:arduino Uno
IDE:arduino-1.0
shield:KeyPadLCDShield
I get errors when compiling the sketch with the #include <LCD4Bit.h> old LCD library, this shield (KeyPadLCDShield from muelectronic) requires this library or the <LCD4Bit_mod.h> in order to work.
sketch>import library>LCD4Bit adds <LCD4Bit.h> in the IDE text editor.
The program never compiles, even with the first one nor the second one, the compiler sends me error messages.
arduino-1.0-windows\arduino-1.0\libraries\LCD4Bit\LCD4Bit.cpp:29:57: error: WConstants.h: No such file or directory
arduino-1.0-windows\arduino-1.0\libraries\LCD4Bit\LCD4Bit.cpp:225: error: 'delay' was not declared in this scope
tested with #include <LiquidCrystal.h>
void setup(){};
void loop(){};
compiles successfully!
OS:Windows XP
board:arduino Uno
IDE:arduino-1.0
Hello!
Also newbie, I have the same problem.
I googled a bit, but did not find anything useful.
Could you solve this issue?
Thanks for helping a more newbie than you!
Open this file.
At line 29, you should find this #include <WConstants.h>
Change to #include <Arduino.h>
The delay declaration in now in that file in V1.0.
Just received my LCD shield and had the same problem. Looking at some other libraries that are (made) v1.0 compatible, I figured out that for it to work with v1.0 arduino code, you don't need all the other libraries, just Arduino.h and the LCD4Bit_mod.h. I changed the headers in the LCD4Bit_mod.cpp file to look like this:
Hello all!
I'm absolutely new here, and new on using arduino 'by myself'. I've read all what i found here about "Cannot find WConstants.h", and still cant find the problem. I'm trying to use one of the stepper motor control provided with the last version of arduino software, reporting:
In file included from stepper_speedControl.ino:20:
/Users/xxx/Documents/Arduino/libraries/Stepper/Stepper.h:52:24: error: WConstants.h: No such file or directory
but there is no reference to that "WConstants.h" file neither on that stepper.h, or .cpp or everywhere in my arduino instalation
I know you'll hate me, and maybe you'll ban me, but... i cant understand (yet..)
I solved the problem by downgrading from version 1.0 to 0023.
See that post http://forum.arduino.cc/index.php/topic,96356.0.html
LCD4Bit_mod is not compatible with versions > arduino 0.23.
And also notice it have to be use with HD44780 LCD driver.
/tmp/arduino_modified_sketch_69442/LCD4Bit_modExample.ino: In function 'void setup()':
/tmp/arduino_modified_sketch_69442/LCD4Bit_modExample.ino:27:43: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
lcd.printIn("KEYPAD testing... pressing");
/tmp/arduino_modified_sketch_69442/LCD4Bit_modExample.pde: At global scope:
LCD4Bit_modExample:6: error: redefinition of 'LCD4Bit_mod lcd'
LCD4Bit_mod lcd = LCD4Bit_mod(2);
/tmp/arduino_modified_sketch_69442/LCD4Bit_modExample.ino:6:13: note: 'LCD4Bit_mod lcd' previously declared here
LCD4Bit_modExample:9: error: redefinition of 'char msgs [5][15]'
char msgs[5][15] = {"Right Key OK ",
/tmp/arduino_modified_sketch_69442/LCD4Bit_modExample.ino:9:6: note: 'char msgs [5][15]' previously defined here
LCD4Bit_modExample:14: error: redefinition of 'int adc_key_val [5]'
int adc_key_val[5] ={30, 150, 360, 535, 760 };
/tmp/arduino_modified_sketch_69442/LCD4Bit_modExample.ino:14:6: note: 'int adc_key_val [5]' previously defined here
LCD4Bit_modExample:15: error: redefinition of 'int NUM_KEYS'
int NUM_KEYS = 5;
/tmp/arduino_modified_sketch_69442/LCD4Bit_modExample.ino:15:5: note: 'int NUM_KEYS' previously defined here
int NUM_KEYS = 5;
LCD4Bit_modExample:16: error: redefinition of 'int adc_key_in'
int adc_key_in;
/tmp/arduino_modified_sketch_69442/LCD4Bit_modExample.ino:16:5: note: 'int adc_key_in' previously declared here
int adc_key_in;
LCD4Bit_modExample:17: error: redefinition of 'int key'
int key=-1;
/tmp/arduino_modified_sketch_69442/LCD4Bit_modExample.ino:17:5: note: 'int key' previously defined here
int key=-1;
LCD4Bit_modExample:18: error: redefinition of 'int oldkey'
int oldkey=-1;
/tmp/arduino_modified_sketch_69442/LCD4Bit_modExample.ino:18:5: note: 'int oldkey' previously defined here
int oldkey=-1;
/tmp/arduino_modified_sketch_69442/LCD4Bit_modExample.pde: In function 'void setup()':
LCD4Bit_modExample:20: error: redefinition of 'void setup()'
/tmp/arduino_modified_sketch_69442/LCD4Bit_modExample.ino:20:6: note: 'void setup()' previously defined here
/tmp/arduino_modified_sketch_69442/LCD4Bit_modExample.pde:27:43: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
/tmp/arduino_modified_sketch_69442/LCD4Bit_modExample.pde: In function 'void loop()':
LCD4Bit_modExample:31: error: redefinition of 'void loop()'
/tmp/arduino_modified_sketch_69442/LCD4Bit_modExample.ino:31:6: note: 'void loop()' previously defined here
/tmp/arduino_modified_sketch_69442/LCD4Bit_modExample.pde: In function 'int get_key(unsigned int)':
LCD4Bit_modExample:62: error: redefinition of 'int get_key(unsigned int)'
int get_key(unsigned int input)
/tmp/arduino_modified_sketch_69442/LCD4Bit_modExample.ino:62:5: note: 'int get_key(unsigned int)' previously defined here
exit status 1
