Timekeeping without RTC+ Interrupt?
Hi!
My first packege with Arudino stuff is on it´s way for my home automation projects are taking form in my head.
My first project will be a dry food feeder for the dog.
Thought a servo that can rotate continuously will turn the feeder for X ms for the right amount of dry food.
Then the Arduino will wait for 24 hours before it´s time again.
This way if I want to food the dog 18:00, I just power on the Arduino at 18:00 and it will dispense dryfood every 24 hour.
How can I program the Arduino to wait 24 hours without a RTC chip?
I checked this but I can´t see how the int can keep that high amount of miliseconds
Also, there will be a button, if pressed it will dispense some additional food.
(That would be the interrupt).
Can I start a counter when the Arduino is powered on and use a IF when the counter have waited for 24 hours?
For example:
TempServo.attach(13);
Ini 24Timer start
IF 24timer = 24hours;
TempServo.write(110); //Dispense food
delay(1800);
IF Button = 1
delay(1800);
You certainly can, but it is not very accurate. If your dog does not mind changing its feeding time a few minutes each day...
But you don't need interrupts. For something like this simply *polling the RTC every second or so would be sufficient.
*polling means that you regularly ask the RTC what time it is.
Why is the Arduino timer not accurate? (Minutes change every day).
Also I do not have an RTC chip.
Thant´s why I ask about timer (Or something similar)
Maybe I can use the "millis()" ?
Or will it not be accurate either?
Will the timer add one or two minutes every time? Or the Arduino execute the code 18:00 plusminus 2 minutes?
istvanuino:
https://www.arduino.cc/en/Reference/Delay
Apparently, the delay() function takes an unsigned long as input. Go ahead, try delay(86400000UL) and see what happens.
One other problem that you will more than likely encounter is a power failure / reset of the arduino. You're timing will be lost. You also might need to set the initial time or start the Arduino at 'exactly' 6 o'clock.
A RTC is a million times ( :wink: ) easier.
