1.8" SPI TFT White screen
Hello guys,
im having a strange problem with the 1.8" TFT SPI display i got on Ebay.
any code i run, with any graphic library i run, will always display a white screen until i hit the arduino RESET. i can barely see the graphics running behind the almost completely white screen, until i hit RESET.
while the arduino RESET button is pressed, i could see the actual display properly in all correct colors! but once it boots up again - white screen again.
here is a video of the problem:
and here is an example code (from adafruit examples).
with this code, when arduino powers on - white screen.
when i hold the RESET button pressed - blue screen appears.
i did triple checked all connections and they are all good. im running 5V without the J1 jumper to set the LCD to work with 5V.
thanks.
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library
#include <SPI.h>
// For the breakout, you can use any 2 or 3 pins
// These pins will also work for the 1.8" TFT shield
#define TFT_CS     10
#define TFT_RST    9  // you can also connect this to the Arduino reset
                      // in which case, set this #define pin to 0!
#define TFT_DC     8
// Option 1 (recommended): must use the hardware SPI pins
// (for UNO thats sclk = 13 and sid = 11) and pin 10 must be
// an output. This is much faster - also required if you want
// to use the microSD card (see the image drawing example)
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS,  TFT_DC, TFT_RST);
// Option 2: use any pins but a little slower!
#define TFT_SCLK 13   // set these to be whatever pins you like!
#define TFT_MOSI 11   // set these to be whatever pins you like!
//Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
float p = 3.1415926;
int BLPin = 7;
void setup(void) {
  // Use this initializer if you're using a 1.8" TFT
  tft.initR(INITR_BLACKTAB);   // initialize a ST7735S chip, black tab
  // Use this initializer (uncomment) if you're using a 1.44" TFT
  //tft.initR(INITR_144GREENTAB);   // initialize a ST7735S chip, black tab
  uint16_t time = millis();
  tft.fillScreen(ST7735_BLUE);
  time = millis() - time;
I also noticed that if i reupload the blue screen code, while the uploading process is running - screen is blue.
seems like there's a pull down line missing somewhere which is occuring while RESET is held or while a code upload process is running... any ideas guys?
This looks like the usual 5V logic level problem. The digital input lines of thee displays do not like 5V logic levels.
Try a 2K2 between the Arduino pin and the display pin on each Arduino digital output pin.
I have created a fast library for these displays that you may wish to try. You can find it here.
thank you, that did the trick!
im trying to find an example of "gauge" graphics that i can runa dn play with - any idea where i could get one?
something that looks like 0:15 in this video:
The display you provided a link to has a much higher resolution and so you will be limited in what you can display.
There is a retro look meter example in my library here (TFT_7735_Meter_5) that may be a good starting point. Also an analogue clock display (TFT_Clock_ST7735).
You will need to edit the User_Setup.h file in the library to suit your setup.
