Hi
My ESP32 WROOM gives only 0.2v between ground and pin 14, what should I expect?
I will turn on a SSD relay, but of course nothing happens...
Previously I tested Wemos ESP8266, that pin gave 3.3V
Any idea?
code:
const int ssrPin = 14;
pinMode(ssrPin, OUTPUT);
Serial.println("Arduino SSR Control");
digitalWrite(ssrPin, HIGH);
Serial.println("SSR turned ON");
delay(3000);
digitalWrite(ssrPin, LOW); // Set ssrPin low
Serial.println("SSR turned OFF");
delay(3000);
3.3V is expected on the GPIO pins of a ESP32 development module. Is that V's measured without a load on the pin?
Are you sure you're measuring Arduino pin 14? The schematic and Arduino pins vary.
LarryD
June 19, 2023, 5:56pm
4
G14 is pin 13 on the ESP-WROOM-32
Hi
I can have mixed pins but...
Anything I don't understand?
I use pin 14 on board + GND, according to pinout it is GPIO14:
Espressif:
0.2 fixed mcu broken. New mcu all ok
Shown below (Fig-2) is a pin mapping diagram among 48-pin LX6 Microcontroller, 38-pin ESP-WROOM-32 Module, and 30-pin ESP32S Dev Kit, which has been prepared based on Espressif's official documents. Here, in this diagram, there is no G14.
Figure-1
Figure-2:
Modesty:
My ESP32 WROOM
Are you referring to: ESP-WROOM-32 Module based 30-pin ESP32S Dev Kit of Fig-1 (upper)? There are many versions of ESP32 Dev Kit.
GolamMostafa:
there is no G14.
I cant aswer other than my wroom have gpio14, and its working for me, ref picture i added 2 days ago.
My ESP32S shows:
VOL = 0.0V (max: 0.33V)
VOH = 3.0V (min: 2.64V)
The above readings agree with the data sheets (Fig-1:.
Figure-1:
Test Sketch:
pinMode(14, OUTPUT);
digitalWrite(14, LOW);
delay(10000);
digitalWrite(14, HIGH);
void loop() {}
Thanks for all help. My system is now working
From datasheet: esp32-wroom-32_datasheet_en.pdf
Here is the WEB GUI for my fish feeder:
IO14/Pin-13 of RF Shielded ESP-ROOM-32 Module is not exposed to user via header pin. It is connected at D14/Pin-11 of the 30-Pin ESP32S Dev Kit (Fig-1, 2) of post #7 .
