New tutorial - Arduino and the NXP PCF8563 real time clock IC
A few people asked me for a tutorial on how to use the NXP PCF8563 real time clock IC. So here you go:
which explains the time, date, oscillator outputs, alarm function and error-checking.
I like this, karma awarded. :slight_smile:
oh, does your e-book have color photos?
Thanks. The print and electronic versions are in grey-scale.
Sorry for bring this from the grave but I'm having some problems with the RTC.
Well, I don't know if this is really a RTC clock problem or if it's an arduino problem. I'm using an Arduino Leonardo (maybe the fault is here) with a PCF8563 and a 32.768 kHZ crystal.
I'd tried to use the arduino "official" library for the PCF8563 and now I'm trying with your code and the results are the same:
 45/25/20165 - 45:85:85
Is there anything I need to change in some library to make it work with Leonardo?
I have 10 RTC chips (all the same model) and all of them show the same result...
Hope you can help a noobie here :blush:
canibalimao:
Leonardo - OK, the pins are different. I2C SDA is 2 and SCL is 3. Double-check your wiring and then try my example 54.1 sketch again.
Out of curiosity, where did you get the PCF8563s from?
tronixstuff:
canibalimao:
Thank you very much. I just need to change the wiring, or need to change other thing else on the code?
On eBay, from a chinese guy :grin:
canibalimao:
tronixstuff:
canibalimao:
Code should be fine. Are you in Australia by any chance?
tronixstuff:
canibalimao:
tronixstuff:
canibalimao:
Thank you very much. Latter on I'll try that and give here some feedback.
No, I'm from Portugal.
And by the way, what a great website you have with all the tutorials :smiley:
PS: I saw now that the leonardo board has an SCL and an SCA separate pin header. Should I use this instead the A3 and A2?
EDIT: It's working finally! :smiley:
Thank you very much tronix! It's working using the SCL and SDA dedicated ports on the board (the 2 one on the left of Digital side).
Now let's play :smiley:
Good news, thanks for letting me know. Have fun!
