Guy please help with this code i made the part con count 0/999 but i don't know how to make 999/0
Por favor ayudenme, ya hice la parte de codigo que va de 0 hasta 999 pero ni idea como hacer el contador de 999 a 0 descendete
byte lectura=B0;
unsigned int contadorInterruptor=0,contadorAnodos=0,contadorNumero=0;
byte numero=0,bases=0;
const byte deco7seg[10]={B1000000,B1111001,B100100,B110000,B11001,B10010,B10,B1111000,B0,B10000};
const byte anodos[3]={B110,B101,B011};
int infoDisplays[3]={0,0,0};
void setup(void) {
DDRL=B111;
DDRC=B1111111;
PORTL=B11100;
void timers(void){
contadorNumero++;
contadorInterruptor++;
contadorAnodos++;
delay(1);
void loop(void) {
PORTL=B111;
if(contadorNumero==60){
contadorNumero=0;
infoDisplays[0]++;
if (infoDisplays[0]==10)
infoDisplays[0]=0;
infoDisplays[1]++;
if(infoDisplays[1]==10){
infoDisplays[1]=0;
infoDisplays[2]++;
if(infoDisplays[2]==10){
infoDisplays[2]=0;
if(contadorInterruptor==200){
contadorInterruptor=0;
lectura=(PINL&B11100)>>3;
if(contadorAnodos==8)
contadorAnodos=0;
PORTL=anodos[bases];
PORTC=deco7seg[infoDisplays[bases]];
bases++;
if (bases==3){ bases=0;}
timers();
You have posted code without using code tags. This creates certain problems and obstacles for other forum members. The code tags make the code look
like this
when posting source code files. It makes it easier to read, and can be copied with a single mouse click.
If you have already posted without using code tags, open your message and select "modify" from the pull down menu labelled, "More", at the lower left corner of the message. Before posting the code, use Ctrl-T in the IDE to reformat the code in a standard format, which makes it easier for us to read. Highlight your code by selecting it (it turns blue), and then click on the "</>" icon at the upper left hand corner. Click on the "Save" button. Code tags can also be inserted manually in the forum text using the
[code]and [/code]
metatags.
When you are finished that, please read this post:
How to use this forum - please read.
I think that you have learned how to subtract at school
To count down, start with all digits set to 9. Then subtract 1 from the lowest digit, and if the result is beyond 0, set it to 0 and continue to subtract 1 from the next digit (borrow).
It may be much easier to use an int variable for the value, which you can increment and decrement easily. Much easier than your BCD representation of the counter. Then write a function to decode that binary value into decimal digits, for output to the display.
