I've tried several things. I cannot upload my sketched to this nano 328. It gives me an error that says the com port is being used.
I've tried following both of these videos that seem to work for everyone else.
No luck. Mprog doesn't find the device and when I try to install the driver I never get the option to set it as a serial converter. Only serial port shows up. Any ideas?
Yep I'm on Windows 7. Forgot to mention that.
Thanks for the response and the new idea but sadly it still didn't work.
I switched it over to a COM that did not say "in use". COM 12 to be specific. It warned me that it could have unpredictable effects. I went ahead and did it anyway. Same result.
"Serial port already in use. Try quitting any programs that may be using it."
The port shows up and I can select it, but it won't let me upload.
After it didn't work I tried updating the driver and it still doesn't accept the upload.
Yea I tried rebooting too.
Nothing seems to work. My Uno and Mega2560 work just fine. I forgot to mention this is a chinese clone of the nano. Doesn't seem to matter for everyone in the comments of those two videos though. But my UNO isn't Arduino either it's a Sparkfun Red Board.
Once you choose port . have you tried to upload boot loader again.Here i am attaching driver section. download it on arduino folder remover old driver folder. chose below path.
Please try to put snap shot along with arduino IDE .or error where you seeing so we can really help it to work
K. I deleted the old driver and put yours in. Again, I can only set it as a port in device manager, it never allows me to set it as a converter. It prompted me to restart my computer afterward so I did. After all was said and done I still get the same result.
Here's the error.
enabled in File > Preferences.
Arduino: 1.0.6 (Windows 7), Board: "Arduino Nano w/ ATmega328"
Binary sketch size: 1,070 bytes (of a 30,720 byte maximum)
processing.app.SerialException: Serial port 'COM1' already in use. Try quiting any programs that may be using it.
at processing.app.Serial.<init>(Serial.java:171)
at processing.app.Serial.<init>(Serial.java:77)
at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:77)
at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:175)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:67)
at processing.app.Sketch.upload(Sketch.java:1666)
at processing.app.Sketch.exportApplet(Sketch.java:1622)
at processing.app.Sketch.exportApplet(Sketch.java:1594)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2382)
at java.lang.Thread.run(Thread.java:619)
processing.app.debug.RunnerException: Serial port 'COM1' already in use. Try quiting any programs that may be using it.
at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:101)
