1 sensor to detect full it range? Available?
I have some ideas, but need to determine the ir wave length of a few devices. Is there a sensor I can get that with the help of an Arduino will tell me the ir wavelength of the input?
Or am I out of luck and will just need to buy a set of sensors and test each on?
Thanks for your time.
Please tell us more.
Do you want to build a infrared spectrum analyzer ? A lambdameter ? What do you need it for ?
I don't even know what a lambdameter is, I just found that word somewhere :wink:
I suspect that a lambdameter indicates lambdas.
@OP Do tell us about these "devices".
I have some random leds, some nice laser tag guns, a few toys that work with off of ir. I would also like to find nm of a few remotes to make diy extenders / repeaters.
I would like to detect what range this thing are in so I can build custom hardware to work with them.
IR LEDs emit over a range of wavelengths. Two common types have maxima at 850 nm and 940 nm (see below). But photodiodes typically have a much broader detection range (second image) and will "see" both LEDs.
Silicon photodiode response:
Perhaps the most accurate method would be to get a set of calibrated IR filters and use them and a photodiode to find the wavelength that passes a particular filter.
Paul
Perhaps use a strip of an old CD as a diffraction grating and build a primitive spectrometer?
A simple servo to move a photodiode across the range of interest, calibrate with known IR
emitters?
I'm off to ask a new question now :wink:
Thank you all for your time.
Perhaps there is a section at StackExchange where people are with infrared sensor knowledge ?
